Optoma GT750 Input Searching with PS3 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 34 Old 10-15-2012, 10:04 AM - Thread Starter
fstanek's Avatar
Quoted: 23 Post(s)
I'm wondering if it is possible to disable the Optoma 750 from constantly searching for input. Each time I put in a game, movie, or start an app like Hulu or Crunchyroll on my PS3, the Optoma searches for a HDMI signal for like 5 seconds. When playing a movie, this can happen a few times, such as when switching between the previews and also the main movie menu.
I disabled all of the inputs on the setup, so that only the HDMI input is enabled, yet this hasn't solved the issue.
Also, and this has happened probably a couple times in the past week, when I put in a 3D movie, the projector just displays a black screen. My default (no input) screen is blue, so the black screen indicates that the projector is receiving input, yet nothing appears on the screen. If I turn off the projector and turn it back on, it re-syncs the HDMI and the image appears, so it is most likely a projector issue. Is this something that others are experiencing (and a known issue) or is my projector is messed up?
fstanek is offline
post #2 of 34 Old 10-15-2012, 03:26 PM
jasoraso's Avatar
i believe this is an issue with the ps3. I get this same switching on my ps3 when switching from games, movies, and other video sources like Netflix or youtube.
I haven't seen it within a movie though (previews etc.)
Sent from my Nexus 7 using Tapatalk 2
jasoraso is offline
post #3 of 34 Old 10-15-2012, 03:28 PM
jasoraso's Avatar
i just reread your post, and it sounds like when the ps3 is switching modes, which is normal (like mine), your projector is going into an auto input mode. You said you had already turned off several of the inputs, i wonder if there is also a setting for auto input?
jasoraso is offline
post #4 of 34 Old 10-15-2012, 04:11 PM - Thread Starter
fstanek's Avatar
Quoted: 23 Post(s)
When I get home, I'll see if its possible to force the PS3 to always output in 720p. Maybe if there's a setting like that, it can prevent the signal interruption. Thanks.
fstanek is offline
post #5 of 34 Old 01-20-2013, 01:12 AM
nyc3dwd60738's Avatar
I need helo.igot the optoma gt750 work great but the bigest problem is doesnt recognise ps3at all.it stays in searching for sorces.should i return it .i bought in best buy with 2year extended warranty a month a go
nyc3dwd60738 is offline
post #6 of 34 Old 01-20-2013, 10:09 PM
Sonyad's Avatar
Quoted: 177 Post(s)
Liked: 103
You have several tests to do. Connect the ps3 to all ports to see if a certain port is not working. Try a different cable to see if that's the problem. Attach something else other than the PS3 to make sure that it is not defective.
Sonyad is offline
post #7 of 34 Old 01-21-2013, 01:55 AM
I did try all of that only ps3 its not recognized,even other sources are not founded when ps3 is conected.when I unplag the ps3 fa other sources get conected right away ,like dirctv.ps3 works in my other tv with th,e same hdmi.very wierd.so hdmi tested ok ,the pj tested with other sources ok,ps3 fail.zero conection
post #8 of 34 Old 01-21-2013, 10:38 PM
Updati exchanged the pj got a new one (bought the optoma a month ago so best buy didnt give me hard time to exchange.now the ps3 works but only if a set the resolution to 720p, if i try to ad 1080p the pj goes blank and gets stuck in serching for sources .if i switch back to 720p than it connects .but in 720 p the ps3 doest let you watch any 3d movie or game .this is such a nightmare .dont know what to do this pj its suppose to gaming pj but have problem with ps 3.maybe i should return it and get some other pj...ahhhhh
post #9 of 34 Old 01-21-2013, 10:40 PM
Sorry for writing errors i type from my cellphone from work
post #10 of 34 Old 01-22-2013, 01:27 AM
rosesawin's Avatar
i think so,very wierd.so hdmi tested ok ,the pj tested with other sources ok,ps3 fail.zero conection, thank you 1.gif
rosesawin is offline
post #11 of 34 Old 01-22-2013, 11:15 AM
Sonyad's Avatar
Quoted: 177 Post(s)
Liked: 103
Searching through the web, many people are using this setup. Must be something in the setup either on the optoma or the ps3 that in conflict. Are you using 720p/60 on the Optoma?
Sonyad is offline
post #12 of 34 Old 01-22-2013, 07:08 PM
In optoma ? I dont know you can change resolution in optroma?you mean 720 in ps3?
post #13 of 34 Old 01-22-2013, 07:21 PM
Sonyad's Avatar
Quoted: 177 Post(s)
Liked: 103
Try it on the PS3. I may have to set up my Optoma and steal my son's ps3 to test this out.
Sonyad is offline
post #14 of 34 Old 01-22-2013, 09:45 PM
Sonyad's Avatar
Quoted: 177 Post(s)
Liked: 103
Here's the update. Setup my tripod projector screen, positioned my optoma then attached the ps3. Turned it on and put in my Avatar 3D blu-ray disk. I didn't touch the settings on either machine. The optoma found the ps3. Started up the movie, put on my glasses and I currently have it playing in 3d just fine. It noted that the Optoma recognized the source as 1080p/60.
Sonyad is offline
post #15 of 34 Old 01-22-2013, 11:20 PM
Then i guess than my optoma has problems, if i connect ps3 to 720 ,or i 1080i it gets connected but if i make it 1080p than no conection my pj goes blank.unbelievable.its brand new drives me crazy.im calling optoma tomorow its just dont really wanna shio to them so they can fix it....
post #16 of 34 Old 01-22-2013, 11:24 PM
Anyway i appreciate you helping man, its good to see somebody still visits this thred
post #17 of 34 Old 01-23-2013, 08:51 AM
Sonyad's Avatar
Quoted: 177 Post(s)
Liked: 103
If you already exchanged the optoma once, it seems something else is awry. Are you using a high speed hdmi cable? Can you reset the PS3 to it's default settings? What PS3 are you using? The PS3 I was using is a new model purchased in December. I can't verify what resolution it was set for since I've never used it before.
Sonyad is offline
post #18 of 34 Old 01-23-2013, 12:09 PM
man4mopar's Avatar
Does it accept 2D 1080P signals?
Do you have your PS3 going through a receiver or anything else between it and projector?
man4mopar is offline
post #19 of 34 Old 01-23-2013, 12:21 PM
No i does not accept 2d i tryrd both ways ,noyhin,butii take the ps3 to the tv change resolution 1080i i go and connect it to optoma and bum it works .the ps3 its recognized in 1080i end 720p but you cant play or watch any 3d movieor game.and tbats why i bought this pj to play 3d games and watch 3d movies
post #20 of 34 Old 01-23-2013, 12:25 PM
I have all high speed hdmi wich they work good with directv and sony bluray 3d player or my 3d setup pc....and the ps3 is the old fat model...wich its upgraded to all new firmwares and plays good on my tv....
post #21 of 34 Old 01-23-2013, 12:26 PM
I did reset the ps3 ....nothing happen
post #22 of 34 Old 01-23-2013, 01:29 PM
Sonyad's Avatar
Quoted: 177 Post(s)
Liked: 103
Can you play a 3d movie with your Sony 3d blu-ray player connected to the Optoma? If so, the projector is not at fault, it's the older ps3 fat model you have.
Sonyad is offline
post #23 of 34 Old 01-23-2013, 02:53 PM
Yes i can play 3d on bluray also in directv but not on ps3....
post #24 of 34 Old 01-23-2013, 02:53 PM
post #25 of 34 Old 01-24-2013, 02:41 AM
Update:up to now i had the optoma conected to ps3 with 25 feet high speed hdmi.i did a test with a short 10 feet 1.3 hdmi and bum it connected.so now i thinkps3 cant hold yhr resolution on long length hdmis.it cant be my 25 feet high speed 1.4 with ethernet hdmi becouse other sources are connected ok can watch 3d in 1080 p.....
post #26 of 34 Old 01-24-2013, 02:44 AM
So for me to enjoy playing 3d on ps3 i have to go with short hdmi wich is not possible becouse i have the pj mounted in 12 feet ceiling plus i need the ps3 to be by my screen becouse on ps eye camera etc connections...ahhh any idea?
post #27 of 34 Old 01-24-2013, 08:28 AM
Sonyad's Avatar
Quoted: 177 Post(s)
Liked: 103
I've heard folks mention some kind of signal booster or amplifier on a long hdmi run.
Sonyad is offline
post #28 of 34 Old 01-24-2013, 10:31 PM
That or im thinking of ordering blue jeans hdmi 25 feet certified high speed cable its 87$ not cheap but still cheapet than others like monster.....
post #29 of 34 Old 01-25-2013, 10:23 AM
Sonyad's Avatar
Quoted: 177 Post(s)
Liked: 103
Why not try Monoprice for a better price on that cable.
Sonyad is offline
post #30 of 34 Old 01-26-2013, 02:27 AM
You right but dont want to risk with monoprace at least im sure blu jeans hdmi gonna be good one...well see.....im orfdering bluejeans.....
Optoma Gt750 Projector
