Need help with throw distance for Optoma HD33 - Am I stuck at 12'7" ? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 09-29-2012, 11:28 PM - Thread Starter
jonathanc's Avatar
Liked: 48
Hello,
I am slightly confused on throw distance and what I can and cannot do as far as measurements. The projector placement calculators recommend a throw distance of 12'7"
Problem is I can't mount the projector right at that distance, I can mount at roughly 13'6" or around 11 feet. OR, I can go off center by about 1 foot.
My room measurements are 16x11' , with a ceiling height of 7'6"
Screen size is 106" fixed at the wall.
Also, the calculator says the center of the lens must be 8.3" above the top of the screen. I am using http://www.projectorcentral.com/Optoma-HD33-projection-calculator-pro.htm for the measurements.
So, is it possible for me to move the projector back slightly ? I don't have the projector mounted yet as I am waiting for some parts to arrive first.
jonathanc is offline
post #2 of 4 Old 09-29-2012, 11:36 PM
Jim McC's Avatar
Quoted: 181 Post(s)
Liked: 64
Where it says 12-7" is the mid point of the throw range. For a 106" diagonal screen, the HD33 would need to be mounted between 11'-6" and 13'-10" from screen.
Jim McC is offline
post #3 of 4 Old 09-30-2012, 08:48 AM - Thread Starter
jonathanc's Avatar
Liked: 48
Thanks. The far end of that range will work fine. What about the 8.6" measurement from the top of the screen. Can I go lower than that ? What is optimal ?
post #4 of 4 Old 10-01-2012, 12:37 PM
jnabq's Avatar
Liked: 39
Looks like within that throw range, and the limited zoom, you can place it, 7.6in to 9.1in above the screen.
jnabq is offline
