BenQ W1070 : DLP Full HD, 3D Ready with lens-shift for 1000$ - Page 252 - AVS Forum | Home Theater Discussions And Reviews
 391Likes
post #7531 of 11957 Old 01-27-2014, 11:23 AM
vjicecool's Avatar
Originally Posted by bluer101 View Post
He is using the w1080 which is short throw.
I have this benqw1070
Is there any option i need to change to make it to short throw or by default its short throw
vjicecool is offline
post #7532 of 11957 Old 01-27-2014, 11:32 AM
bighvy76's Avatar
Quoted: 22 Post(s)
Liked: 29
No
bighvy76 is offline
post #7533 of 11957 Old 01-27-2014, 11:47 AM
ConnecTEDDD's Avatar
Quoted: 1078 Post(s)
Liked: 1546
Originally Posted by Cerberus83 View Post
Originally Posted by Phatboy69 View Post
You can buy the disc, ISO or MKV & MP4 downloads from here $15 > http://www.displaycalibrations.com/index.html
How intuitive is this calibration tool? Do I need to have experience/knowledge and/or any additional tools in order to use this calibration software or can anyone (especially a noob) use it to probably calibrate his/her projector? I wouldn't mind paying $15 for software that works, but there's no point in me buying one if I have no idea how to properly use it...
Hello, this is a calibration disk, not a software.
It features full automated profiling with LightSpace Software for 3D LUT, or semi-automated with CalMAN/ChromaPure to measure the performance of a display or perform 1D LUT calibration.
I have posted before some minutes a long detailed reply here.
But there some additional informations at the first post of this topic.
LightSpace Software combined with Ted's LightSpace Calibration using an eeColor 3D LUT Box to save the changes; it's the only solution right now in HT world that you can profile your display/projector by using your actual consumer stand-alone bluray player as a pattern source to generate the required 10-Point (1.000 Colors) or 17-Point (4.913 Color) without the need of any external pattern generator.
90% of the HT world users, they use consumer blu-ray/media players, so running my disk from their actual source is a real advance since this is impossible right now with any other calibration solution to do this, since all the other solutions are using an external pattern generator to generate the patches and this is avoiding the errors that the players are introducing.... I'm talking about HT enviroment and not HTPC.
So this fact is making LightSpace + My Calibration Disk the best method for calibrating the whole HT video signal chain.
My reply sounds off-topic but is a quick reply to the user request. I will continue to reply to any new question to the disk delicated topic please.
Ted's LightSpace CMS Calibration Disk Free Version for Free Calibration Software: LightSpace DPS / CalMAN ColorChecker / HCFR
S/W: LightSpace CMS, SpaceMan ICC, SpaceMatch DCM, CalMAN 5, CalMAN RGB, ChromaPure, ControlCAL
V/P: eeColor 3D LUT Box - P/G: DVDO AVLab TPG
Meters: JETI Specbos 1211, Klein K-10A, i1PRO2, i1PRO, SpectraCAL C6, i1D3, C5
ConnecTEDDD is online now
post #7534 of 11957 Old 01-27-2014, 12:05 PM
niccolo's Avatar
Quoted: 141 Post(s)
Liked: 39
Throw range is a function of the optics and internals of the projector, so you're stuck with the quasi-short throw range of your W1070, rather than the extreme short throw range of the W1080. It's like buying a rear-wheel drive car and then asking where the button is to convert it to four-wheel drive; doesn't exist.
Benq W1070 projector w/ Chief RSM mount with custom interface bracket
119" Da-Lite Cinema Contour with High-Contrast (gray) Da-Mat screen
Denon X2000 receiver fed by Panasonic DMP-BDT210 Bluray player
Focal Chorus 700-series towers and center, JMLab Tantal 500-series bookshelf rears
Rythmik FV15HP sub
niccolo is offline
post #7535 of 11957 Old 01-27-2014, 12:12 PM
Cerberus83's Avatar
Hi Ted,
Thanks for your response. So I just pop it in my blu-ray player and I will be able to properly (or at least get close to properly) calibrate my projector, even though, I really have no prior experience with calibration (especially since this my first projector)? I am a noob at this (to a point), so I just need something this is somewhat simple to use that yields good results. I was going to use the settings that people have posted on this forum to start with and see where that takes me....
Cerberus83 is offline
post #7536 of 11957 Old 01-27-2014, 12:26 PM
Liked: 1546
Hi Ted,
Hello,
You can use a lot of patterns (without using meter/software) to perform a basic calibration of your display.
For example, you can set:
Brightness Pattern to set the Black Level (Brightness Control) of the Display; to prevent crushing of shadow details or raised black levels.
Contrast Pattern to set the White Level (Contrast Control) of the Display; to prevent color detail clipping up to peak white levels and above reference white level color shifts/discoloration.
Use Sharpness Pattern to prevent edge enhancement (halo/ringing effect) or soft contouring (blurring of the image details).
Use Color Clipping Pattern to prevent clipping of each color channel.
Use a Grayscale Ramp to check which color temperature mode (normal/warm1/warm2 etc) of your display looks more neutral to your eyes.
You can use the Colour Reproduction Patterns to check your display's controls / various mode settings / enhancements of your display, if they introducing problems or if they are broken and you have to leave them untouched to prevent new problems. (no smooth color graduations, distortions, discoloration, clipping, banding, posterization, crushed shadow details, raised black levels etc.)
But you can't set your peak light output, perform RGB Balance of your grayscale, calibrate your Primary/Secondary Colors (Hue/Saturation/Lightness), fix your gamma levels etc. for REC.709 without a meter/software.
The truth is that by using any calibration disk you just preparing the display before start using your meter/software.
Calibration without meter/software can't be performed, with a disk you can adjust some basic controls and you will be able to prevent some problems.
For anyone who need to discus something please post it to the Display Calibration Area of the AVSForum. Thanks
post #7537 of 11957 Old 01-27-2014, 12:43 PM
humblebeing's Avatar
Hello,
Would you recommend the BenQ W1070 on top of Optoma's 131Xe?
humblebeing is offline
post #7538 of 11957 Old 01-27-2014, 12:46 PM
Liked: 1546
Hello, unfortunately I have no personal experience between these 2 units. If any of these units come to my hands I will let you know my impressions wink.gif
post #7539 of 11957 Old 01-27-2014, 04:09 PM
Phatboy69's Avatar
Liked: 55
To add, or perhaps simplify Teds answers that he already provided. The W1070 and W1080ST are very close to reference calibration out of the box, but can certainly be improved with proper calibration.
The keys to a good picture are brightness, contrast, gamma and colour balance. These 1st 3 key areas of brightness, contrast and gamma can be improved without any knowledge or meters and the last one, colour balance, you need a meter. (however the W1070 and W1080ST colour are close enough out of the box that most people wouldn't see the difference and you would infact need professional calibration meters to make it better)
For $15 it does way more than most calibration discs out there, but you don't need a science degree to drive it to get good results and you don't need meters to make improvements to your picture quality. (but to get the most out of it you need software and a meter)
The brightness and contrast patterns are easy enough to set and you will get pretty close using setting others have posted here without a calibration disc. But to allow for variations in peoples throw distance, screen material, screen gain, ambient light, and bulb age you need some reference material and a test disc to set specifically for your circumstances.
Teds disc does the basics very well without any other meters or software or without any great knowledge. It is the most complete solution on the market but you don't need to use all the features to get a good picture.
Originally Posted by timdafweak View Post
With which version of the firmware, if I may ask.
1080p 3D @ 60hz SBS is enabled in firmware 1.05 on the W1080ST and 1.08 on W1070.
I have a question regarding this gentleman's thread
http://www.avsforum.com/t/1511459/120-matt-white-black-spandex-with-benq-w1080st-what-a-great-combination
How is it possible to project that large image from a short distance, any settings needs to be changed?
I am now projecting the image from 16ft distance from the wall and 6 feet from the ground. Any help would be appreciated.
As mentioned by others its an ultra short throw W1080ST version of the W1070. Its the only ultra short throw 3D projector on the market an you can make an 80" picture from about 1.5M or roughly 5 feet.
Hi Ted,
As mentioned above, yes, but you might need to do just a little bit of light reading and research to understand which patterns to use and how to set the projectors settings with them.
With the picture I posted I dropped the brightness control to 48 with the black and white combined test pattern getting the number 17 square to be just visible and the 16 to blend in with the background. 16 is reference video black.
Using the individual contrast and brightness images results in crushed blacks because the average picture level in those tests doesn't represent an average picture. The combined test gives the best result for average picture levels of most films.
I then used the same calibration image to set the maximum contrast with out introducing colour shift and making sure that white clipping was occurring above 235. (in my case a setting of 65 for contrast which clipped everything above 235 which is peak white for video)
However pushing the contrast that high also resulted in quite a big push in gamma, making the whole image shift brightness up to about gamma 1.9. This meant blacks were now brighter than the best black the projector could do, even though the black was still calibrated for black 16.
I then used a gamma pattern to adjust gamma. With a gamma pattern you squint until the gamma bar matches the outside area and the bar that blends the smoothest to the outside is the gamma of your picture.
In my case I was reading a Gamma of about 1.9 with contrast at 65 and I opted to reduce contrast to 55 to bring gamma back into alignment. I tried using the projector gamma settings and even at maximum gamma setting of 2.8 I was still only measuring about 2.1 and the picture had a slightly hard edge to it instead of looking smooth and film like. By dropping the contrast to 55 I was able to attain almost perfect Gamma of 2.2. Changing the projector to 2.4 gave a gamma of about 2.3 which in some circles is the perfect gamma for well mastered film, however with this projector that results in slightly crushed blacks and scenes that are slightly darker than ideal.
A gamma of 2.2 is just about the best picture you can get out of this projector while still being forgiving of some material which is mastered a bit dark or cloudy in the blacks. For some slightly cloudy black films where blacks are crushed anyway, I move the projector down to brightness 47 and this makes a significant drop in blacks down to about the right clipped level for those cloudy black films. Gamma 2.4 also works well for those situations.
Keep in mind these are my settings for my circumstances with .9 gain spandex screen with a black layer behind the white @ a 120" in a light controlled room. My playback source also goes below black and above peak white over HDMI in YUV mode which some peoples players do not.
Your mileage will vary but what works well for me is: (with W1080ST Firmware 1.05)
Cinema memory
Economic lamp
Colour Temp Normal
Brightness 48
Contrast 55
Gamma 2.2
+1 step of red (I haven't got a suitable light meter to do full calibration yet but I did a rough manual calibration of RGB with my basic light meter with colour filters, which is VERY time consuming)
Phatboy69 is offline
post #7540 of 11957 Old 01-27-2014, 07:23 PM
Cerberus83's Avatar
WOW! Thanks for that very informative reply! And yes, I do understand that it will take some time playing around with settings and that my HT room will have a lot to do with which settings I choose as well. FWIW, I'm planning to paint my walls Gibraltar Gray from Sherwin-Williams and probably a bit darker ceiling and black carpet (with controlled ambient lighting). As I mentioned in the previous post a few pages back, I'm finishing my basement and will turn a section into a dedicated HT room. So the only - sort of unknown - is the screen, but I'm planning to go with Elite Screen 1.1 gain. I did read about folks making their own ND filter and I may go that route if it's too bright.
Either way, that's for the info!
post #7541 of 11957 Old 01-27-2014, 09:33 PM
Phatboy69's Avatar
Liked: 55
No worries, sounds like you'll have a great setup there but depending on your screen size 1.1gain might be too high as you have already suggested unless its a grey screen.
Just for reference, the projector central calculator suggested I would get 22fl at .9 gain with 120" with my throw distance and that's about spot on with what I measured with my meter with projector in normal mode. That's a tad too bright in a light controlled room for 2D, so you can get a pretty good idea what will work for you based on the projector central calculator.
Also the projector is actually brighter in smarteco mode than normal mode and I use smarteco for 3D with almost the same calibration settings and the image is great.(contrast 57 brightness 49). A 1.1 gain screen is certainly useful for 3D though!
post #7542 of 11957 Old 01-27-2014, 10:10 PM
JoeBoy73's Avatar
Quoted: 12 Post(s)
Liked: 26
Hello Vj...not sure if this helps, I'm projecting on to a 150" screen from 14-15ft back (1070. Completely dark media room and the picture is great!
JoeBoy73 is online now
post #7543 of 11957 Old 01-28-2014, 10:16 AM
Cerberus83's Avatar
The screen would be Max White. I can't find a gray screen or <1.0 gain screen that's affordable (under $400).
Using, the projector central calculator, I would have to get 125" screen at 1.1 gain in order to maintain ideal brightness. However, I'm also considering 110" screen, but at 1.1 gain, that does seem too bright. Looks like in order to compensate for higher brightness and not spend $900+ on the screen, the most economical solution would be to add the ND filter. And yes, while brightness would be great for 3D movies, ironically, I am not interested in those (2D only).
post #7544 of 11957 Old 01-28-2014, 12:18 PM
THE BIG SITT's Avatar
Anyone know when the sale through Amazon will end on this?
THE BIG SITT is offline
post #7545 of 11957 Old 01-28-2014, 12:48 PM
Daniel Chaves's Avatar
Quoted: 394 Post(s)
Liked: 281
just took advantage of that Amazon deal and bought another w1070, so the one currently in my bedroom with the much older firmware I want to say 1.04 will be moved into the living room and Im hoping fingers crossed I get the one with the newer firmware and different remote for the bedroom. smile.gif
Projector: BenQ w1500 + ES Sable 135" Screen AVR: Onkyo TX-NR646 ATMOS/DTSX + Darbee 5000
Speakers: Polk Audio TSX550t (FL/FR), CS2 Series II (C), Monitor40 Series II (RL/RR),
Onkyo THX Bookshelf Speakers (Ceiling L/R), (2) JL Audio 12" Subs + (2) Dayton 15" Subs + (2) ButtKicker LFE
Arrangement: 5.1.2 Source: HTPC, Roku 4, Nexus Player, Samsung UBD-K8500 4k Bluray Player
Daniel Chaves is offline
post #7546 of 11957 Old 01-28-2014, 01:38 PM
Jester435's Avatar
Quoted: 24 Post(s)
Liked: 75
The price on amazon fluctuates every few weeks. Between $750-$850
I ordered off amazon 3 weeks ago and got 1.07 and much newer updated remote.
I think you should be fine!
Jester435 is offline
post #7547 of 11957 Old 01-28-2014, 01:40 PM
Quoted: 394 Post(s)
Liked: 281
awesome fingers crossed, since I will be using my harmony one remote in the living room now, having a red light up remote would be handy for the bedroom lol ^_^
post #7548 of 11957 Old 01-28-2014, 01:40 PM
Jester435's Avatar
Quoted: 24 Post(s)
Liked: 75
You can buy mine.. haha
I use harmony one remote and the benq remote is in a drawer.
On a side note..
I watched Skyfall last night my brain almost exploded with how awesome it looked and sounded! BenQ W1070 is amazing for the price.
post #7549 of 11957 Old 01-28-2014, 08:18 PM
filtor's Avatar
Liked: 36
Get aload of this 1070 deal I got. I tried to price match mine to Amazon thru Best Buy rite after Christmas ... but Amazon itself was out of stock and BB won't price match their vendors just Amazon itself. So found Frys also had it for $749 (same as Amazon did) but there was no Frys locally so they said (second call to BB sales dept) they couldn't match Frys to my local BB. I finally (third call and third different sales rep) got rep to discount 10 percent off BB's $799 price... so minus $79.90 ... but couldn't talk her out of waiving sales tax. But did get free in-store pickup. So total came to like $779... BUT I got $35 in "Best Buy Rewards* AND they had a deal going for two days after Christmas where if you order over $100 online for in-store pickup they sent a $15 savings code by email ... soooooo -- total outta pocket came down to like $730 after savings ... which I applied to some 3D discs. biggrin.gif
filtor is offline
post #7550 of 11957 Old 01-28-2014, 08:19 PM
Scottathon's Avatar
My warranty has lapsed and the dust particles are becoming increasingly annoying for films with darker scenes. I've perused this thread and have seen that at least one person has disassembled their unit, but how rash would doing such a thing be with little to no experience in dealing with projectors? Can anyone offer any advice?
Scottathon is offline
post #7551 of 11957 Old 01-28-2014, 08:20 PM
Cerberus83's Avatar
Given that Fry's price is back to $999, I wouldn't be surprised to see Amazon raising the price back to $875 within a day or so. FYI - the current price is the second lowest (the lowest was $749 a month ago).
post #7552 of 11957 Old 01-28-2014, 08:28 PM
Cerberus83's Avatar
Is it worth buying 3-year warranty for $60? After reading the terms on Amazon, it appears it's only 2 additional years since "the plan begins on the date you purchased your item and is inclusive of the manufacturer's warranty period."
post #7553 of 11957 Old 01-29-2014, 06:32 AM
Well that does it. I shall purchase today!
Alex Batiste likes this.
post #7554 of 11957 Old 01-29-2014, 06:52 AM
caseyparsons's Avatar
Quoted: 41 Post(s)
So what's a good mount, reasonable price for this projector? I'm a noob and jumped on the Amazon deal.
n00b
Theater Under Construction
Childhood Home Theater Build
caseyparsons is offline
post #7555 of 11957 Old 01-29-2014, 11:08 AM
Jester435's Avatar
Quoted: 24 Post(s)
Liked: 75
worth every penny. dont go cheap on the mount or else you will have nightmare keeping it aligned
http://www.amazon.com/Peerless-PRGUNV-Precision-Universal-Projector/dp/B000TXNS6G
THe_Flash likes this.
post #7556 of 11957 Old 01-29-2014, 11:14 AM
Wow that seems a little salty for a mount. Correct me if I'm wrong, it seems a little pointless to spend so much for something you will set once and never touch again...
post #7557 of 11957 Old 01-29-2014, 11:17 AM
efto's Avatar
Hi,
I downloaded both firmware upgrade instructions, from here:
ftp://62.141.76.120/driver/projectors/w1070/
and here:
https://www.dropbox.com/sh/x5omnxp1vr6wyi4/15YsjCtmTd
The first one says this: "...Skip Boot loader area (32KB)"
The second one: "...Skip Boot loader area (128KB)"
Which one is true?
efto is offline
post #7558 of 11957 Old 01-29-2014, 11:17 AM
Jester435's Avatar
Quoted: 24 Post(s)
Liked: 75
If you have ever dealt with trying to align a projector after it gets moved. that price is nothing. I spent over an hour messing with mine over the weekend. My theater room is in the basement and my son jumping around upstairs makes the mount move.
I went cheap on the mount and it has been a nightmare
http://www.amazon.com/gp/product/B000IDC0K2/ref=oh_details_o02_s00_i00?ie=UTF8&psc=1
This is what I got and HATE IT!
post #7559 of 11957 Old 01-29-2014, 11:20 AM
I have never done anything with a projector mount. What causes yours to move? Couldn't you just tighten the bolts? How would your mount work if you never had anyone around to move it?
post #7560 of 11957 Old 01-29-2014, 11:20 AM
bluer101's Avatar
Quoted: 347 Post(s)
Liked: 281
That's the same mount a bought last week and hung this past weekend. I used the the adjustment plate only and made my own projector plate. The arms that come with the unit will work but for me was overkill and too heavy/bulky.
After spending the $90 plus my own design of the plate it's worth every penny. It makes fine tuning a breeze. Also I find I do not need to tighten the set screws as the mount holds it position without them. I can't imagine sitting there and loosen screws and put your hands on the projector and moving it fraction of an inch. Then tighten the screws to find out it moved slightly. This mount was so precise.
Projector & Screen: Epson 5040ub Elite Screens 100" Electric Video: Oppo 103d Audio: Denon 4520ci Speakers: Infinity RS5 (LW L C R RW) Infinity RS1 (LH RH) Infinity Beta ES250 (SL SR) Subwoofers: 2 SI18d4 Martycubes with iNuke3000dsp and 2 Infinity BU120 Shakers: 4 ADX shakers with Dayton SA230 amp
My Builds--Media console build----Martycube build----ADX Bass Shaker Install
bluer101 is online now
Benq W1070 1080p 3d Projector
