Help. JVC DLA-RS1 or $1,000? - AVS Forum | Home Theater Discussions And Reviews
Old 10-04-2012, 09:54 PM - Thread Starter
sunpole's Avatar
Hello,
I'm in the process of buying a home that has a media room and comes with a projector JVC DLA-RS1. The problem is seller just found out it doesn't work anymore and he couldn't figure out why.,.
So he is willing to either fix it for ~$500 with manufacture but takes 5 days (that's what he told me) or compensate me $1,000 to avoid delay closing and leave the broken projector with me.
He claimed his home theater is worth $7,000 (I don't believe it)... But without much knowledge of professional projector, I wonder is this particular model worth $1,000 in today's technology? Or am I better off just spending $1,000 buy a new projector?
Thank you very much.
sunpole is offline
Old 10-05-2012, 01:31 AM
jnabq's Avatar
Liked: 39
In 2007, msrp $6295, now used on ebay about $1300. I'd take the $1000 toward a new pj, and see if I couldn't get it fixed myself, for a cheaper price. Who knows, with a little research you might find it's just the bulb needing replacement?
jnabq is offline
Old 10-05-2012, 02:42 AM
coderguy's Avatar
Quoted: 364 Post(s)
Liked: 300
Take the $1000 absolutely. It's unlikely the projector can be fixed for a cheaper price. It's also not smart to dump money in such an old PJ that's already broken down once.
You can get JVC HD-250 B-Stock projectors here at AVS sometimes for just a bit more than that.
Otherwise you can get an Epson 8700ub refurb or 8500ub refurb for even cheaper from certain Internet stores or the Epson store sometimes.
There is no way I'd pay to have a projector fixed in general (usually it's far more than the PJ is worth), but even if it's something simple it's not worth it because LCOS panels degrade naturally (especially one from that old).
Access HERE from this thread
coderguy is online now
Old 10-05-2012, 06:58 AM - Thread Starter
sunpole's Avatar
Okay, that was my hunch too.
Taking $1,000 and see if there is a cheap fix...
Thanks to both of you.
sunpole is offline
Jvc Dla Rs1 Projector
