Additional options on the AE-100 - AVS Forum | Home Theater Discussions And Reviews
Old 05-23-2002, 02:36 PM - Thread Starter
crodrigues's Avatar
Hey Guys,
I saw a couple threads from Li On and many others about their settings on the AE-100. The basic ones (brightness, contrast, sharpness etc) are right there in the Picture menu.
And for R, G, B and any additional tweaks? What do I need to do to access them? Is there something I'm missing?
C
crodrigues is offline
Old 05-23-2002, 02:40 PM
fcg_vi's Avatar
If you read a bit more into the threads or the owner's manual you should see that the RGB level adjustments are only available when a VGA input is used. I don't believe anyone has uncovered any hidden service menu type adjustments yet.
fcg_vi is offline
Old 05-23-2002, 06:27 PM
Nthusiast's Avatar
to get to the service menu go to the OSD and hold down the select button for about 3 seconds, there are other threads explaining the options you'll find there though. Good Luck.
Nthusiast is offline
