benq w7000 screen size recomendations, please??? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 08-22-2012, 09:38 AM - Thread Starter
jkmicronix's Avatar
I was hoping to get some recommendations on screen size for this PJ. I set it up at 110" sitting about 13.5 feet back. it just didn't feel that big!
I'm also going to have seating behind the front row...so that will be close to 16 or 17 feet away.
for movies, the room will be pretty well blacked out...but another primary use is going to be for football games in dim-lit situations.
I just put up a bit 12' by 8' black floating panel above the area where the screen will be positioned, and the screen wall will be a very dark blue. I will also have a black rug on the floor in front of the screen.
jkmicronix is offline
post #2 of 12 Old 08-22-2012, 10:35 AM
Mr.G's Avatar
Quoted: 603 Post(s)
Liked: 309
You don't mention the height of your ceiling which will also help determine the optimum screen size.
http://www.projectorreviews.com/benq/w7000/screens.php
All I Really Need to Know I Learned in Kindergarten Movies
Mr.G is offline
post #3 of 12 Old 08-22-2012, 11:46 AM
MichaelG's Avatar
What software are you using for your floor plan, with cost?
MichaelG is offline
post #4 of 12 Old 08-22-2012, 03:45 PM - Thread Starter
jkmicronix's Avatar
it's web based...and awesome. you can render your layout in 3d as well: http://www.floorplanner.net
post #5 of 12 Old 08-22-2012, 03:45 PM - Thread Starter
jkmicronix's Avatar
8ft cielings. thanks!
post #6 of 12 Old 08-22-2012, 03:46 PM - Thread Starter
jkmicronix's Avatar
post #7 of 12 Old 08-22-2012, 03:51 PM
coderguy's Avatar
Quoted: 322 Post(s)
Liked: 277
As big as you can stand it from the front row. Probably 120"+.
Access HERE from this thread
coderguy is offline
post #8 of 12 Old 08-22-2012, 03:54 PM - Thread Starter
jkmicronix's Avatar
about how large can I still go....with some ambient light....before I start to get a noticeably dimmer picture?
post #9 of 12 Old 08-22-2012, 03:54 PM - Thread Starter
jkmicronix's Avatar
thanks, guys. this is much appreciated.
post #10 of 12 Old 08-22-2012, 04:06 PM
coderguy's Avatar
Quoted: 322 Post(s)
Liked: 277
LOL, with the w7000, well you can go to about 150" comfortably, and 140" easy. That is with 1.0 gain, you can go bigger if you want.
coderguy is offline
post #11 of 12 Old 08-22-2012, 06:05 PM - Thread Starter
jkmicronix's Avatar
thanks, coderguy. will I notice much difference in brightness going from 110 to 140 or 150 with some ambient light? ie, daytime, shades drawn...bar room type lighting.
post #12 of 12 Old 08-22-2012, 07:05 PM
coderguy's Avatar
Quoted: 322 Post(s)
Liked: 277
As the lamp ages, yah it will be a big noticeable difference, but it'll be ok at first at least.
coderguy is offline
