Epson Home Cinema Powerlite 8350 loud fan noise - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 09-13-2012, 12:22 PM - Thread Starter
nfltitan33's Avatar
Hello, just a question about possibly cleaning or replacing the fan inside the projector. The projector is making a strange noise that sounds like the fan bearings are going. Wondering if anyone has cleaned or replaced the fan inside the projector and has any advice. Thanks.
nfltitan33 is offline
post #2 of 2 Old 03-16-2014, 07:02 PM
simonaks's Avatar
Hello, Older post but did you ever fix your fan noise? Mine was making a whine noise and I opened the unit and oiled the fan shaft, It made it a little better but it has started to come back. Id like to replace the fan, which is a nidec ultraflo  U92T12MMB7 - 53 j33, however ive been unable to find the exact model.
simonaks is offline
