Need help with short throw projectors - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 10-04-2012, 04:51 PM - Thread Starter
ramapula's Avatar
my media room is around 15' X 17'.4"
I wanted to install a projector screen of 150" diagnally.When i checked online the projection minimal distance for that resolution is 20`.If anyone knows a projector that can do a short throw without any reduction in resolution.Please let me know.
ramapula is offline
post #2 of 3 Old 10-05-2012, 02:14 AM
jnabq's Avatar
Liked: 39
Which projector, and which calculator where you using? That doesn't sound quite right? Reduced resolution shouldn't be a factor, but depending on the pj it may be difficult to fill a large screen, if it has to be placed to close in that space limitation.
jnabq is offline
post #3 of 3 Old 10-07-2012, 04:52 PM
jrwhite's Avatar
The current crop of Epson's can do 150" from about 15' of throw.
Jonathan
jrwhite is offline
