BenQ W1070 : DLP Full HD, 3D Ready with lens-shift for 1000$ - Page 262 - AVS Forum | Home Theater Discussions And Reviews
 1417Likes
post #7831 of 12009 Old 02-15-2014, 07:36 AM
bighvy76's Avatar
Quoted: 23 Post(s)
Liked: 29
3d blurays thru the ps3 have to be set to framepack if u didn't set it that way
bighvy76 is offline
post #7832 of 12009 Old 02-15-2014, 11:12 AM
d19racing's Avatar
My projector auto detects the 3d blue ray from ps3 and sets it to frame packing format 1080p/24hz. But still not the same effect as wat I get with my cable 3d movies on SBS 1080i /60hz.
u think is there any other setting etc ??????
d19racing is offline
post #7833 of 12009 Old 02-15-2014, 12:06 PM
bighvy76's Avatar
Quoted: 23 Post(s)
Liked: 29
Your 3d cable really looks that good? I herd there are other setting on 1.08 upgrade I'm still on 1.05
bighvy76 is offline
post #7834 of 12009 Old 02-15-2014, 01:34 PM
THe_Flash's Avatar
Liked: 25
Blu-Rays are frame packed, it's as simple as that. I don't know why your streamed/cable content would look that superior, most everyone would argue the opposite. I suppose if it were really that important to you, you could rip your 3D Blu-Ray movies to SBS or T&B with DVDFab. I really can't see that being worth it though personally.
THe_Flash is offline
post #7835 of 12009 Old 02-15-2014, 08:40 PM
d19racing's Avatar
I just want to find out if there is any other setting that would help to achieve the effect depth / 3d POP OUT EFFECT via my Blue Ray that I get via 3d cable movies..
Also can anyone giver directions / links on how to upgrade my firmware from 1.6 to 1.8 . Thanks . Dint have clue on how to this.
Also wat does the "Wireless" button on the remote do as when I click if if does nothing...?
post #7836 of 12009 Old 02-15-2014, 09:23 PM
THe_Flash's Avatar
Liked: 25
There are instructions for firmware upgrades littered through this thread, and there is a link to the firmware with the instructions just a few pages back. Search the thread, it's all here.
post #7837 of 12009 Old 02-15-2014, 10:49 PM
filtor's Avatar
Liked: 36
Maybe it's the PS3 ... I find that BD 3D framepacking movies are as good or better than downloaded SBS or T/B movies. My Sony BD player has a 3D depth/pop setting (normal, +1, +2 - or something like that) ... but I keep it on normal. Since you have a Sony device maybe it has a similar 3D setting?
filtor is offline
post #7838 of 12009 Old 02-16-2014, 05:28 AM
d19racing's Avatar
My PS3 does not have any 3d depth/POP Setting at all. Checked it again.
There has to something else...
post #7839 of 12009 Old 02-16-2014, 06:18 AM
d19racing's Avatar
There has to be some setting issue cause how else can I explain that 3D POP OUT EFFECT for 3d movies from my Comcast cable on SBS 1080i/60hz and not having any 3D POP OUT EFFECT when playing 3D BLue Ray movies from my PS3 on FramePacking @ 1080P/24hz ????
Unless movies like Pacific Rim, Avatar, or Tangled have 0 Pop out Effect... But I'm thinking its gotta be something else ????
post #7840 of 12009 Old 02-16-2014, 06:47 AM
CheYC's Avatar
Quoted: 58 Post(s)
Liked: 61
Can't speak for Tangled, but Pacific Rim and Avatar both have very little pop-out, it's all about the depth. If pop-out is what you yearn for, the majority of 3D probably will disappoint you. That being said, there are some great 3D movies with a lot of pop-out, but in my experience, it's mostly the animated flicks.
Basement: BenQ W1070 on 110" Elite Screen, Denon AVR-1913, JBL LC1 (C), JBL L880 (FL/FR), JBL 810 (BR/BL), Rhythmik LV12R Sub, PS3 and Roku 3
Living Room: Vizio M65-E0, Vizio SB3651-e6 Soundbar, PS4, Roku Premier+, and X Box One X coming soon
CheYC is offline
post #7841 of 12009 Old 02-16-2014, 07:02 AM
d19racing's Avatar
But nothing POps Out for me in Pacific Rim & Avatar. Zero Pop outs when played via my PS3.
Since u said that there were at least little pop outs.
On the other hand Pops out all over the when watching 3d movies like Jack the Giant Slayer, Journey to the Mysterious Island 2, Wreck it Ralph, etc from my Via comcast cable.
post #7842 of 12009 Old 02-16-2014, 07:35 AM
bighvy76's Avatar
Quoted: 23 Post(s)
Liked: 29
Have u tried playing the same movie thru ps3 and thru cable to see how they compare ?
bighvy76 is offline
post #7843 of 12009 Old 02-16-2014, 07:39 AM
CheYC's Avatar
Quoted: 58 Post(s)
Liked: 61
Well, if you really are taking me that literal, then no, there is no pop-out in Pacific Rim that I can remember, and maybe one or two scenes from Avatar, and even those weren't that exaggerated. Kids/animated films (like the ones you seen on Comcast) almost always have far more pop-out than other movies. Journey actually probably has some of the best pop-out for a movie out there.
Best suggestion out there is to compare like the above poster said, or watch a movie like Madagascar 3, Rise of the Guardians, or the "fish scene" from IMax Under the Sea on your PS3 setup, then if you see no pop-out, there may be something wrong.
CheYC is offline
post #7844 of 12009 Old 02-16-2014, 10:31 AM
kohawk08's Avatar
Hello everybody, I just bought this projector and am going to buy the Peerless mount based off of the recommendations in this thread. My question is this: based off of the Benq calculator website, it says to mount my projector roughly 12 inches from the ceiling. Will I need to buy an extension for this mount? I'm assuming no, since it has vertical lens shift??? Is this correct? Does anybody have a formula or website which shows when I would need to buy an extension??
Thank you so much for all of the knowledge and expertise that you guys have. I am a total newbie to all of this and I couldnt have done any of my home theatre w/o all of the knowledgable folks on this website.
kohawk08 is offline
post #7845 of 12009 Old 02-16-2014, 10:40 AM
Auric's Avatar
I thought the POP OUT is made by the Special Effects Team who made the Movie, the Software (aka Bluray or Stream) does contain only in two different frames, the Players Job is to decode these two different Frames, the Projectors job is to show these two different Frames
No POP Out in the Movie no POP OUT to watch, regardless of the Source, Player or Display.
THe_Flash likes this.
Auric is offline
post #7846 of 12009 Old 02-16-2014, 11:18 AM
sojourner353's Avatar
Originally Posted by rwestley View Post
Originally Posted by sojourner353 View Post
Hi all,
So interesting issue has just occurred with my projector, it seems HDMI Port 1 has failed, at first I suspected it was my Denon Receiver but after changing to HDMI Port 2 it all works again, the signal on HDMI Port one cuts in and out and at times the Projector says No Signal.
Seems strange because it's been working fine for the past year and I haven't modified my setup in any way, any ideas or anyone else seen this problem? Cheers.
Sent from my HTC One using Tapatalk Pro
The early 1070's had poor HDMI ports that were later changed. I would suggest changing your cable and try again. If it it cutting in and out it seems like a connection issue. Try another cable and be very careful in seating the cable.
Fault found the problem, my receiver is dying, took it out of the circuit and issue goes away, just ran out of warranty too, wonderful! Thanks for the help guys.
sojourner353 is online now
post #7847 of 12009 Old 02-16-2014, 06:43 PM
Golfwhizard's Avatar
What are best 3D glasses for this projector. Thanks
Golfwhizard is offline
post #7848 of 12009 Old 02-16-2014, 07:03 PM
filtor's Avatar
Liked: 36
Opinions vary - but I'm totally satisfied with my Tru Depth 3D Firestorm XL glasses. Don't see how they could be any better. Large, comfortable, go over regular glasses and covers all the screen and much more, no red flash/tint, don't lose sync, not overly dark with great contrast and are rechargeable. Best available in my opinion.
filtor is offline
post #7849 of 12009 Old 02-16-2014, 07:43 PM
post #7850 of 12009 Old 02-16-2014, 09:50 PM
OZReddog's Avatar
Liked: 32
Hi, are you aware that there is a dedicated topic on 3D glasses for the W1070 / W1080ST? You may like to take a look.
http://www.avsforum.com/t/1448720/benq-w1070-144hz-compatible-dlp-link-3d-glasses
OZReddog is offline
post #7851 of 12009 Old 02-16-2014, 11:57 PM
normanu's Avatar
Quoted: 17 Post(s)
What totally sucks is I have it near the sealing on a shelf.
But now I have to lay the projector on its back ....
It can only project or from low to high or upside down from high to low frown.gif
normanu is offline
post #7852 of 12009 Old 02-17-2014, 12:52 AM
fredl's Avatar
Quoted: 29 Post(s)
Why can't you mount it upside down below the shelf?
Just use appropriate nylon distances so the projectors cooling works and long bolts with washers.
fredl is offline
post #7853 of 12009 Old 02-17-2014, 01:21 AM
Escabeche's Avatar
Hi, I updated  firmware version from 1.05 to 1.08, It finished ok but now the red light is always on, and the projector doesn't start after updating.
If I connect it to the Pc using the USB, the PC doesn't detect anything, so I can not repeat the operacion with another firmware version
ups! I doesn't sound well. Has it happened to anyone?
Any idea? Is it possible to reset the flash memory?
Escabeche is offline
post #7854 of 12009 Old 02-17-2014, 01:41 AM
mishari84's Avatar
Quoted: 120 Post(s)
Liked: 25
same issue happened to me. I sent it to Benq and they changed the motherboard
mishari84 is offline
post #7855 of 12009 Old 02-17-2014, 02:49 AM
normanu's Avatar
Quoted: 17 Post(s)
Its on top of a bookcase to be precise....
normanu is offline
post #7856 of 12009 Old 02-17-2014, 03:08 AM
Escabeche's Avatar
Ough :(
did you have any problem with warranty?
post #7857 of 12009 Old 02-17-2014, 08:21 AM
d19racing's Avatar
There has to be some setting issue cause how else can I explain that amazing 3D POP OUT EFFECT for 3d movies from my Comcast cable on SBS 1080i/60hz
And not having Zero 3D POP OUT EFFECT when playing 3D Blue Ray movies from my PS3 on FramePacking @ 1080P/24hz
Unless movies like Pacific Rim, Avatar, or Tangled have No Pop out Effect at all ...
But I'm thinking its gotta be something else ????  Any to do with "Nvidia card or FramePacking @ 1080P/24hz setting" in projector/ or any other PS3 setting ?
Using True Depth 3D Glasses, work very well on the cable format atleast.... ?
post #7858 of 12009 Old 02-17-2014, 08:29 AM
gamermwm's Avatar
Quoted: 84 Post(s)
Liked: 93
I believe it is because of the lower resolution in SBS 3D (vs. True 1080p Framepacked). When I looked into the 3D Bee 2D-3D converter, they note that 720p content in 3D will have ~30% stronger depth/popout than 1080p
What is the meaning of life?
www.iamsecond.com/films
gamermwm is offline
post #7859 of 12009 Old 02-17-2014, 08:48 AM
CheYC's Avatar
Quoted: 58 Post(s)
Liked: 61
Again, purchase a blu ray that you know has significant popout and test it (ones that you've already seen on comcast or the ones I quoted earlier). The films you're listing there have VERY little to no pop out from what I recall. There is no setting on the PS3 that will change what you're seeing right now. I have a PS3 as my blu ray player and have no problems with 3D.
fredxr2d2 likes this.
CheYC is offline
post #7860 of 12009 Old 02-17-2014, 12:31 PM
d19racing's Avatar
Thanks again CheYC, & all other who have provided helpful insight towards my issue.
I shall do as advised. Will buy Journey to the Mysterious Island 2 on 3D Blue Ray and see if it plays the same way (displays 3D Pops Pout Effect) as it does when played from my Comcast Cable.
Will post my findings after comparing them.
Benq W1070 1080p 3d Projector
