Decent outdoor projector? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 09-01-2012, 08:40 PM - Thread Starter
Stryker412's Avatar
Liked: 27
I had a thread in the outdoor area but it's rather dead in there. My brother can get me an Epson 710HD for under $500 as an open box at BB. How would this projector fair outdoors? Is 2800 Lumens enough?
Stryker412 is offline
post #2 of 5 Old 09-02-2012, 02:06 AM
jnabq's Avatar
Liked: 39
As with any pj, ambient light is the killer. If you plan on using on a well lit basketball court, prob not. If you plan to use it in the dark, even with a full moon, prob be fine. Art liked it for the price point. http://www.projectorreviews.com/epson/home-cinema-710/index.php
He also reviewed an outdoor screen.
http://www.projectorreviews.com/gemmy/index.php
jnabq is offline
post #3 of 5 Old 09-02-2012, 07:51 AM - Thread Starter
Stryker412's Avatar
Liked: 27
Nope I'll only be using it my backyard with no light at all.
post #4 of 5 Old 09-02-2012, 09:03 PM
jnabq's Avatar
Liked: 39
Sounds like it'll be fine for that, just realize it is only a 720p resolution projector.
jnabq is offline
post #5 of 5 Old 09-03-2012, 05:28 AM
blee0120's Avatar
Quoted: 443 Post(s)
Liked: 236
I use a Optoma GT720 on my 220in outdoor with no problem. But it helps being a short throw projector, meaning more light hit the screen. The 720p resolution has been no problem. Movies and PS3 looks good on it.
blee0120 is offline
