BenQ W1070 : DLP Full HD, 3D Ready with lens-shift for 1000$ - Page 199 - AVS Forum | Home Theater Discussions And Reviews
 390Likes
post #5941 of 11931 Old 08-14-2013, 03:50 AM
theskins44's Avatar
Quoted: 26 Post(s)
Originally Posted by hotjt133 View Post
The ultra light looks exactly the same as sainsonic. Do you have sainsonic to compare?
no I don't,but have read the sainsonics do a poor job with red flash,3dtv ultralites do a good job on this.
I think for the price around $20 vs $85 for benq's(not on your list, I know) the 3dtv win hands down
the benq's do a little better job(very little) and are little more comfortable over a 2hr plus sitting (my eyes get a bit sore during some long 3d movies,less so with benq's) . IMO
Greatest hobby ever!
theskins44 is offline
post #5942 of 11931 Old 08-14-2013, 04:16 AM
kbarnes701's Avatar
Quoted: 6740 Post(s)
Liked: 5069
I have the Sainsonics and find them fantastic. No problems at all. I wonder if there are different 'varieties' of Sainsonics. These are the ones I have:
http://www.amazon.co.uk/gp/product/B0081JPABQ/ref=oh_details_o02_s00_i00?ie=UTF8&psc=1
kbarnes701 is offline
post #5943 of 11931 Old 08-14-2013, 08:11 AM
rwestley's Avatar
Quoted: 144 Post(s)
Liked: 97
These are the same ones I and others have. The work ok but do not completely block the red flash. I have compared many brands and the 3DTV, 3DActive and Benq's are the best with red flash blocking. If you compare these to the Sansonic glasses you will notice better blacks because of the better red flash blocking. I use the Sansonic for guests since they sync very well but I use the others for myself.
rwestley is offline
post #5944 of 11931 Old 08-14-2013, 08:24 AM
kbarnes701's Avatar
Liked: 5069
Thanks - this is interesting. I have never been a huge fan of 3D ... until I got this PJ. I just bought one pair of the Sainsonics to evaluate the 3D, but I am so impressed now by the 3D that I will probably buy more glasses. Now I know how good the 3D is I am happy to spend more for better quality glasses. Not sure I can get the 3DTV here in the UK but I can probably get the BenQ.
post #5945 of 11931 Old 08-14-2013, 10:20 AM
aohus's Avatar
so after 2nd replacement i have received the perfect benq w1070. the last 2 were suffering from rattling sounds. BenQ's customer service was pretty good with responding to emails. the replacement was manufactured july 2013, and came with 1.06 fw.
aohus is offline
post #5946 of 11931 Old 08-14-2013, 11:06 AM
bighvy76's Avatar
Quoted: 22 Post(s)
Liked: 29
Where do u find the manufacturing date?
bighvy76 is offline
post #5947 of 11931 Old 08-14-2013, 11:36 AM
rwestley's Avatar
Quoted: 144 Post(s)
Liked: 97
The manufacture date and hardware revision is on the box.
rwestley is offline
post #5948 of 11931 Old 08-14-2013, 11:39 AM
rwestley's Avatar
Quoted: 144 Post(s)
Liked: 97
Dimensional Optics will ship their Active 3D DLP glasses to the UK. They are great.
http://www.dimensionaloptics.com/
rwestley is offline
post #5949 of 11931 Old 08-14-2013, 12:11 PM
bighvy76's Avatar
Quoted: 22 Post(s)
Liked: 29
So these work good?
bighvy76 is offline
post #5950 of 11931 Old 08-14-2013, 01:12 PM
utee05's Avatar
Quoted: 30 Post(s)
Originally Posted by pdxrealtor View Post
Here ya go. I got the same mount in the 200 mm length. Youll need to hit the hardware store for shorter screws and some washers but otherwise it works great.
http://www.monoprice.com/products/product.asp?c_id=109&cp_id=10911&cs_id=1091102&p_id=8802&seq=1&format=2
I got that mount. Any clue why you need shorter screws and washers? The ones that come with it seem to fit fine. Do you happen to have a pic of the mount attached to the projector to see if/what I am doing wrong? TIA
utee05 is offline
post #5951 of 11931 Old 08-14-2013, 02:24 PM
rwestley's Avatar
Quoted: 144 Post(s)
Liked: 97
So these work good?
Yes, they work great. My favorite pair
petesvt likes this.
rwestley is offline
post #5952 of 11931 Old 08-14-2013, 02:40 PM
petesvt's Avatar
Quoted: 13 Post(s)
+1
petesvt is offline
post #5953 of 11931 Old 08-14-2013, 02:42 PM
kbarnes701's Avatar
Liked: 5069
That is very kind of you - thanks!
post #5954 of 11931 Old 08-14-2013, 05:34 PM
deez's Avatar
search google for benq w1070 calibration settings. I took mine from here- http://www.projectorreviews.com/benq/w1070/calibration.php and it looks darn good. But what do I know? lol....
I went into color settings but they all start at 50? Theres fine tuning and regular...would I add those numbers to the main or fine tune? Not sure what to do here...also, the black level is not where I was hoping it would be,,,,anyway to fix this or maybe make it better thanks.
XBOX Gamertag:deezusmusic
deez is offline
post #5955 of 11931 Old 08-14-2013, 05:35 PM
deez's Avatar
Im using the Sainsonics from Amazon...there 30.99 a pair and work perfectly.
deez is offline
post #5956 of 11931 Old 08-15-2013, 05:10 AM
rwestley's Avatar
Quoted: 144 Post(s)
Liked: 97
If you compare them to the 3DTv and the Dimensional Optics DLP Active you will see that the Sansonic are not perfect. I have compared 5 or 6 brands and I find the Sansonic to be of lower quality in blocking red flash than at least 3 other brands.
The 3DTV ones below for about $30 each are one of the best and are so much better than the Sansonic glasses.
http://www.amazon.com/3DTV-Corp-DLP-LINK-Projectors-Mitsubishi/dp/B004G2VJM6/ref=sr_1_2?ie=UTF8&qid=1376565102&sr=8-2&keywords=3d+tv+dlp+glasses
The only thing is that they are not rechargeable but that is no a problem for me. In fact, I like it better that way since the standard 2032 batteries are really cheap and easy to replace. I find this much better than having the rechargeable glasses fail during a movie. If you want rechargeable glasses consider the Dimensional Optics ones in a few posts above.
rwestley is offline
post #5957 of 11931 Old 08-15-2013, 05:31 AM
bighvy76's Avatar
Quoted: 22 Post(s)
Liked: 29
The 3dtv ones are not rechargeable the ones from dimensional optics are. If u care one way or the other
bighvy76 is offline
post #5958 of 11931 Old 08-15-2013, 08:20 AM
eah9's Avatar
Liked: 29
I just entered the world of large screen viewing about a week ago smile.gif I received the w1070 and got June 2013 rev 1.04. Only one issue that happened one time - A quick bright flash. Weird but never happened again.
Anyway - Very impressed with the display. Some folks say it's like having a huge LED/LCD display and they are right. It is a fantastic picture - I calibrated using http://www.avforums.com/forums/projectors/1761516-benq-w1070-reviewer-s-recommended-best-settings.html - colors are accurate and black levels are really good. Watching in the basement HT, so it's light controlled. So glad this technology has improved so much and is now affordable. No reason not to go this route. Funny how the 52" monster I moved upstairs seems tiny....all perspective I suppose.
I have the 100" Elite Cinewhite sable screen and it is excellent with this projector IMHO. I couldn't really go much bigger due to the 7'6" ceiling and just over 10' width where the screen is located.
Still have to mount it but my kids keep watching things, so I am having a tough time getting a few hours during the day to do it. Just on a temporary table for now.
Prior to buying this projector I purchased the sony s3100 bdp...so I wasn't thinking of 3D. Guess I will have to move that bdp player upstairs and get an s5100 and some glasses.....biggrin.gif
Appreciate all the experts and helpful info in this thread!
Energy RC70 L/R | RC-LCR Center | C-R3 Surrounds | VMINI Bookshelves Surrounds | S12.3 and Dual S10.3 Subs | KRK 10s Sub | Benq w1070 pj | Elite 100" Sable Screen | SONY STR-DN1030| Sony S5100 and S3100 BDPs
eah9 is offline
post #5959 of 11931 Old 08-15-2013, 05:41 PM
teeger's Avatar
Liked: 33
I think I read somewhere here that some folks have noticed a sound that has a rhythmic sound - kind of like the way crickets sound. I hear it when viewing 3D. This sound just started recently. I suspect it might be the color wheel is starting to squeak in the 3D mode. I only have approx. 50 hrs. on the projector . . . the sound is a bit loud, but I wouldn't complain IF it wasn't a problem that would a) get louder or b) cause the projector to fail. This would really suck if it died just outside of the warranty period.
Is the squeaky sound when viewing 3D an issue?
Ian
teeger is offline
post #5960 of 11931 Old 08-15-2013, 07:00 PM
terminal33's Avatar
Quoted: 107 Post(s)
Liked: 57
Ian
The sound is present for me as well during 3D. It does bother me enough to the point where I think I will exchange mine at BB since I'm still within the return period. Unfortunately they don't have them in stock near my house so I'll have to wait for it to ship to the store. mad.gif
Epson 5040ub
Hsu VTF-15H MK2
Ascend Acoustics 340 & 170
Denon X2300W
Philips UHD player
terminal33 is online now
post #5961 of 11931 Old 08-15-2013, 09:41 PM
deez's Avatar
Well so far I haven't ha any issues. Even wen I look away they stay synched.I sit about 1 Ft back from my 1070 which is ceiling mounted.
deez is offline
post #5962 of 11931 Old 08-15-2013, 11:09 PM
deez's Avatar
Originally Posted by DavidK442 View Post
Can't be of much help, except to say that if there is an obvious defect (like the blue spot you describe) then just keep returning it.
When buying projectors dealing with a reputable dealer with a solid return policy is worth the few extra dollars it may cost in the initial purchase.
My third W1070 so far is perfect. (First one returned due to the focus problem, second due to a noisey fan which quickly failed.) Thank you Amazon for making the process so painless or else I may have never tried the 3rd.
It would be interesting to setup a poll to know how many receive a good projector on the first go, but I doubt many would be motivated to log-on just to give a positive review.
What exactly is the focus problem?
deez is offline
post #5963 of 11931 Old 08-16-2013, 12:43 AM
hotjt133's Avatar
Quoted: 21 Post(s)
Liked: 30
Ian
I think this cricket sound is by design...
It develops over time. My first sample took 50 hours, current one took 120 hours. But now the cricket sound is very similar to the first one which I returned. I hope it is a fan bearing issue, and can be cured by some lubrication. But if it is the color wheel then we are cursed.
And the noise on mine is not just 3D mode, 2D as well.
hotjt133 is offline
post #5964 of 11931 Old 08-16-2013, 07:52 AM
Derek Day's Avatar
Is this sound loud enough that you can actually hear it over 7.1 surround sound?
Derek Day is offline
post #5965 of 11931 Old 08-16-2013, 08:00 AM
farleyville's Avatar
I have had my unit for roughly 80 hours and I do not hear any noise as reported above. When the unit is powered on, in a quiet room, there is definitely a winding up that you hear and the fan motor comes on. But I do not hear it at all while watching a movie. In fact, my Air conditioner blowing in my basement is louder than the fan on this unit. Can you hear your AC when it comes on in your house, YES, does it bother you? I assume it doesnt as you just get used to it. Same for the fan on this unit. I can't speak to the issues that they are reporting, but for my unit, the sound of the fan is NOT a problem.
farleyville is offline
post #5966 of 11931 Old 08-16-2013, 08:23 AM
Derek Day's Avatar
Okay, that's kinda what I figured. This will mainly be used for football and gaming. The NFL finds it amusing to populate the rear channels with fans screaming. People who aren't used to watching football with 7.1 will often times turn around, it's semi-humorous.
post #5967 of 11931 Old 08-16-2013, 10:18 AM
kbarnes701's Avatar
Liked: 5069
Ian
On mine I get it when using Smart Eco mode. If I use Economic mode I don't get it. I haven't used 3D enough yet to be able to comment. As with yours, it took 40 to 50 hours for it to develop. I 'solved' it by switching to Economic mode.
post #5968 of 11931 Old 08-16-2013, 10:19 AM
kbarnes701's Avatar
Liked: 5069
Not in mine, except in scenes that are more or less silent. And my unit is directly overhead, about 2 feet above me.
post #5969 of 11931 Old 08-16-2013, 12:57 PM
Scotty Leon's Avatar
Any football settings you guys recommend? I have the calibration settings for movies but Football doesn't look "natural" with those settings?
Scotty Leon is offline
post #5970 of 11931 Old 08-16-2013, 06:13 PM
jlluna's Avatar
Any one using the harmony one remote with this projector? i am using the harmony one remote and it wont change my projector input from hdmi 1 to hdmi 2 it just stays on the same input.
jlluna is offline
Benq W1070 1080p 3d Projector
