Any 2D only projectors in $2500 range? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 08-24-2012, 01:37 PM - Thread Starter
ltbbw's Avatar
I am looking for a projector for my dedicated theater in my basement. Light will be completely controlled, and projector will be used for movies and TV (mostly football). The largest screen I have room for is 90 inches.
I don't care about 3D, but have found that all the projectors in that price range also do 3D. I was looking at the VPL-HW30ES. Can anyone recommend a non 3D projector below $3000? Are there any 2D only models available that do just as good 2D as the more expensive 3D models?
Any help is appreciated.
ltbbw is offline
post #2 of 9 Old 08-25-2012, 04:18 AM
rgtaa's Avatar
rgtaa is offline
post #3 of 9 Old 08-26-2012, 05:15 PM - Thread Starter
ltbbw's Avatar
Thanks for the help. Picked up an 8700ub for $1600. Very excited.
ltbbw is offline
post #4 of 9 Old 08-26-2012, 10:59 PM
sksahai's Avatar
Ltbbw, where did you get it from? Looking for the 8700ub also.
All I can find is around 2k for a new one.
sksahai is offline
post #5 of 9 Old 08-27-2012, 06:09 AM
MichaelG's Avatar
Visual Apex sells manufacturer refurbished for that price with full 2 year warranty from Epson
MichaelG is offline
post #6 of 9 Old 08-27-2012, 06:10 AM
blee0120's Avatar
Quoted: 436 Post(s)
Liked: 231
Why was you looking at just non 3D? A RS40 and RS45 could be had for under $2500, much better 2D than the UB8700.
blee0120 is online now
post #7 of 9 Old 08-27-2012, 01:00 PM
strugs's Avatar
I cannot find any sources for RS45 for under $2500. Do you have any suggestions? Thanks.
strugs is offline
post #8 of 9 Old 08-27-2012, 07:31 PM - Thread Starter
ltbbw's Avatar
I did purchase a factory refurb from visual apex. So far my experience with refurbs has been excellent. I have only found the RS40/45 for around $2900. They may be better than the 8700ub, and within my price range, but at $1300 less, I couldn't pass on the epson.
ltbbw is offline
post #9 of 9 Old 08-27-2012, 11:43 PM
blee0120's Avatar
Quoted: 436 Post(s)
Liked: 231
Avs had RS40s for $1800 and 45s for $2100. They were b-stocks. But new 45s can be found for $2450. But the Epson is very good also. Still a win
