projector screen help! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 10-21-2012, 08:59 PM - Thread Starter
johnybass's Avatar
Okay, i'm gonna be picking up either a Vivitek D951HD 1080p or a Vivitek H1080FD 1080p. They are both 1080p and will be used in a dedicated theater room with white walls but no lighting when watching video. I need a big cheap fixed screen, and a 5.1 receiver for about $300 that has airplay or something similar and can output all the inputs to a single hdmi that will feed the projector. I also need a cheap ceiling mount for the projector. I'll be hooking these up to 5 dayton audio ceiling speakers and a subwoofer. I know there are lots of options and choices and no "best for any situation" but i'm just trying to narrow it down to a few options really quickly while i have the money. Help would be super appreciated! Thanks
johnybass is offline
post #2 of 3 Old 10-21-2012, 09:28 PM
diat150's Avatar
check out the denon avr 1912 at accessories for less.
cheap screen you can look at the favi or elite screens on amazon.
diat150 is offline
post #3 of 3 Old 10-23-2012, 08:54 PM - Thread Starter
johnybass's Avatar
Does this have wifi or just wired Ethernet?
