Epson 8350 - Easy fix? Red and Green line on the Test Pattern? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 09-22-2012, 04:30 PM - Thread Starter
bleumax's Avatar
I just mounted my 8350 and the picture is fuzzy with a green outline around objects. When I view the Test Pattern, the pattern has a double line, one green and one red. I'm assuming that this is related to my fuzzy picture. Is there an easy fix? Is this the dreaded convergence issue that the 8350 is prone to? Thanks.
I'm a total newbie to projectors, so please forgive my ignorance. I'm also trying to use the search function, but so far, no luck.
bleumax is offline
post #2 of 8 Old 09-22-2012, 08:20 PM
Ranger's Avatar
wow. I've never seen a convergence that bad. This problem cannot be fixed. You need to return to Epson to get an exchange.
Ranger is offline
post #3 of 8 Old 09-23-2012, 12:42 PM
shiseido's Avatar
wow, ive had 2 epson changed but non was like that, you have an awfull convergence problem, return it for an exchange!
shiseido is offline
post #4 of 8 Old 09-23-2012, 03:56 PM - Thread Starter
bleumax's Avatar
Thanks for the replies. I emailed them yesterday and they indicated that I'll likely need to exchange the projector after talking to their diagnostics group.
bleumax is offline
post #5 of 8 Old 09-23-2012, 04:21 PM
gregzoll's Avatar
Liked: 33
Post a after, after you get the new projector.
gregzoll is offline
post #6 of 8 Old 09-24-2012, 08:15 PM - Thread Starter
bleumax's Avatar
New projector should be here Thursday. Fairly painless process thus far. Fingers crossed.
bleumax is offline
post #7 of 8 Old 09-27-2012, 10:03 PM - Thread Starter
bleumax's Avatar
I received the replacement today. It's like night and day. So far, so good. No double lines and the pattern lines are white, not red and green.
bleumax is offline
post #8 of 8 Old 10-02-2012, 07:24 AM - Thread Starter
bleumax's Avatar
Last night the projector prompted an Auto Iris Error. I guess this one is going back. frown.gif
bleumax is offline
