Panasonice AE4000 image issue - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 08-19-2012, 12:16 PM - Thread Starter
bubbakja's Avatar
I normally like to google my own problems, but I don't know what to call this issue. I've tried every adjustment I can find in the menu's and with the mount I have (peerless prg mount) and I cannot figure out why the image is doing this. Basically on the right half of the screen its perfectly sized and straight. The left side starting at about the middle of the screen the top and bottom slightly angle up/down so that the far left border is a bit smaller than the right side. I checked keystone and those settings didn't seem to do anything. Anyone have any ideas ? The grey is my screen black would be the edge of the image.
bubbakja is offline
post #2 of 4 Old 08-19-2012, 06:57 PM
jnabq's Avatar
Liked: 39
Normally that might occur if the pj isn't perfectly level. Might wanna check that?
jnabq is offline
post #3 of 4 Old 08-19-2012, 11:30 PM
invadergir's Avatar
Quoted: 56 Post(s)
Liked: 37
^^^What they said. Had the same issue when i first got my Epson 8350 and it was all because i didn't have my projector leveled and my front end wasn't facing the screen flat on.
My DVD Collection
HOME THEATER:
JVC X950RB Projector, 106", Samsung 51" 3D Plasma, Marantz sr7010 in 5.2.4 Atmos/DTS:X
invadergir is offline
post #4 of 4 Old 08-20-2012, 07:42 AM
Mr.G's Avatar
Quoted: 743 Post(s)
Liked: 422
As the others have pointed out incorrect alignment is the cause of your problem. Assuming your projector is level front to back and side to side, the problem is from the projector lens not being square to the screen. Make sure that any menu corrections (keystone, etc.) you tried are set back to zero.
All I Really Need to Know I Learned in Kindergarten Movies
Mr.G is offline
