Need help Connecting HDMI to Infocus SP7200 - AVS Forum | Home Theater Discussions And Reviews
Old 09-17-2012, 11:16 PM - Thread Starter
scubasteve007's Avatar
I inherited an old sp7200 with a new bulb, a fine projector in its day, and still good enough to use. I have a sony BDP-s185 blu-ray player that runs sound through a harmon kardon avr 146. The receiver only has an HDMI switch and won't process any signals, audio or video, from the hdmi.The blu-ray player only has an hdmi, digital audio, and rca out. No component since it is newer than 2011. I tried to connect the video with an hdmi to M1-DA adapter from monoprice. All I got was a black signal, different from the blue "no signal" screen. The frustrating part is that when I hook my hp laptop up to the Projector using the same adapter and hdmi cable, no problem. Anyone know why this is? I tried to play with the output settings on the blu ray player but so far no luck. My main question is what is the best way to get at least a 720p out of my blu-ray? I am trying to not dump very money into this setup since it is already dated, but at the same time would like to milk it for all she's worth. Has anyone had luck with an older infocus projector and hdmi? thanks
scubasteve007 is offline
Old 09-18-2012, 07:45 AM
Mr.G's Avatar
Quoted: 606 Post(s)
Liked: 311
Have a look here.
http://www.avsforum.com/t/787535/infocus-sp7200
All I Really Need to Know I Learned in Kindergarten Movies
Mr.G is offline
Old 04-10-2013, 10:59 AM
HiFiChris1234's Avatar
scubasteve,
Were you able to resolve your issue? I am in a similar situation with the same SP7200. I have been using the component video inputs up until now. But I thought I would try to use the M1-DA input from an HDMI source to get a better quality signal. As of yet I have been unable to get it to work. I don't get any picture or sync at all when I connect a DVD player, it just cycles through the auto scanning. But when I connect a PC, it works perfectly.
I am using an HDMI to DVI-D cable and then a DVI-D to M1-DA adapter.
I just found out that InFocus sells a specific M1-DA adapter for their projectors and they claim that aftermarket adapters won't work. So I have ordered one to try.
Reading through the other threads, it looks like it could be related to HDCP problems on the main board of the projector, but since the projector is out of support now, there really is no way to verify that, nor get a replacement board.
Have you had any luck?
HiFiChris1234 is offline
Old 12-15-2014, 06:40 PM
lkosova's Avatar
I hope you solved your issue but if not let me know.
I just plugged my old 7200 back in and it has a hdmi to md 1 adapter. It is an old version and works fine hooking up ps4. Actually it looks great! I was told if you use a newer hdmi to dvi they will not work.
My problem is when hooking up TiVo mini, I can see the menu...very detailed...but when I go to press to watch something it says I can not use a hdmi connection due to hdcp rules or something like that so will use component and try that out.
For a older projector , in my isolated dark theater, the pic still looks great even with Netflix. This should hold me till 4k becomes affordable......plus all those nicer older1080p projector's should be going on sale now....ha
Larry
lkosova is offline
Old 12-16-2014, 06:26 AM
paris401's Avatar
Originally Posted by lkosova View Post
For a older projector , in my isolated dark theater, the pic still looks great even with Netflix. This should hold me till 4k becomes affordable......plus all those nicer older1080p projector's should be going on sale now....ha Larry
affordable?? bought a mits 7900...800bucks delivered to my door.. replaced a 7205... how much cheaper can it get then 800 bucks, for a picture way better...
ps..weren't u selling screens at one point?? I seem to recall buying a screen research from ya??
paris401 is offline
