BenQ W1070 : DLP Full HD, 3D Ready with lens-shift for 1000$ - Page 253 - AVS Forum | Home Theater Discussions And Reviews
 392Likes
post #7561 of 11960 Old 01-29-2014, 11:21 AM
efto's Avatar
I downloaded the firmware upgrade instructions from both links provided here (ftp and dropbox).
The first one says that Skip Boot loader area should be set to 128KB while the second one suggests 32KB.
Which one is true?
efto is offline
post #7562 of 11960 Old 01-29-2014, 12:00 PM
kbarnes701's Avatar
Quoted: 6740 Post(s)
Liked: 5074
Originally Posted by Jester435 View Post
Originally Posted by caseyparsons View Post
So what's a good mount, reasonable price for this projector? I'm a noob and jumped on the Amazon deal.
worth every penny. dont go cheap on the mount or else you will have nightmare keeping it aligned
http://www.amazon.com/Peerless-PRGUNV-Precision-Universal-Projector/dp/B000TXNS6G
100% agreed. That is the mount I use and it is fabulous. So much control. And it will last a lifetime, so the price will soon be forgotten.
kbarnes701 is offline
post #7563 of 11960 Old 01-29-2014, 12:24 PM
CoxyUK's Avatar
What 3D has 1.08 added? I see people saying 1080p @ 60hz SBS but this was possible on 1.07 as long as source was in RGB colour mode, which is still true for 1.08.
Cheers
CoxyUK is offline
post #7564 of 11960 Old 01-29-2014, 12:31 PM
caseyparsons's Avatar
Quoted: 41 Post(s)
OK, sounds good and you've convinced me to spend a little extra. I need a mount that allows me to hang the projector about two feet from the ceiling. Will this mount allow an extension? Or is there a different Peerless I should look at?
Thanks!!!
n00b
Theater Under Construction
Childhood Home Theater Build
caseyparsons is offline
post #7565 of 11960 Old 01-29-2014, 12:56 PM
THe_Flash's Avatar
Liked: 25
Completely agree on the Peerless Mount, it's awesome.
For those that upgrade their firmware, that's at least one move you'll be making after it's initially set. If you ever need to adjust or move your screen (painting walls comes to mind), there's another time you'll need to adjust. True, it doesn't happen often but knowing it's easily aligned once snapped back in place makes it worth it. I can't say enough about how great the gear adjustment is.
THe_Flash is offline
post #7566 of 11960 Old 01-29-2014, 12:59 PM
THe_Flash's Avatar
Liked: 25
Thanks!!!
After it's up take a measurement and buy yourself a cheap threaded pipe from Lowes or Home Depot. I needed about a 7in. drop and that worked pretty well for me. Since painting steel is cumbersome, I simply wrapped it in white vinyl tape.
post #7567 of 11960 Old 01-29-2014, 01:01 PM
Quoted: 41 Post(s)
OK, so the pipe extension just screws in place? Sounds easy enough...
Thanks!!
n00b
post #7568 of 11960 Old 01-29-2014, 01:06 PM
bighvy76's Avatar
Quoted: 22 Post(s)
Liked: 29
I used one of these cheaper mounts. It works just fine has a ball joint so u can adj left right up and down.
bighvy76 is offline
post #7569 of 11960 Old 01-29-2014, 01:12 PM
THe_Flash's Avatar
Liked: 25
Yes,
Thanks!!
Yes, make sure it's threaded and you can screw it right in.
post #7570 of 11960 Old 01-29-2014, 01:13 PM
Jester435's Avatar
Quoted: 24 Post(s)
Liked: 75
Thanks!!
Amazon shows these items
http://www.amazon.com/Peerless-Indus-EXT-006-extension/dp/B0002XHBIO/ref=pd_bxgy_e_text_z
http://www.amazon.com/Peerless-ACC570-Joist-Ceiling-Mounts/dp/B000BITSTA/ref=pd_bxgy_e_text_y
So if you need to extend.
I havent used either, so I cant tell you if it is worth the cost. Others have given you correct direction by buying a threaded pipe from lowes/home depot
Jester435 is offline
post #7571 of 11960 Old 01-29-2014, 01:16 PM
THE BIG SITT's Avatar
That's the kind of thing that I'm interested in. If I can save $80 on a mount simply by spending some extra time, than I'm all for it. Once the mount is in position, how do you lock it in place?
THE BIG SITT is offline
post #7572 of 11960 Old 01-29-2014, 01:18 PM
bighvy76's Avatar
Quoted: 22 Post(s)
Liked: 29
Those white thumb screws lock everything down.
bighvy76 is offline
post #7573 of 11960 Old 01-29-2014, 01:27 PM
bluer101's Avatar
Quoted: 352 Post(s)
Liked: 285
For the peerless mount I used the 2 inch schedule 40 PVC to make my extension, total cost $3.50.
Here is my post 2 pages back I made this past weekend.
http://www.avsforum.com/t/1435626/benq-w1070-dlp-full-hd-3d-ready-with-lens-shift-for-1000/7500#post_24271646
THe_Flash likes this.
Projector & Screen: Epson 5040ub Elite Screens 100" Electric Video: Oppo 103d Audio: Denon 4520ci Speakers: Infinity RS5 (LW L C R RW) Infinity RS1 (LH RH) Infinity Beta ES250 (SL SR) Subwoofers: 2 SI18d4 Martycubes with iNuke3000dsp and 2 Infinity BU120 Shakers: 4 ADX shakers with Dayton SA230 amp
My Builds--Media console build----Martycube build----ADX Bass Shaker Install
bluer101 is online now
post #7574 of 11960 Old 01-29-2014, 01:37 PM
timdafweak's Avatar
Cheers
I too would like to know that. I've been searching high and low for a definitive answer to this.
That said, I did update to 1.08 last night and will try out the formats this weekend (once the renovation is complete).
timdafweak is offline
post #7575 of 11960 Old 01-29-2014, 03:22 PM
niccolo's Avatar
Quoted: 141 Post(s)
Liked: 39
The Peerless mount is excellent, with the major caveat that it lacks yaw (i.e. side-to-side) adjustment. If you mount it on an extension pipe, you can rotate it around the pipe threads for a crude yaw adjustment. If you ceiling mount, you can loosen the anchor bolts and rotate it that way for an even cruder adjustment. I ended up returning the Peerless and replacing it with a Chief, which unlike the Peerless is engineered for a three-dimensional world. You'll see more robust discussion a few pages back in this thread. http://www.thefinalclick.com/Chief-RSMAU-Universal-Mini-Elite-Projector-Mount--Black_p_86403.html
Benq W1070 projector w/ Chief RSM mount with custom interface bracket
119" Da-Lite Cinema Contour with High-Contrast (gray) Da-Mat screen
Denon X2000 receiver fed by Panasonic DMP-BDT210 Bluray player
Focal Chorus 700-series towers and center, JMLab Tantal 500-series bookshelf rears
Rythmik FV15HP sub
niccolo is offline
post #7576 of 11960 Old 01-29-2014, 03:25 PM
niccolo's Avatar
Quoted: 141 Post(s)
Liked: 39
And whatever mount you get, properly balancing the projector beneath the mount will go a long way toward keeping it aligned over time.
Rythmik FV15HP sub
niccolo is offline
post #7577 of 11960 Old 01-29-2014, 03:50 PM
bluer101's Avatar
Quoted: 352 Post(s)
Liked: 285
That's why I made my mount to go with the peerless. It allows up, down, side to side, and yaw. Then pitch and roll is controlled by the peerless.
post #7578 of 11960 Old 01-29-2014, 03:55 PM
Jester435's Avatar
Quoted: 24 Post(s)
Liked: 75
I am confused on why Yaw is so important.
I understand, up and down, side to side, pitch and roll.. But not Yaw.
post #7579 of 11960 Old 01-29-2014, 05:37 PM
niccolo's Avatar
Quoted: 141 Post(s)
Liked: 39
We live in a three-dimensional world, right? So when you're trying to get your projector perfectly lined up relative to your screen/wall, you're going to need to be able to adjust it in all three of those dimensions.
Let me try a different tack: imagine your projector is pointing into the front corner of your room, not at the center of your screen. How do you fix that? Answer: yaw. It's obviously an extreme example, but the point is that unless you are able to mount your projector absolutely perfectly parallel to the screen, you'll need some fine-tuning to get it parallel to the screen.
Rythmik FV15HP sub
niccolo is offline
post #7580 of 11960 Old 01-29-2014, 05:53 PM
Jester435's Avatar
Quoted: 24 Post(s)
Liked: 75
Isnt this what keystone does??
I do see how yaw is important, but maybe I missing something because my install was very straight forward.
post #7581 of 11960 Old 01-29-2014, 06:14 PM
niccolo's Avatar
Quoted: 141 Post(s)
Liked: 39
Keystone can compensate for either vertical or horizontal misalignment (though I think our projector only allows one of those), but at the cost of degrading the image. Basically, keystone squishes the image into the smaller number of pixels available at whatever spot you're trying to reduce the image size, both reducing resolution and introducing digital distortions. Keystone is not a substitute for proper mounting, it should only be used when proper mounting is impossible due to the physical characteristics of the room (and in that case you're much better off with a projector that allows sufficient vertical and horizontal lens shift).
Rythmik FV15HP sub
niccolo is offline
post #7582 of 11960 Old 01-29-2014, 06:15 PM
mishari84's Avatar
Quoted: 119 Post(s)
Liked: 25
Today I watched the hobbits 3D. used soundandvision for colors settings.. Huge improvement and much more accurate colors than default. I also put the projector on shortest throw to increase brightness, I think it helped.
mishari84 is offline
post #7583 of 11960 Old 01-29-2014, 08:15 PM
Daniel Chaves's Avatar
Quoted: 394 Post(s)
Liked: 282
I bought the mustang mount and it worked out great
http://www.amazon.com/Mustang-Profile-Projector-Mount-MV-PROJSP-FLAT-B/dp/B000F5NFTS
Projector: BenQ w1500 + ES Sable 135" Screen AVR: Onkyo TX-NR646 ATMOS/DTSX + Darbee 5000
Speakers: Polk Audio TSX550t (FL/FR), CS2 Series II (C), Monitor40 Series II (RL/RR),
Onkyo THX Bookshelf Speakers (Ceiling L/R), (2) JL Audio 12" Subs + (2) Dayton 15" Subs + (2) ButtKicker LFE
Arrangement: 5.1.2 Source: HTPC, Roku 4, Nexus Player, Samsung UBD-K8500 4k Bluray Player
Daniel Chaves is offline
post #7584 of 11960 Old 01-29-2014, 08:19 PM
merkaba's Avatar
Quoted: 131 Post(s)
Liked: 36
Is anyone using an Elite ($200-300) screen with electric motor on this projector? Are you happy with it? I will be about 10 feet from the screen and was thinking about getting a 120" screen. Is that too big for the viewing distance?
merkaba is offline
post #7585 of 11960 Old 01-29-2014, 08:35 PM
Phatboy69's Avatar
Liked: 55
It will be a little big for 16:9 material at that distance but great with 2.35 anamorphic. A better size would be 110".
merkaba likes this.
Phatboy69 is offline
post #7586 of 11960 Old 01-29-2014, 08:37 PM
merkaba's Avatar
Quoted: 131 Post(s)
Liked: 36
Thank you.
merkaba is offline
post #7587 of 11960 Old 01-29-2014, 08:42 PM
bluer101's Avatar
Quoted: 352 Post(s)
Liked: 285
I'm 9 feet to eyes from an elite spectrum 100 inch. I think it's just perfect for us.
post #7588 of 11960 Old 01-29-2014, 08:51 PM
merkaba's Avatar
Quoted: 131 Post(s)
Liked: 36
Nice. So maybe a 106 or a 110 version is going to be just perfect. The Elite Spectrum was the version I was thinking about getting. I thought about the CineTension version, but is it really worth the extra money? Tension vs no tension seems to be the only difference? I believe all my content will be normal 16:9, 1080p content. Do you happen to have an example of what would be 2.35 anamorphic?
merkaba is offline
post #7589 of 11960 Old 01-29-2014, 08:56 PM
THe_Flash's Avatar
Liked: 25
Essentially, black bars at the top and bottom of the image.
post #7590 of 11960 Old 01-29-2014, 08:58 PM
merkaba's Avatar
Quoted: 131 Post(s)
Liked: 36
Ah, ya ok. Not too big of a deal if that's the case for me. Most of the stuff is 16:9 anyways.
merkaba is offline
Benq W1070 1080p 3d Projector
