Lamp Shopping HC4900 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 08-22-2012, 07:09 PM - Thread Starter
Greg T's Avatar
I know this has been covered a lot, are any of the sites claiming to have an OEM bulb with generic housing really legit?
I have a Mitsubishi HC4900 that has a bad bulb, so I bought a Lamp and housing off of Amazon from Bulb Word (which claimed to be OEM). It came and the bulb said, made in Taiwan, so I sent it back. I'm planning on putting the HC4900 on ebay, and could not live with myself if I gave someone a bulb that only lasted 200 hours. It's not worth my return on investment to get the OEM bulb. Do any of these sites provide a true OEM bulb?
Lampedia.com
discount-merchant.com
As far as I can tell, the OEM bulb was USHIO.
Greg T is offline
post #2 of 2 Old 08-23-2012, 05:41 PM - Thread Starter
Greg T's Avatar
Or I think the OEM bulb might be NSH. Has no one had experience with a true OEM bulb in a generic housing?
Greg T is offline
