$2500 budget! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 08-25-2012, 09:27 AM - Thread Starter
NealAtTheWheel's Avatar
Dedicated home theater used for movies, TV, Sports, and gaming, so lag is a concern, albeit not a HUGE one, still present.
The projector will be approximately 16-17 ft. from the screen, and around 10-15 inches higher than the screen as well in a soffit in the back of the dedicated home theater.
I will be using a 92" Elite Screens Cinewhite screen.
I was initially looking at the Epson 8350, because of the good reviews it got for lag time and picture quality for the price.
Is there a better projector out there that I can get for that price range?
NealAtTheWheel is offline
post #2 of 4 Old 08-26-2012, 03:53 PM - Thread Starter
Basically just wondering if I can get a better projector with low lag times for under 3,000. (I found another $500 I could spend haha!)
I prefer a non DLP projector, as I don't want the rainbow effect.
Screen size is definitely 92 inches, as I just ordered the screen, and it will be projecting from 16 feet out and it will be about 18 inches above the screen.
post #3 of 4 Old 08-26-2012, 04:26 PM
jnabq's Avatar
Liked: 39
jnabq is offline
post #4 of 4 Old 08-26-2012, 05:29 PM
TonyG's Avatar
For your budget and gaming interests, it looks to me like the Panasonic AE7000 is the best fit @ $2550 with a couple pair of 3D glasses under a current promotion.
TonyG is offline
