Which is the BEST 2D PROJECTOR ?? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 10-22-2012, 09:25 AM - Thread Starter
mirage1000's Avatar
Which one do you think is the BEST 2D PROJECTOR - ANY TECHNOLOGY (DLP AND LCD)?
mirage1000 is offline
post #2 of 6 Old 10-22-2012, 02:37 PM
soupdragon's Avatar
Quoted: 12 Post(s)
Liked: 36
There is no such thing as a best projector. All depends on what you will be using it for, screen size you want and what the room conditions are like. This makes buying the right one a bit of a headache as its difficult to know which one will be best for you! biggrin.gif
soupdragon is offline
post #3 of 6 Old 10-22-2012, 02:56 PM
rgtaa's Avatar
I agree, you have to give more info , bro. Best 2 D for gaming, tv shows, blu ray, computer use, in batcave, or in room with lights on, with big screen.
Tell us your room and what you are gonna do with your PJ, what you will watch, screen size, room size, how dark is the room. Because some would be good for batcave but not for living room, and some would be good for blu ray but not as good for gaming.
Now, you could go to projectorreviews.com and look over their 2012, or 2011 yearly round up, and he does give best 2d, and best in 3d, and best PJ that does 3d/2d both good , etc ... maybe start there and figure out what exactly you would be doing with your PJ.
Also, some PJ'a are geared towards portable use with built in speakers and tons of inputs/outputs and some are just for ceiling mount and to be used in batcave only. Do you see why the other guy said hard to say what the best 2d model is? Without saying how you would use the PJ, can't really say, because it might not be best for you. biggrin.gif
rgtaa is offline
post #4 of 6 Old 10-22-2012, 06:49 PM - Thread Starter
mirage1000's Avatar
100% movies ; shelf mounted : 120 inch screen; living room with decent blinds ; NOT A BAT CAVE ;
post #5 of 6 Old 10-22-2012, 06:57 PM
Duke Broadway's Avatar
pt-ar100u
Duke Broadway is offline
post #6 of 6 Old 10-26-2012, 10:33 AM
iolmaster's Avatar
Hard to beat the 100u under those conditions.
iolmaster is offline
