Can someone recommend a neutral detergent/cleaner for my projector? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 10-14-2012, 09:39 PM - Thread Starter
BestInTheWorld's Avatar
The outer casing seems to be plastic and it's white and grey. I haven't used the projector in over a month, due to work, but it's been collecting dust on the top (not so much on the sides or on the vents)
The manual states to wipe with a dry cloth, but I see some hair and other stuff on the projector so I want to actually clean it. It also states to use a neutral detergent and I don't know of any products that are neutral that also cleans.
If someone can recommend 1 or more that would be awesome, so again thanks AVSForums! smile.gif
BestInTheWorld is offline
post #2 of 2 Old 10-15-2012, 05:25 AM
jnabq's Avatar
Liked: 39
I'd use a vacuum to get the larger debris, then just a damp cloth. If you need, might add a tiny bit of dish soap to the water. No alcohol products because of possible fire danger.
jnabq is offline
