BenQ W1070 : DLP Full HD, 3D Ready with lens-shift for 1000$ - Page 256 - AVS Forum | Home Theater Discussions And Reviews
 396Likes
post #7651 of 11971 Old 02-04-2014, 12:30 AM
kreeturez's Avatar
Quoted: 477 Post(s)
Liked: 363
Originally Posted by lapino View Post
Originally Posted by kreeturez View Post
Same here.
My LED TV's don't handle brightness uniformity (with plain-white) much better, so not really complaining.
Actually they don't handle plain-black all that well either! (Edge-lit = brighter corners even on a black image. One-up to the BenQ, then!)
The only time I (barely) notice it on the pj in regular video viewing is with the occasional plain-white subtitles. Though if you do something like browse the web (with plain white backgrounds frequently) it may be a bit distracting.
well, we watch about 90 percent of our movies with subtitles, so that's why it is so annoying to me. it is always 'in my face'. have a Epson tw7200 now to test, and while it definitely shows more contrast I don't find it that much of a difference to the Benq. Movies seem less fluid, and I notice more xtlak in 3D. If only the Benq had a more uniform brightness...
That's saying something considering the higher price of the Epson. Though as a 3LCD, at least rainbows would be invisible (if you notice them in the 1st place); though I guess convergence/sharpness may be a bit worse for it too.
Most of my evening viewing is done with subs also (to not wake the kids wink.gif and as I mention, I still barely notice it :-)
If your media player supports it, what about changing the color of them? Light-Grey instead of white? (Haven't had the need to try this myself but it may produce an improvement?)
BenQ HT2050 Projector; Kodi (on Ubuntu, OpenELEC & S802) via Sony STR-DH540 AVR with Boston Acoustics SoundWare XS SE 5.1 Audio + Jamo 210 Sub. Emby for Mobile Streaming.
Helpful post? Click the 'Like' button!
kreeturez is offline
post #7652 of 11971 Old 02-04-2014, 01:01 AM
lapino's Avatar
Quoted: 73 Post(s)
Tried that but it did not improve things a lot. Maybe mine was just a tad worse than normal? Could you take a picture of a movie with white subs to show me?
lapino is offline
post #7653 of 11971 Old 02-04-2014, 01:18 AM
militaru's Avatar
Hello everybody,
I know that you already answered 1000 times to these question that i'll ask you but there are alot of pages to search for the answers...
I need help for finding the perfect budget 3d glasses for my Benq w1070 - I found SainSonic-SSZ-200DLB which looks ok but you are the experts and that's why i'm asking you.
The second question is about a mount ceiling solution, if you can recommend any..
Thank you guys :)
militaru is offline
post #7654 of 11971 Old 02-04-2014, 02:59 AM
Phatboy69's Avatar
Liked: 55
Originally Posted by Phatboy69 View Post
...I'll have another look at 1080p 60Hz 3D SBS tonight. I know I did get it to work at least once but I'll confirm what settings were needed. From memory it only works in RGB mode and your video output from the player needs to be set to 60Hz. Its designed for PC use, not BD players.....
I tried again tonight and it definitely supports 1080p 60hz SBS 3D.
You need to be in RGB mode on the projector and also RGB mode on your output source (in my case RGB mode in Nvidia control panel).
You also obviously need to be in 60hz mode on your output source so the projector detects a compatible signal so that it will enable 1080p60hz SBS 3D.
I also played tomb raider in 3D SBS @ 1080p 60hz using tridef 3D and it looks great with a frame rate between 30-60FPS with the GTX760 and game settings on high. smile.gif
I found I actually liked the MADVR smooth motion on Wrath of the Titans in 3D @ 60hz because it smooths some of the 3D judder in the fast motion in that film. I would have thought that native 24p triple flash 144hz 3D would have been smoother than 24p MadVR smooth motion 3D @ 60hz (projector is probably doing double flash 120hz @60hz which is 60hz per eye vs 72hz per eye with triple flash)
Now off to do some more SVP testing.
timdafweak likes this.
Phatboy69 is offline
post #7655 of 11971 Old 02-04-2014, 05:05 AM
kreeturez's Avatar
Quoted: 477 Post(s)
Liked: 363
Sure; I'll do so this evening for you.
There's always the possibility your sample was a bit worse than regular... you'll let us know!
post #7656 of 11971 Old 02-04-2014, 05:38 AM
timdafweak's Avatar
PB69, thanks for your detailed posts and for looking into the 1080p SBS. From what you wrote, the crucial setting I forgot was to set the color space to RGB on the projector. I did however set it on my HTPC (via the AMD Catalyst Control Panel), all other things being the same. I will give that a shot tonight and see what I get.
I am rather stoked to read that you had a positive experience with madVR. I didn't even give it a shot, after the negativity from the Mrs towards SVP. Tonight while she works, I will do some extensive testing on my own. Stoked! Good luck on yours, and keep us informed. Your posts here are a fount of knowledge!
timdafweak is offline
post #7657 of 11971 Old 02-04-2014, 06:52 AM
ravneet's Avatar
ravneet is offline
post #7658 of 11971 Old 02-04-2014, 09:39 AM
kreeturez's Avatar
Quoted: 477 Post(s)
Liked: 363
I've spent some time trying to get a shot that demonstrates this on subtitles.
The closest I got was this:
Not very noticeable on the subs; in person or in picture...
However, we happened to watch another show this evening which had a plain-white background: and here it's pretty obvious:
Definite right-side brightness preference. (I'm table-mounted: ceiling would be the reverse).
The reason I'm not complaining (other than how much I like this pj in general and how little it costs) is because my other display devices aren't much better: here's that same shot on my new-ish LG 42" LED TV:
That's perhaps even less uniform than the projector.
Worse, that LED TV isn't great on plain-black either:
Nearly a year later and I'm still a massive fan of this projector, I guess!
post #7659 of 11971 Old 02-04-2014, 09:42 AM
mishari84's Avatar
Quoted: 119 Post(s)
Liked: 25
I think I read somewhere you can try to remove the lamp and put it back again.
mishari84 is offline
post #7660 of 11971 Old 02-04-2014, 09:51 AM
lapino's Avatar
Quoted: 73 Post(s)
I tried that. That being said, it does look a lot less bad than it was on mine. The difference is on top in your situation, I use it ceiling mounted and this adds to the effect like you said too. Just read about the w1300. If inputlag is the same as the w1070, I think I will buy that one since reviews state it has a better lens.
lapino is offline
post #7661 of 11971 Old 02-04-2014, 11:29 AM
Grayson73's Avatar
Quoted: 12 Post(s)
Originally Posted by pennywise666 View Post
its from this site:
http://www.soundandvision.com/content/benq-w1070-3d-dlp-projector-settings
they are nice settings,i use them.
I thought most people were using Withers' settings from this link:
http://www.avforums.com/threads/benq-w1070-reviewer%C2%92s-recommended-best-settings.1761516/
Has anyone compared both?
Grayson73 is offline
post #7662 of 11971 Old 02-04-2014, 11:39 AM
CheYC's Avatar
Quoted: 35 Post(s)
Liked: 56
My personally calibrated 1070 has values closer to those of the S&V FWIW (for 2D). I also think the 2.2 gamma is too low, but that's more of a personal preference I suppose. The 2.2 setting gives an actual gamma closer to 2.1, whereas the 2.4 setting gives an actual gamma around 2.3.
CheYC is offline
post #7663 of 11971 Old 02-04-2014, 12:14 PM
fredxr2d2's Avatar
Quoted: 178 Post(s)
Liked: 107
For mine (without equipment and just by eye), the Withers settings look far better to me than the S & V (I had it running both for a while and would switch back and forth). The Withers settings seem to make a much more natural looking picture and the colors don't seem to be oversaturated, whereas with the S &V settings, I noticed some blue oversaturation, especially on some beginning scenes in the Avengers blu-ray (take a close look at the spear that Loki uses when he first arrives on earth--the blue seems like it should be bright and glowing, but the S & V settings produced banding and too much pop: it didn't glow so much as sizzle with artifacts and grossness). All that being said, I think both produce much better picture than out of the box and unless I'd compared them side-to-side, I don't think that I would've noticed. Just my, non-equipment using 2 cents.
Also, on Gamma, I used to really like a darker gamma, but I much prefer the details that come out when you set it to 2.2 instead of 2.4 That's more my personal preference. And, as these may have variances in individual units: your mileage may vary. (I also don't seem to have the major lighting inconsistencies that others report, or that I've noticed anyway.)
Tim S.
Former 35mm and Digital Projectionist @ Regal Cinemas
Currently watching on: BenQ W1070, 106" 0.8 Gain Screen, Darbee, PS4, w/ Marantz SR6011, NAD C370 (for Front L/R), Outlaw Model 5000, SVS PB-2000, SVS PC-2000, a Def Tech CS-8080HD, 2 SM65 for L/R, 2 SM55 for sides, 2 PM1000 for rears, and 4 AW5500 for Atmos.
fredxr2d2 is offline
post #7664 of 11971 Old 02-04-2014, 12:25 PM
Derek Day's Avatar
Hey all, probably a newby question here but I've searched every place both on here and Google and haven't been able to find a definitive answer.
If I ditch the whole 3D thing and just use this projector for normal gaming, will it do 2D at 144hz? In the nVidia control panel I only have an option for 60hz and heard rumors that projectors can only do 60hz due to an HDMI limitation?
Derek Day is offline
post #7665 of 11971 Old 02-04-2014, 12:44 PM
Phatboy69's Avatar
Liked: 55
Unless Benq changes things with a firmware update you won't get more than 60hz. I tried custom resolutions and timings upto 144hz and could only get anything less than 60hz working.
post #7666 of 11971 Old 02-04-2014, 01:21 PM
Daniel Chaves's Avatar
Quoted: 396 Post(s)
Liked: 282
Well my second w1070 came in yesterday, got it up and I have the new remote but Im on firmware 1.06, now to break it in smile.gif
So far I have noticed that the fan is a lot quieter then my older w1070 even with high altitude cooling turned on its quieter, so I wonder if they improved the fan or reduced the RPMs...
Projector: BenQ w1500 + ES Sable 135" Screen AVR: Onkyo TX-NR646 ATMOS/DTSX + Darbee 5000
Speakers: Polk Audio TSX550t (FL/FR), CS2 Series II (C), Monitor40 Series II (RL/RR),
Onkyo THX Bookshelf Speakers (Ceiling L/R), (2) JL Audio 12" Subs + (2) Dayton 15" Subs + (2) ButtKicker LFE
Arrangement: 5.1.2 Source: HTPC, Roku 4, Nexus Player, Samsung UBD-K8500 4k Bluray Player
Daniel Chaves is offline
post #7667 of 11971 Old 02-04-2014, 02:04 PM
flint723's Avatar
This is true at 1920x1080, you will not get anything higher than 60hz to work, I tried as well.  But at 1280x720 I got it to work at 120hz interlaced.  But it did register on the projector info menu as 1280x800 @ 120hz.  Although it did display a picture, it did not fill the screen and I'm not sure if this could be resolved with aspect ratio settings or not.
I should also mention this is on 1.08 firmware.
The way to do it is set up a custom resolution in the "customize" button in the Nvidia control panel.
flint723 is offline
post #7668 of 11971 Old 02-04-2014, 05:03 PM
Phatboy69's Avatar
Liked: 55
I couldn't get SVP to work smoothly with my FullHD SBS 3D BD rips because 3840x1080 @ 60hz was too much for my CPU with SVP running. It did work if I set it to H-SBS but the picture was noticeably lower res with less detail on that mode. Unfortunately the Benq wont accept 48hz SBS 3D so SVP seems like a no go for 3D. I'll have another play tonight with 2D 24>60 SVP and see how I go.
Also remember with MadVR, that it won't do anything to the picture unless you have set the GPU display res to 60hz.
So far I think MadVR smooth motion at 60hz is the best option for smoothing 3D with fast action films but I prefer native 24p with 2D and most 3D non-action films.
From some more research I did, it seems that the Benq W1070/1080ST (and other consumer grade single chip DLP projectors) display 24p 2D material at 48hz to eliminate flicker. This is unconfirmed and just speculation that I found on another site.
I can get into service mode on my projector so I'm going to have a poke around while playing some 2D and 3D 24p material tonight and see what else I can uncover.
post #7669 of 11971 Old 02-04-2014, 05:45 PM
Quoted: 396 Post(s)
Liked: 282
okay this may be a silly question due to the cost involved but since the projector has the option has anyone tried this projector with an anamorphic lens?
hagsi likes this.
post #7670 of 11971 Old 02-04-2014, 10:28 PM
Bassoholic's Avatar
Ok, I did a search on FW1.08 and after reading 15mins, I do not see what changes in 1.08? Can someone post what new in 1.08 please? Thanks so much.
Bassoholic is offline
post #7671 of 11971 Old 02-05-2014, 01:03 AM
Phatboy69's Avatar
Liked: 55
Firmware Changelog History of Benq W1070
Firmware 1.03
Problem-1- To improve the flickering when smart ECO mode + dynamic setting
Problem-2- To add “Background” color in OSD
Firmware 1.04
Problem-1- When at low temperature environment, fan oil would become thickened, cause rotational speed of
fan can’t reach target then shut down.
Problem-2- Keystone bug: When playing 3D (Frame packing), and then switch to 2D, and keystone value
can’t be kept.
Firmware 1.05
Problem-1- ISF setting cannot be saved
Problem-2- compatibility problem for some unique 3D DVD players(Philips)
Problem-3- OSD Swedish language of ”on& off” wrong translation
Firmware 1.06
Fixes:
-1- Hg bridge problem symptom: can’t turn on a projector, but NDF after transportation; few cases found in BQC.
There is Hg (Mercury) in a lamp bulb. Whenever the liquid mercury make the Short-circuit of electrodes of the lamp, the unit can’t
be turn on. To change the cooling status and lamp ignition behavior can make mercury condense at different locations of a bulb.
Due to Hg (Mercury) changing the location in lamp bulbs during transportation, it will be NDF in ASP.
-2- To improve power-on while system initializing
-3- To improve Philips DVD compatibility issue(BQC)
-4- Add 3D format as appendix
-5- Adjust Audio Curve for BQjp
-6- Japanese OSD correction for Cool and Warm (BQjp)
-7-To enhance HDMI searching speed
-8- To update RC code for new remote RCV011
-9- To modify the gain value to improve HDMI signal searching ability
-10- To add model name W1250 in Factory OSD (only W1070)
Added support for 3D formats:
1280x720p@59/94/60 Hz -- SBS added
1280x720p@50Hz - SBS added
1920x1080p@23.98/24Hz - SBS added
1920x1080p@59.94/60Hz - Top Bottom - added
1920x1080p@50Hz - Top Bottom - added
Firmware 1.07
- ISF Night setting can’t be keep after 2D->3D timing changed
- To keep lamp hour after “reset all setting in USE OSD”
- To improve the 32 gray level via PS3 HDMI
- Modify picture mode of “power off” icon
- Modify HSG setting in No signal condition
Firmware 1.08
- Noise improvement / 1080p greenish problem via HDMI/VGA signal.
- Add 3D support timing: 1080p 60Hz SBS
W1080ST Version 1.03 = W1070 Version 1.06
W1080ST Version 1.04 = W1070 Version 1.07
W1080ST Version 1.05 = W1070 Version 1.08
(Do not load W1080ST with W1070 firmware!!!! The changelogs are the same but firmware IS NOT compatible between different projector models)
All current versions of W1070 Firmware
https://www.dropbox.com/sh/x5omnxp1vr6wyi4/e8_HLKrQUV/Firmware%20Files
or
ftp://62.141.76.120/driver/projectors/W1070/ Username: username Password: password
Latest 2 versions of W1080ST Firmware
ftp://62.141.76.120/driver/projectors/W1080ST/ Username: username Password: password
Service Manuals
https://docs.google.com/folderview?pli=1&docId=0B_xTFybwtlbvTHFqclRLU3pBNlk&id=0B_xTFybwtlbvU1oxdHRNcWd3LTQ
Useful Test Patterns - Username: username Password: password
ftp://62.141.76.120/driver/projectors/Tests/Main_HD/
post #7672 of 11971 Old 02-05-2014, 06:54 AM
Cerberus83's Avatar
Thanks!!
Cerberus83 is offline
post #7673 of 11971 Old 02-05-2014, 08:02 AM
Grant D's Avatar
Hi Daniel
I have been looking for an answer regarding the use of a anamorphic lens with W1070. Hopefully someone here may have tried it.
Grant D is offline
post #7674 of 11971 Old 02-05-2014, 09:09 AM
Mr.G's Avatar
Quoted: 612 Post(s)
Liked: 324
Putting a $2000-3000 anamorphic lens on an $800 projector would seem a silly thing to do. You realize you would also need a new 2.35:1 screen for this to work.
That said there are DIY anamorphic lens out there but they are mediocre at best.
All I Really Need to Know I Learned in Kindergarten Movies
Mr.G is offline
post #7675 of 11971 Old 02-05-2014, 09:16 AM
Quoted: 396 Post(s)
Liked: 282
I am aware of the cost as I mentioned such but some of us might want to work our way up to a better projector but figured why not if we had the chance to buy a second hand lens ($800 to 1400) why not use it for the current BenQ so all I am looking for is people who have tried this and maybe post some screens of it.
hagsi likes this.
post #7676 of 11971 Old 02-05-2014, 09:26 AM
Mr.G's Avatar
Quoted: 612 Post(s)
Liked: 324
I was just commenting on how unrealistic this is - however if you manage to accomplish this I'd be very interested in seeing your end product.
Mr.G is offline
post #7677 of 11971 Old 02-05-2014, 11:08 AM
Bassoholic's Avatar
Firmware 1.03
Firmware 1.04
can’t be kept.
Firmware 1.05
Firmware 1.06
Fixes:
Firmware 1.07
Firmware 1.08
or
Service Manuals
Awesome. Thanks dude.
post #7678 of 11971 Old 02-05-2014, 12:49 PM
nonahunjan's Avatar
I have this projector and when I watch tv (1080i) on this projector, the images look very pixelated and unfocused when seeing a large image of say a football game, but it appears clear when zoomed up on the players. Anyone else have this issue or know how to fix it if possible? Thanks. I have tried adjusting the focus and it still looks pixelated. Any help please!!!!
nonahunjan is offline
post #7679 of 11971 Old 02-05-2014, 12:50 PM
Visceral Monkey's Avatar
I've downloaded the 1.08 firmware, can someone point me to a post that explains how to flash it?
Visceral Monkey is offline
post #7680 of 11971 Old 02-05-2014, 01:05 PM
thadius65's Avatar
Before I break down and cry like a baby.... Can someone give me some guidance on a Peerless spyder install on the bottom of my W1070? This mount is the PPA from amazon. Here is a pic:
This is like rubics cube stuff..... I cannot find a video and the instructions are really poor.
Ted
thadius65 is offline
Benq W1070 1080p 3d Projector
