Wanting 720p Center (maybe slightly left) Shelf Mounted for HDTV - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 08-23-2012, 06:57 AM - Thread Starter
tigerfan33's Avatar
Quoted: 350 Post(s)
Liked: 168
Using HP 106" screen and wanting for HDTV. I have the JVC RS45 mounted center shelf and want to shelf mount a720p projector next to it. I'm shooting from 11'-12'. Looking around the 1-1.2k range. Anything out there for me?
tigerfan33 is online now
post #2 of 6 Old 08-24-2012, 05:31 AM
blee0120's Avatar
Quoted: 430 Post(s)
Liked: 230
With my RS40 and 55, I used an Acer H5360 for only $400 but there are 1080p projectors that are less than $800, like the Acer H6500 and Viewsonic Pro8200
blee0120 is online now
post #3 of 6 Old 08-24-2012, 09:09 AM - Thread Starter
tigerfan33's Avatar
Quoted: 350 Post(s)
Liked: 168
Nice.
Are you using with a HP screen center screen shelf mounted?
Screen size and distance from screen?
BTW. I can shelf mount above the JVC in the center which will put the projector just below the top of screen. Would this be better than just beside the JVC?
post #4 of 6 Old 08-24-2012, 09:19 AM
blee0120's Avatar
Quoted: 430 Post(s)
Liked: 230
Nice.
Yep, my hp screen is 119in and my throw distance is about 13ft. I have a shelf made for a 3 projector set up.
post #5 of 6 Old 08-24-2012, 02:41 PM - Thread Starter
tigerfan33's Avatar
Quoted: 350 Post(s)
Liked: 168
Nice.
How high to the top of the screen are your DLP projectors?
I have my RS45 about 12" above head level to get the most gain.
I figure if I can mount the next projector above my 45 I won't have benefit of any gain but will need a light cannon to make up for it.
post #6 of 6 Old 08-25-2012, 04:30 PM
blee0120's Avatar
Quoted: 430 Post(s)
Liked: 230
my JVC about 2in above my head, W7000 about 14in, and my Acer H5360 is turned upside down about 12in from the ceiling. It works for me
