Official Epson Home Cinema 3020 Thread - Page 41 - AVS Forum | Home Theater Discussions And Reviews
 7Likes
post #1201 of 1211 Old 01-02-2017, 08:17 AM
hiperco's Avatar
Originally Posted by exm View Post
I sold my 3020 projector. Received a message that there's a pink/red bar on top. Lamp is a genuine Epson lamp with 4,000+ hours. Would a new lamp solve this, or is there another issue?
It's probably not the lamp. Bad LCD panel is more likely
hiperco is offline
post #1202 of 1211 Old 01-02-2017, 11:47 AM
exm
exm's Avatar
Quoted: 129 Post(s)
Liked: 82
Appreciate the reply. I sold the projector on eBay clearly stating the problem.... Am now the proud owner of a 6040 [just realized that 6040 is double 3020, HA!]
exm is offline
post #1203 of 1211 Old 02-10-2017, 08:04 PM
Jefferson Morris's Avatar
Hey, guys--could use some advice.
I just tried to replace the lamp in my 3020. The old lamp came out fine, but the new one (a $125 knockoff--yeah, I know, probably not a good idea) does not light up. The fan runs for a while and then the red temperature warning light comes on after a while. No image thrown.
s
But the real trouble is that I can't get the non-functioning bulb out now. It's stuck good, and it's definitely not because of the attachment screws. Something that appears to be on the left side of the bulb is keeping it in there and I'm leery of putting too much force on it. And I'm not too keen to disassemble the thing, since I don't know what I'm doing.
Anyone experience something like this? Is sending it to a repair center my only viable option?
--Jeff
Jefferson Morris is offline
post #1204 of 1211 Old 02-11-2017, 06:37 AM
hiperco's Avatar
Pull harder. If it went it, it will come out.
hiperco is offline
post #1205 of 1211 Old 02-12-2017, 07:29 AM
exm
exm's Avatar
Quoted: 129 Post(s)
Liked: 82
s
--Jeff
My 2 cents: if you buy a knockoff don't spend $125. You might as well get a genuine bulb. Most knockoffs can be found for $50 or less.
As far as your problem is concerned, it might have overheated and maybe something melted inside. The repair center route isn't worth it - keep on trying, and a little bit of force won't break the projector. Worse case is that you'll break the bulb or bulb housing [disclaimer: not professional advise ]
exm is offline
post #1206 of 1211 Old 02-14-2017, 08:15 PM
Thanks, guys. Forcing it worked! At least I can put the old bulb back in and still get some use out of it while I wait for a proper replacement.
So that leads me to another question--where's a good place to order bulbs for this thing? When I search on the bulb part number (V12H010L68) I see such a wide disparity in prices from different sellers. I'm certainly leery after the experience I just had--the bulb just didn't quite fit, and that's what caused me all the problems.
post #1207 of 1211 Old 02-14-2017, 08:24 PM
exm
exm's Avatar
Quoted: 129 Post(s)
Liked: 82
How many hours do you use your projector on average?
exm is offline
post #1208 of 1211 Old 02-20-2017, 12:31 PM
Sorry for the late reply--I use it maybe 25 hours per week.
post #1209 of 1211 Old 02-21-2017, 08:40 AM
Mr.G's Avatar
Quoted: 609 Post(s)
Liked: 317
If you go to the Epson website you will see that the replacement lamp for the Epson 3020 is a different number (V13H010L68) - this is usually listed as the replacement for the 3010/3010e.
https://epson.com/For-Home/Projector...r/p/V11H501020
If you click on Accessories, Lamps - it will list ELPLP68 as the Replacement Projector Lamp / Bulb. $299.
Assuming this is the correct OEM lamp you can find it discounted on the Provantage website for $232.
Provantage is a respected site used often by AVS Forum members and a company I've used several times over the years.
http://www.provantage.com/epson-v13h010l68~7EPS90VC.htm
All I Really Need to Know I Learned in Kindergarten Movies
Mr.G is offline
post #1210 of 1211 Old 02-22-2017, 07:18 PM
exm
exm's Avatar
Quoted: 129 Post(s)
Liked: 82
That's about 1,300 hours a year, so a bulb will last about 3 years. A new OEM bulb can be had for $240 (see above), so that's $80 a year. I think that's worth it IMHO.
exm is offline
post #1211 of 1211 Old Today, 06:58 PM
Liked: 0
Hi all,
I'm new to AVS and be glad to do my first post here.
I bought my 3020 light bulb from projectorlamps.com back in September 2015 for $200 including tax and shipping cost. It is still young (~700hr) and is doing OK. Hope this helps.
cewu2007 is online now
Epson , Epson Projector , Epson V11h501020 Powerlite Home Cinema 3020 2d And 3d Home Theater Projector , Epson V11h502020 Powerlite Home Cinema 3020e 2d And 3d 1080p Wireless Home Theater Projector
