Should I get a projector? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 10-01-2012, 06:17 PM - Thread Starter
bradleyedward's Avatar
I have a 50" Panasonic Plasma, love it to death but I want a bigger screen. So, two things.
1) Should I even get one? My room is dim and I have a good 15-20 feet for throw distance.
2) If so, which one? The two I've been looking at are the Optoma HD23 and the Epson 8350. My budget is around $750-$1000.
Thanks in advance!
bradleyedward is offline
post #2 of 9 Old 10-02-2012, 06:54 PM
Wolverine2021's Avatar
Thanks in advance!
Wow I am this exact same situation. 50' Panny Plasma G10 but want a bigger screen and the same room conditions.
Not to hijack this thread but i would love to hear some suggestions on a projector in the same under $1000 range that would be used for gaming.
Thanks guys
Wolverine2021 is offline
post #3 of 9 Old 10-02-2012, 07:39 PM
Jim McC's Avatar
Quoted: 115 Post(s)
Liked: 58
Thanks in advance!
I think both of those are more than $1,000.
Jim McC is offline
post #4 of 9 Old 10-02-2012, 10:33 PM - Thread Starter
The Optoma is $999 (famed for the 1080p projector < $1,000), and the Epson ranges between $1,100-$1,300.
post #5 of 9 Old 10-03-2012, 08:39 AM
josh33007's Avatar
I am thinking about getting an optoma gt750e mostly for 3d gaming. I wanted a projector for under 1 grand too. The major downfall is not having 1080p. I have no experience with projectors tho. Have you looked into that?
josh33007 is offline
post #6 of 9 Old 10-03-2012, 02:47 PM
Frosteh's Avatar
Always get projectors!!!!
Anyway, a couple of things to take note. Your black levels will be better on the Panny unless you spring for a good Epson or JVC. You can find used ones from both manufactureres in your price range. Look up the JVC RS1, RS2 and HD100, and Epson 6500UB, 8500UB on Videogon. There's a couple up there for <$1000 with new bulbs. Sharpness will be better on the plasma unless you get a good DLP like BenQ's.
What size screen do you want? You haven't really given us enough information to recommend a projector. Projectors suffer greatly from ambient light where TV's don't. The fact that your room is dim helps, but if you can get it completely black that would be ideal.
Bottom line, yes you should get a projector. They are exponentially more immersive and awing than little TV's.
Frosteh is offline
post #7 of 9 Old 10-03-2012, 07:30 PM - Thread Starter
Screen size I'm looking for is between 130-150". The Optoma HD23 attracts me because of the brightness level. I'd like to be able to watch things without completely darkening the room, with normal levels of ambient light. Thanks for the reply!
post #8 of 9 Old 10-10-2012, 05:27 AM
EJ
EJ's Avatar
I bought an epson 6500ub refurbished from Visual Apex (site sponsor) for $995 back in January. With the epson units, I'd definitely go for a "ub" model. Here's a snapshot of what they're currently offering.
Former USSB uplink operator.
EJ is offline
post #9 of 9 Old 10-10-2012, 08:19 AM
mikeman117's Avatar
You are posting in a projectors specific forum. Obviously we are all going to say yes.. seriously..
mikeman117 is offline
