Anyone seen this problem before(Epson 8100 HC)? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 10-03-2012, 07:30 PM - Thread Starter
jbushore's Avatar
Hello, I am having a problem with my Epson 8100 HC projector. Would love any advice you may have! Here is what is happening:
Turn on the projector, A/V receiver, and video source. Works fine for 2-3 minutes. Picture looks good. After a few minutes, the screen goes black, the fan on the projector kicks on high, and the the lamp light blinks red. We can then turn it off, then back on, and repeat the above.
I ordered a replacement bulb on Amazon from a vendor who had good reviews on the product(Prolitex). Installed it(reset the counter) and it worked fine for 45 hours. After 45 hours, the unit went began showing the same symptoms as before(above). I can even put the original lamp back in and it will work for a few minutes then go out.
I am currently getting a refund on the lamp, but have also talked to Epson who of course said that I should be using a bulb I ordered from them smile.gif But he did think it was unusual that the lamp works at all, and that it could suggest a problem with the ballast(?). I don't want to put a new lamp in if I have another problem that could ruin the lamp. Anyone experienced this? Should I get the ballast tested? Thanks!
Details: Projector is ceiling mounted in well ventilated, climate controlled media room. I have not replaced the filter, but cleaned it by vacuum(not washed it though). I tried running it without the filter at all with same result. Original bulb had 1450 hours on it. Never tried ECO mode until this new lamp.
jbushore is offline
post #2 of 3 Old 10-04-2012, 07:02 PM - Thread Starter
jbushore's Avatar
bumpity bump - could really use some input - thanks!
jbushore is offline
post #3 of 3 Old 10-04-2012, 07:21 PM
rekbones's Avatar
Quoted: 503 Post(s)
Liked: 256
I think its a defective bulb. Never buy a non oem bulb, you dont have to get it from epson but make sure it has an epson serial # and an epson warrenty not a aknock off warrenty.
"Smart enough to know better, to old to care" ------ Dedicated Home Theater, Mitsubishi HC7900DW Projector, 110" 16:9 Jamestown screen with variable power masking for CIW 2.50:1 to 16:9, Marantz 7009 with 7.1.4 Atmos with Ohm mains,3 DIY Subs (2 15" (1 ported, 1 sealed and a 12" 4th order bandpass), 1 DIY butt kicker, Custom Built HTPC, 10TB DroboFS NAS
rekbones is offline
