BenQ W1070 : DLP Full HD, 3D Ready with lens-shift for 1000$ - Page 276 - AVS Forum | Home Theater Discussions And Reviews
 376Likes
post #8251 of 11879 Old 04-04-2014, 07:57 PM
AV_Integrated's Avatar
Quoted: 916 Post(s)
Liked: 688
Originally Posted by bori View Post
So do you guys recommend putting up screen first before projector?
The only time the screen shouldn't go up first is if that screen needs to be in a place which may not work with the height of the projector. The W1070 has limited lens shift, so ceiling mounting placement is crucial.
Just measure the height from the top of the mount to the center of the lens (about 7" or so) and make sure the top of the screen is about 2" lower than the center of the lens. If you WANT the screen lower, then put it lower and drop the mount the appropriate distance.
ellisr63 likes this.
AV Integrated - Theater, whole house audio, and technology installation in the Washington DC metro area.
AV_Integrated is online now
post #8252 of 11879 Old 04-04-2014, 08:22 PM
PrimeTime's Avatar
Quoted: 521 Post(s)
Liked: 232
Originally Posted by drjay71 View Post
I would say the Sony is clearly better in PQ but obviously not 3x better even though the Sony is 3x the cost of the BenQ. IMHO the Sony is about 10-15% better in PQ and I would guess that is much more apparent when you compare side by side.
Unless you're constantly watching Space Operas, I doubt if there's even that much difference.
PrimeTime is offline
post #8253 of 11879 Old 04-04-2014, 08:34 PM
Quoted: 916 Post(s)
Liked: 688
I expect there is that much difference. There certainly is between the JVC and the BenQ, or the Epson or Panasonic models. I've seen the Sony 600ES (4K) and it was the best looking image I've seen on screen. The JVC is comparable in black levels, but not overall quality. The BenQ isn't the same level. It's just not. The W1070 is a solid entry level projector, but the color, black level, and shadow detail of the JVC just is better.
post #8254 of 11879 Old 04-05-2014, 03:11 AM
lsdec's Avatar
Quoted: 178 Post(s)
Liked: 116
Agreed. That 600 ES is just amazing...it's good to know that my next projector will be that awesome in a few years smile.gif.
BenQis very nice for its price. It's a simple question of can I live with this picture and the answer is "gladly!" For me. Still can't believe for $900, I can get a 110" picture like this.
lsdec is offline
post #8255 of 11879 Old 04-05-2014, 08:09 AM
butie120's Avatar
Quoted: 198 Post(s)
Liked: 61
I'm hoping to have my Benq ceiling mounted with the Chief RPAU this evening. Will post some pics once complete!
butie120 is offline
post #8256 of 11879 Old 04-05-2014, 12:43 PM
jarablue's Avatar
Quoted: 13 Post(s)
If it is ceiling mounted, how far down does the picture get displayed on the screen? The projector calc doesn't tell you that. On the W1080ST it shows 2 inches. But there is no measurement for the W1070.
jarablue is offline
post #8257 of 11879 Old 04-05-2014, 01:41 PM
butie120's Avatar
Quoted: 198 Post(s)
Liked: 61
I could be wrong on this, but I think there is probably less offset on the 1070 since the optical system is different between the two projectors. I actually own the 1080ST, not the 1070. But, I thought I would post in this forum regarding the Chief RPAU mount because there's been a lot of discussion about which mount is best and how to ceiling mount it.
butie120 is offline
post #8258 of 11879 Old 04-05-2014, 06:51 PM
flint723's Avatar
At 10'6" throw and 120" screen I can adjust from about 1" below the lens to about 7" below.  Shorter throws and/or smaller screen sizes will have less adjustment.
flint723 is offline
post #8259 of 11879 Old 04-05-2014, 09:19 PM
butie120's Avatar
Quoted: 198 Post(s)
Liked: 61
So I got my 1080ST mounted this evening using the Chief RPAU. I can say that this mount is solid as a rock. It doesn't budge...at all. I know the true test will be over time, but I have no concerns whatsoever. I will say this would be one hell of a job mounting this by yourself. I'm sure you could do it, but it's far simpler with an extra set of hands. Here are a few pictures of the projector mounted. I still need to finish painting the plywood, using some spackle over the screws, some sanding on the corners, etc.
butie120 is offline
post #8260 of 11879 Old 04-05-2014, 10:24 PM
filtor's Avatar
Liked: 36
filtor is offline
post #8261 of 11879 Old 04-05-2014, 10:29 PM
Quoted: 916 Post(s)
Liked: 688
Man, look at that light leakage onto the ceiling.
post #8262 of 11879 Old 04-05-2014, 10:52 PM
blee0120's Avatar
Quoted: 350 Post(s)
Liked: 182
Actually, the jvc is much better at black levels than the 600es and the pq is better on the jvc too
blee0120 is online now
post #8263 of 11879 Old 04-06-2014, 03:20 AM
jarablue's Avatar
Quoted: 13 Post(s)
Is it possible with the W1070 to fill up a 135 inch screen at a 11'8 ft throw?
I think I should go with a 120 inch screen. But my heart is set on a 135" incher. Zooming in doesn't hurt PQ does it?
jarablue is offline
post #8264 of 11879 Old 04-06-2014, 03:38 AM
wormraper's Avatar
Quoted: 313 Post(s)
Liked: 154
you can have a 135 inch screen at 11 feet 4 inches...
wormraper is offline
post #8265 of 11879 Old 04-06-2014, 05:07 AM
bori's Avatar
Quoted: 186 Post(s)
Liked: 124
I bought a elite screen 100H. Is it recommended to leave the screen down for a certain amount of time when you first open it? Also for the people that have elite screens do you have any issues with the screen when scrolling down making a knocking sound every few seconds?
bori is offline
post #8266 of 11879 Old 04-06-2014, 09:09 AM
bluer101's Avatar
Quoted: 287 Post(s)
Liked: 218
I left mine down for a few days to get rid of the smell and to straighten out some. I do still have some waves but cannot see them 99% of the time viewing. I do know if I have it up for a week or so then put it down I get the side curling on the black border only. After a few hours it goes almost away.
I get a slight click when the screen goes up and down. Not bad for the $179 I paid.
Projector & Screen: Benq W1070 Elite Screens 100" Electric Video: Oppo 103d Audio: Denon 4520ci Speakers: Infinity RS5 (LW L C R RW) Infinity RS1 (LH RH) Infinity Beta ES250 (SL SR) Subwoofers: 2 SI18d4 Martycubes with iNuke3000dsp and 2 Infinity BU120 Shakers: 4 ADX shakers with Dayton SA230 amp
My Builds--Media console build----Martycube build----ADX Bass Shaker Install
bluer101 is offline
post #8267 of 11879 Old 04-06-2014, 09:35 AM
bori's Avatar
Quoted: 186 Post(s)
Liked: 124
I have read on Amazon reviews the there screen is perfectly quiet. I wonder if the knocking or clicking sound is then same like yours. Anymore elite owners screen willing to chime in on this one? I want to know if only need to return it.
bori is offline
post #8268 of 11879 Old 04-06-2014, 09:53 AM
ellisr63's Avatar
Quoted: 964 Post(s)
Liked: 404
If it is not perfectly quiet and all the reviews say it is perfectly quiet... I would return it to Amazon and get a new one. If it is defective you pay no shipping fees.
Yamaha CX-A5100, (3) JBL 2360As/EV DHA-1s, (3) 1/4 Pie bass bins, 4 JBL 8340As, 4 JBL 8320s, PS3, XBoxOne, 2 Intel NUCs, Monoprice speaker wire, and XLR cables, Redmere HDMI cables, Monster HTPS7000, 2 Furman filters, 2 DTS-10 subs, Panasonic AE8000, SeymourAV 195" diagonal scope screen, Panamorph UH-480, Darbee Darcet, Yamaha P7000s, (2) Crest Audio CM2208s, Yamaha XM-4080, (2) MiniDSP DDRC-88.
The Ellis Family Go Big or go Home HT
ellisr63 is offline
post #8269 of 11879 Old 04-06-2014, 10:48 AM
bori's Avatar
Quoted: 186 Post(s)
Liked: 124
Yes I know I think I am going to do that.
bori is offline
post #8270 of 11879 Old 04-06-2014, 03:39 PM
AaronPSU79's Avatar
I think it's easier to install the projector first and then the screen. The W1070 only has vertical lens shift, so if you put the screen up first positioning of the projector is critical. If you are off, even an inch, your picture will not be perfectly square and you're going to have to go back and move the projector. On the other hand if you mount the projector first you can get it aligned just by shining it on the wall or something, then you can position the screen exactly where it needs to go.
The only time I would install the screen first is if the screen has to go in a fixed position, with no real flexibility. Then you might as well set it up first.
AaronPSU79 is offline
post #8271 of 11879 Old 04-06-2014, 06:05 PM
bori's Avatar
Quoted: 186 Post(s)
Liked: 124
Thats my fear is gegetting projector aligned correctly. I have read people place projector on table first set it up there before ceiling mount. My question is when doing it this way do flip the projector upside down on the table? Cause it's going on the ceiling like that. Correct me if I am wrong.
bori is offline
post #8272 of 11879 Old 04-06-2014, 06:58 PM
ellisr63's Avatar
Quoted: 964 Post(s)
Liked: 404
I think when people put it on a table first, they are just trying to get an idea of where the projector will need to be for a given size screen. If you want to test it out on a table first... Do not set the projector as "ceiling", and just look at the picture the way it is. Don't forget that the BenQ w1070 does not have much of a lens shift, so you would most likely be better off putting it on the floor or maybe a very short table (if you are going for maximum size).
ellisr63 is offline
post #8273 of 11879 Old 04-06-2014, 07:01 PM
bori's Avatar
Quoted: 186 Post(s)
Liked: 124
Is there any really good video tutorial on getting this set up as easy as possible? I have my screen up just waiting on projector.
bori is offline
post #8274 of 11879 Old 04-07-2014, 06:39 AM
Rew452's Avatar
Quoted: 99 Post(s)
Liked: 57
Originally Posted by Rew452 View Post
Hi all,
A few months back someone had posted a pictorial that showed dis-assembly of the w1070 to clean the dust out of the light engine. I had it bookmarked but have somehow lost it.
Does anyone have the link?
Rew
No one????
Rew
Vizio P75-C1 | BenQ HT2050 |Lumagen RadianceXS-3D |Panasonic BDT460 | Samsung UBD-K8500
Denon AVR-x5200w | Nvidia Shield Android TV | C =Axiom VP150 |FL/FR =Axiom M60 |SL/SR =Axiom QS4 |TFL/TFR =Bose 161 | TRL/TRR =Bose 161 |Sub =Reaction Audio S-15 500W SEALED SUBWOOFER
Rew452 is online now
post #8275 of 11879 Old 04-07-2014, 07:03 AM
butie120's Avatar
Quoted: 198 Post(s)
Liked: 61
Are you referring to the screen or a mount?
Edit: Just realized you said you have your screen up. So setting up the projector in terms of settings, or getting the mount up?
butie120 is offline
post #8276 of 11879 Old 04-07-2014, 08:19 AM
hoogs's Avatar
Quoted: 24 Post(s)
This projector is pretty amazing for the price. I had a PT-AE7000U since 2011 and the bulb was going out. I attempted twice to replace the bulb, but each replacement looked super DIM and I was frustrated. I decided to look around at the new projectors and landed on this one due to the gaming lag or lack thereof. I purchased the projector last week and got it mounted it up on the ceiling. WOW the picture is bright and looks just as good if not better than the 7000U IMO. I was floored at the response time and how clear the picture was when hooked up to my PC, literally night and day. For example in XBMC I also had a ton of mouse lag, etc. When I booted up XBMC I couldn't believe how much faster it was. Needless to say, I am selling my 7000U and not looking back. Not to mention the 3D performance blows the Panny out of the water!
hoogs is offline
post #8277 of 11879 Old 04-07-2014, 05:37 PM
bluer101's Avatar
Quoted: 287 Post(s)
Liked: 218
I have a question. Does the PJ handle 1080p 24 natively? The reason I ask is it shows it in the upper corner what it's receiving but it can be changing it to 1080p 60. I also notice some jitter at 24 vs turning it off on my blu ray player. Then it feeds it 1080p 60.
bluer101 is offline
post #8278 of 11879 Old 04-07-2014, 07:38 PM
Daniel Chaves's Avatar
Quoted: 368 Post(s)
Liked: 259
Projector: BenQ w1500 + ES Sable 135" Screen AVR: Onkyo TX-NR646 ATMOS/DTSX + Darbee 5000
Speakers: Polk Audio TSX550t (FL/FR), CS2 Series II (C), Monitor40 Series II (RL/RR),
Onkyo THX Bookshelf Speakers (Ceiling L/R), (2) JL Audio 12" Subs + (2) Dayton 15" Subs + (2) ButtKicker LFE
Arrangement: 5.1.2 Source: HTPC, Roku 4, Nexus Player, Samsung UBD-K8500 4k Bluray Player
Daniel Chaves is offline
post #8279 of 11879 Old 04-08-2014, 10:33 AM
THe_Flash's Avatar
Liked: 25
Curious to know who is using 4:4:4 color with HDMI set to PC Signal, as was recommended in an online review. I've calibrated my greyscale with 4:4:4 on both PC and Video. While PC does seem to give better shadow details, the blacks on video appear to be a little darker. Just wondering what everyone else is using.
THe_Flash is offline
post #8280 of 11879 Old 04-08-2014, 03:05 PM
bori's Avatar
Quoted: 186 Post(s)
Liked: 124
Got my projector now the exciting part starts. Hopefully I can get it set up right. I bought the refurbished one and the packaging looks brand new.
bori is offline
Benq W1070 1080p 3d Projector
