Problem with projection - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 09-18-2012, 12:09 AM - Thread Starter
xdominguez's Avatar
Hello,
I am new here and I am not sure this is the correct forum to write this.
We have installed a Mitsubishi xl7000u in our office for a rear projection display window and, thruth be told, we have bought the cheapest vinyl in the market, one that is not even prepared for projections... And the obvious result is that the image can't be seen on plain daylight except when you are looking directly in front of the hot spot.
So, I am trying to improve the quality of the image and I have read about two ways of doing it, but I'd like some proof that this could work: illuminating the window to give extra light to the screen, with which the image should be seen better. The other way is some kind of black veil to absorb the ambient light, but I am not sure how this could actually work.
I know the best solution is to buy a better vinil but it is pretty unlikely right now, this is why I am asking for these cheaper solutions.
Thank you.
xdominguez is offline
post #2 of 10 Old 09-20-2012, 08:54 AM - Thread Starter
xdominguez's Avatar
post #3 of 10 Old 09-20-2012, 05:35 PM
jnabq's Avatar
Liked: 39
Might give AVS a call here and see if they have any insight/options you can explore.
jnabq is offline
post #4 of 10 Old 09-21-2012, 12:21 AM - Thread Starter
xdominguez's Avatar
Well that would be much appreciated.
post #5 of 10 Old 09-25-2012, 05:58 AM - Thread Starter
xdominguez's Avatar
post #6 of 10 Old 09-25-2012, 11:57 PM - Thread Starter
xdominguez's Avatar
So no one knows about what I've said?
I am from Spain so a call to AVS is just not option for me, unfortunately.
post #7 of 10 Old 09-26-2012, 06:13 AM
jnabq's Avatar
Liked: 39
Can you post a picture of the "image/vinyl" your trying to improve?
jnabq is offline
post #8 of 10 Old 09-27-2012, 03:15 AM - Thread Starter
xdominguez's Avatar
There you have them. I have pictured the two most critical.
post #9 of 10 Old 09-29-2012, 08:36 PM
jnabq's Avatar
Liked: 39
I don't think you'll be able to do much to improve the image in that situation, without investing in a better screen. I think Screen Innovations makes a product that would help, but you can send AVS an email, or pm and direct them to this thread to see the images you posted, and if they can offer any suggestions.
jnabq is offline
post #10 of 10 Old 10-01-2012, 12:31 AM - Thread Starter
xdominguez's Avatar
Thank you for the advice. I will probably contact with them via mail.
