BenQ W1070 : DLP Full HD, 3D Ready with lens-shift for 1000$ - Page 269 - AVS Forum | Home Theater Discussions And Reviews
 388Likes
post #8041 of 11920 Old 03-19-2014, 07:12 AM
Desisuperman's Avatar
Quoted: 32 Post(s)
Originally Posted by Desisuperman
I have a question regarding the PC Signal option under HDMI options.
For my HTPC, I have Dynamic Range set to Full 0-255, Pixel Format YCBCR 4:2:2
Projector HDMI Settings is set to PC Signal
Does this make sense? Do have it setup correctly ? Thanks in advance for the help
Originally Posted by RLBURNSIDE View Post
Put your HTPC in ycbcr 4:4:4 instead, apparently the greyscale tracking on the w1070 is better when fed that type of signal. I noticed a difference, but I've never properly calibrated mine. Someone else want to put up a link with the review from that calibrator who discovered this? This thread is huge, and I'm too lazy right now. Sundays and all...smile.gif
Thanks RLBURNSIDE. Switched ycbcr to 4:4:4
What about Dynamic Range on my PC? Should I leave it at full? I have tried PC signal and Video signal settings on the projector and I find with it on PC signal the picture has got a white washed look to it. I'm going to assume PC signal is Full Range 0-255 and Video Signal is limited range 16-235. Is this correct?
I've set the projector to Video Signal so should I leave dynamic range to full on the HTPC and let the projector handle it or do I match the signal and put it on limited ?
Desisuperman is offline
post #8042 of 11920 Old 03-19-2014, 09:56 AM
mgp32's Avatar
Schmidtwi,
I don't normally write reviews but since I was so impressed with the image qaulity of this projector I felt I needed to take the time to write a quick review, I even took some pics to help others their decision. As you can see, Im in the middle of finishing my basement and don't have time to ready through 269 pages. All I was looking for was some info that would be easy to pass on for a guy/gal that has had some time with this projector.
mgp32 is offline
post #8043 of 11920 Old 03-20-2014, 01:45 AM
dryasanne's Avatar
Quoted: 28 Post(s)
Have left the windows universe decades ago...
dryasanne is offline
post #8044 of 11920 Old 03-20-2014, 07:39 AM
TLJester's Avatar
Thats a shame - i have noticed (as others have reported) huge improvements in image, color, HDMI locking, 3D frequencies etc
I was VERY worried to upgrade. My firmware was 1.02. However after reading, and reading, and reading again i took the plunge.
My main relief from anxiety was just getting the DLP Comp app talking with the Projector. Once i was happy with that, i then tried booting into UPLOAD mode (RED LED light). Also i kept MD5 checking the firmware i downloaded...
Once i did all of that several times. re-read the flashing guide again i hit the START button and let it do its thing. No worries once it started. I left it for a LONG time to turn ORANGE - rebooted - had a panic attack, then remembered to set the source to AUTO DETECT - anxiety left - projector is OK - the world is good again smile.gif
TLJester is offline
post #8045 of 11920 Old 03-20-2014, 03:25 PM
hitman6079's Avatar
I'm about to pull the trigger and buy this projector but now I'm a little concerned with all this firmware and RBE talk. Hope I don't regret this purchase.......
hitman6079 is offline
post #8046 of 11920 Old 03-20-2014, 03:57 PM
sojodave's Avatar
Quoted: 16 Post(s)
Liked: 56
Nothing to be nervous about. The upgrades are easy to do and you will love your new projector. I have 2,500 hours with no problems.
sojodave is offline
post #8047 of 11920 Old 03-20-2014, 03:58 PM
Bachelor's Avatar
Quoted: 40 Post(s)
Liked: 38
It has been a huge improvement in my hardware. I don't have any regrets only that I wished I would have pulled the trigger a year ago when I first had my eye on one. I think you'll enjoy it too.
Bachelor is offline
post #8048 of 11920 Old 03-20-2014, 05:27 PM
Daniel Chaves's Avatar
Quoted: 387 Post(s)
Liked: 276
Not sure if this has been answered but if you flash to a newer firmware, I am assuming your lamp time gets reset?
Projector: BenQ w1500 + ES Sable 135" Screen AVR: Onkyo TX-NR646 ATMOS/DTSX + Darbee 5000
Speakers: Polk Audio TSX550t (FL/FR), CS2 Series II (C), Monitor40 Series II (RL/RR),
Onkyo THX Bookshelf Speakers (Ceiling L/R), (2) JL Audio 12" Subs + (2) Dayton 15" Subs + (2) ButtKicker LFE
Arrangement: 5.1.2 Source: HTPC, Roku 4, Nexus Player, Samsung UBD-K8500 4k Bluray Player
Daniel Chaves is offline
post #8049 of 11920 Old 03-20-2014, 05:28 PM
wormraper's Avatar
Quoted: 313 Post(s)
Liked: 154
please forgive the newbish question, but how reliable are Benq's???? I'm seriously considering the 1070 since I want a 3D projector from my 8350 Epson, but the 1 year warranty makes me slightly nervous
wormraper is online now
post #8050 of 11920 Old 03-20-2014, 05:32 PM
THe_Flash's Avatar
Liked: 25
Yes.
THe_Flash is offline
post #8051 of 11920 Old 03-20-2014, 05:40 PM
Quoted: 387 Post(s)
Liked: 276
Originally Posted by THe_Flash View Post
Yes.
yeah I figured as much, I am still on the fence since I am on 1.06 on if I really should upgrade to 1.08 since it seems the color on the green side of the scale seems to be the only thing that improves and even then not sure if thats even a big enough change to make it worthwild. ^^;
post #8052 of 11920 Old 03-20-2014, 05:45 PM
THe_Flash's Avatar
Liked: 25
I'm on 1.06 too and haven't bothered, and probably won't. Tweaking the green sounds good, but I'd then assume any settings you're used to using (Withers, Sound & Vision, etc.) are no longer valid. If you calibrate yourself maybe this isn't a big deal.
Daniel Chaves likes this.
post #8053 of 11920 Old 03-20-2014, 05:51 PM
rwestley's Avatar
Quoted: 144 Post(s)
Liked: 97
If you are on 1.06 you are probably fine. You could always fine tune the color yourself. 1.06 was important for improving the HDMI handshake.
rwestley is offline
post #8054 of 11920 Old 03-20-2014, 05:53 PM
kreeturez's Avatar
Quoted: 466 Post(s)
Liked: 350
Agreed; I did this same update (1.06 to 1.08) and found it a bit of a waste of time.
Even posted the good excuses for firmware updates that I've found. 1.08 wasn't on the list wink.gif
With fast HDMI source-detection and full 3D-timing support, 1.06 was already excellent.
BenQ HT2050 Projector; Kodi (on Ubuntu, OpenELEC & S802) via Sony STR-DH540 AVR with Boston Acoustics SoundWare XS SE 5.1 Audio + Jamo 210 Sub. Emby for Mobile Streaming.
Helpful post? Click the 'Like' button!
kreeturez is offline
post #8055 of 11920 Old 03-20-2014, 06:01 PM
kreeturez's Avatar
Quoted: 466 Post(s)
Liked: 350
1-year warranty is pretty standard at this price point. I believe one of the main reasons for longer warranties from Epson is because the LCD panels used in their 3LCD's are susceptible to dust blobs - which isn't an issue with DLP's.
1400 hours here after about a year of daily use; no issues so far. At all.
If you purchase new; you'll probably get recent firmware anyway so no need to worry about that.
If you run into RBE issues (not all that likely for most people); there are solutions (ND filters, adjusting refresh rate, etc).
I highly doubt you'll regret your purchase. And worst case? You can always do a return.
post #8056 of 11920 Old 03-20-2014, 06:03 PM
wormraper's Avatar
Quoted: 313 Post(s)
Liked: 154
gotcha, I guess I was used to my 2 year epson warranties that I got a little spoiled. wish I'd have seen last months $779 deal on this baby. that would have been a big duuuuuh for me.. frown.gif unless anyone knows where it's cheapest right now (from an authorized retailer)
oh, and I almost forgot. how forgiving is the lens shift? I know the epson is NUTS for it's awesome flexibility, but I put my pj at about the top edge of the screen about dead center (ish)... so as long as it doesn't have a crazy offset like the Mits 7900 I'm assuming I should be good
post #8057 of 11920 Old 03-20-2014, 06:12 PM
kreeturez's Avatar
Quoted: 466 Post(s)
Liked: 350
Not all that forgiving... but at the positioning you specify (dead center of screen; at top edge) you're already perfectly positioned. Offset range is from about lens-height; to a few inches downwards (if ceiling-mounted) or a few inches upwards (if table-mounted).
post #8058 of 11920 Old 03-20-2014, 06:12 PM
hitman6079's Avatar
Thanks for the replies everyone!
post #8059 of 11920 Old 03-20-2014, 06:14 PM
wormraper's Avatar
Quoted: 313 Post(s)
Liked: 154
nice, that's about what I like.. a few inch offset. I can adjust my pj up a few inches from where it's at too so that sounds fine.. I'm really tempted. I just need to see if anyone has it for less than the $899 it is now ....I like my 8350 but I've heard the 1070 throws a better picture AND it is 3d...
post #8060 of 11920 Old 03-20-2014, 06:17 PM
Patty2720's Avatar
Hi guys,
I have a few questions as a first time buyer.
- Which screen is best for the W1070, white or grey? AND high or low gain?
- Is it wise to go with a 85 inch, when my room is only 218 mm wide ?
The screen will be 15 cm from the wall on both sides. Will this cause major problems for me?
Patty2720 is offline
post #8061 of 11920 Old 03-20-2014, 06:29 PM
wormraper's Avatar
Quoted: 313 Post(s)
Liked: 154
Originally Posted by Patty2720 View Post
Hi guys,
with the brightness level you'll be fine with either white or grey, but a 1.1 gain white screen would do very well with those lumens
85 inch is fine with that distance from the wall as long as you can paint the walls a flat dark color..otherwise you're gonna get some nasty reflections washing out those nice contrast levels
post #8062 of 11920 Old 03-20-2014, 06:39 PM
Patty2720's Avatar
Actually, my projector will be placed 3½-4 meters from the screen.
Okay, just to make sure, so you recommend a 1.1 gain white screen?
I'll make sure to do that :)
post #8063 of 11920 Old 03-20-2014, 08:32 PM
rolling01's Avatar
Quoted: 23 Post(s)
My lamp hours were not reset.
rolling01 is offline
post #8064 of 11920 Old 03-20-2014, 09:49 PM
flint723's Avatar
Mine were not reset either, going from 1.05 to 1.08.
flint723 is offline
post #8065 of 11920 Old 03-20-2014, 10:48 PM
N2Sand's Avatar
@Patty2720 - Check the projector calculators to make sure the 1070 will produce an 85" image at 3.5-4 meters. Mine is at 11 feet (within your range) producing a 120" image. You may very well be fine but that just seems small for that distance so double check.
N2Sand is offline
post #8066 of 11920 Old 03-21-2014, 01:10 AM
Ceremony's Avatar
yeah, im getting 90" at around ~3m at 1.0 zoom
Ceremony is offline
post #8067 of 11920 Old 03-21-2014, 01:19 AM
Quoted: 387 Post(s)
Liked: 276
post #8068 of 11920 Old 03-21-2014, 02:12 AM
Patty2720's Avatar
Change of plans, my girlfriend now wants me to put it into our bedroom, which is nice because there is MUCH more space. So time for some new questions :p
- What screen should I choose to my W1070? We have some (don't know the word) curtains that makes our bedroom pitch black when drawn, so sunlight isn't an issue.
- The W1070 will be placed 11 feet from the screen, and we will sit 10 feet from the screen, is a 100 inch screen to big?
- On a scale 1-10 how good is the 3D, when sitting 10 feet from a 100 inch?
- Which is the best 3D movie you've seen on the W1070?
- Is it good for gaming?
post #8069 of 11920 Old 03-21-2014, 06:01 AM
Ceremony's Avatar
- dunno, i use a cheap rolloscreen, which slightly curls at the corners (crap), but thats ok. simple matte white with a gain of 1.0
- http://i.imgur.com/fIqy71S.jpg and should be alright. just make sure that the height is good (eyes roughly in the mid of the screen). looking up or down is not nice.
- dunno, dont use 3D
- dunno
- I only played metroid prime (via dolphin @ 1080p): looks awesome, plays very well too. dunno about input delay (reviews state around 25-30ms), but for offline games, it will be awesome!
Ceremony is offline
post #8070 of 11920 Old 03-21-2014, 07:06 AM
wormraper's Avatar
Quoted: 313 Post(s)
Liked: 154
one more question to bug people with. how are the black levels on the W1070 vs. the Epson 8350??? I know I like a DLP image for color "pop" more than the epson (almost bought the Optoma HD20 back in the day when I was deciding on the 8350 vs dlp debate) but I know the 8350 was known for having really good black levels..but then again that was 2.5 years ago
Benq W1070 1080p 3d Projector
