BenQ W1070 : DLP Full HD, 3D Ready with lens-shift for 1000$ - Page 277 - AVS Forum | Home Theater Discussions And Reviews
 391Likes
post #8281 of 11954 Old 04-08-2014, 04:09 PM
bluer101's Avatar
Quoted: 347 Post(s)
Liked: 279
Originally Posted by bori View Post
Got my projector now the exciting part starts. Hopefully I can get it set up right. I bought the refurbished one and the packaging looks brand new.
Just put it somewhere and project it on a wall. I did this but with a king size sheet. We watched it this way for a few days.
Projector & Screen: Epson 5040ub Elite Screens 100" Electric Video: Oppo 103d Audio: Denon 4520ci Speakers: Infinity RS5 (LW L C R RW) Infinity RS1 (LH RH) Infinity Beta ES250 (SL SR) Subwoofers: 2 SI18d4 Martycubes with iNuke3000dsp and 2 Infinity BU120 Shakers: 4 ADX shakers with Dayton SA230 amp
My Builds--Media console build----Martycube build----ADX Bass Shaker Install
bluer101 is offline
post #8282 of 11954 Old 04-08-2014, 04:32 PM
bori's Avatar
Quoted: 187 Post(s)
Liked: 125
I have the projector screen up already
bori is offline
post #8283 of 11954 Old 04-08-2014, 06:49 PM
bluer101's Avatar
Quoted: 347 Post(s)
Liked: 279
Then hang it an enjoy.
bluer101 is offline
post #8284 of 11954 Old 04-08-2014, 07:45 PM
lsdec's Avatar
Quoted: 178 Post(s)
Liked: 116
It's very easy to setup. I agree with the refurb - what a deal!
lsdec is offline
post #8285 of 11954 Old 04-08-2014, 09:46 PM
DekPM19's Avatar
Quoted: 115 Post(s)
Liked: 34
I am looking at trying a pj and screen in my bonus room and I would like to do it for less than $1500. This pj looks like a good place to start and see if I will like it. The room is 15 x 21 and I am looking at a 100" to 114" screen. I don't have light control as of now but will add black out curtains for now. If I like a pj set up I have plans for down the road to have full light control. My main question is what is the best screen for the 1070 pj to get in the size I am looking at.
Allen
DekPM19 is offline
post #8286 of 11954 Old 04-08-2014, 09:48 PM
DekPM19's Avatar
Quoted: 115 Post(s)
Liked: 34
O by the way don't care about 3d want to watch sports movies tv shows and I don't game but I bet my kids would love to on a big screen.
Allen
DekPM19 is offline
post #8287 of 11954 Old 04-08-2014, 11:47 PM
preed88's Avatar
Any idea on when they will have some refurbs in stock?? I missed the deal and even benq is out of stock. Do they refill periodically? Thanks
preed88 is offline
post #8288 of 11954 Old 04-09-2014, 02:29 AM
bori's Avatar
Quoted: 187 Post(s)
Liked: 125
Deleted
bori is offline
post #8289 of 11954 Old 04-09-2014, 03:30 AM
bori's Avatar
Quoted: 187 Post(s)
Liked: 125
When using the tip above and from the link. Are we attaching the string to the corner where the white and black border meet?
http://www.avsforum.com/t/440027/mounting-tips#post_4274616
Sent from the TermiNOTEr 2! ;-)
bori is offline
post #8290 of 11954 Old 04-09-2014, 05:11 AM
detzx's Avatar
How adjustable in the W1070 as far as tilt, zoom, etc? I have an odd setup and I'm trying to run the wires before everything gets here but I'm worried everything will be off by a few inches and I'll have to move it.
My room.
The screen should be about 1' off the wall since there is another tv behind it. The screen is an Elite 125" electric drop down so one of the variables is "top of screen" since when I hang this I'm not sure where the top of the screen will be. Next I have a mount that doesn't change vertically so I might have to add spacers to make it hang lower.
So, back to my original question. Should I just do my best guess using the calculator to where the projector will be and put the wires near there and hope the projector and adjust if I need to move it up/down, side/side, tilt?
Edit: Just found another variable. The lens is not centered so I have to move the projector over a little to make the lense centered?
Another question: My mount allows for about 3" of horizontal movement, should I make it so I can move it side to side or back to back? What does the project do and I'll do the opposite with the mount?
detzx is offline
post #8291 of 11954 Old 04-09-2014, 06:39 AM
bluer101's Avatar
Quoted: 347 Post(s)
Liked: 279
My room.
If you mount goes side to side then you want that adjustability. Just follow the calculator. Your zoom in and out will take care of the front to back as long as you put it between the 2 measurements the calculator gives you. Meaning with full zoom and no zoom will tell you max and min from your size screen. Also keep in mind for some error.
Yes, you need to compensate for center of lens so adjust over before mounting. Every calculation is from center if lens. In the w1070 is all the measurements from lens to outside body if needed.
As for projector height. This is where I waited to mount everything. I have a 100 elite motorized. If I mounted it directly to my ceiling it would be to high, 8 ft ceiling. I mounted the screen to a board with spacers to bring the screen down. I did this with elite screens measurements. Well needless to say I had an old PDF for measurements and when I put the screen down for the first time it was 3-4 inches higher than where I wanted it. So after I built longer spacers to bring the screen lower. Just like you mine comes down in front of my tv and 1/2 inch off my tv console.
So just be prepared for some changes maybe. I was following the 1/3 screen viewing rule and if I did not move it down I was looking more up like in the front row of a theater. I do not like that. Also when watching 3d it made the depth look like it was going up into the screen as if you are sitting in the floor. You can try it out after you get setup and see for yourself.
Good luck.
BTW: this was my first install ever with a pj and screen. It has been the best money spent for our family and friends. This really makes the whole movie experience.
bluer101 is offline
post #8292 of 11954 Old 04-09-2014, 07:13 AM
butie120's Avatar
Quoted: 366 Post(s)
Liked: 74
Projector Supercenter has a refurb for $749. That's where I bought my 1080ST from.
butie120 is online now
post #8293 of 11954 Old 04-09-2014, 07:14 AM
wormraper's Avatar
Quoted: 314 Post(s)
Liked: 156
so does projector people
wormraper is online now
post #8294 of 11954 Old 04-09-2014, 08:24 AM
butie120's Avatar
Quoted: 366 Post(s)
Liked: 74
I don't think they do. It's not listed on their website.
post #8295 of 11954 Old 04-09-2014, 08:26 AM
wormraper's Avatar
Quoted: 314 Post(s)
Liked: 156
Sorry. Its a demo model
post #8296 of 11954 Old 04-09-2014, 02:59 PM
bori's Avatar
Quoted: 187 Post(s)
Liked: 125
Ok here is a pic of the dimensions I put in the BenQ calculator. I need your help to determine how high do I mount projector from top of screen? I have a RPM chief mount that I wanted to directly mount to ceiling. But want to make sure I am doing this right. Cause if I do that I cant adjust height.
bori is offline
post #8297 of 11954 Old 04-09-2014, 03:48 PM
bori's Avatar
Quoted: 187 Post(s)
Liked: 125
I ordered this splitter let me know if anyone is using it or that its ok for this projector.
http://www.amazon.com/gp/product/B004F9LVXC/ref=oh_details_o00_s00_i00?ie=UTF8&psc=1
bori is offline
post #8298 of 11954 Old 04-09-2014, 03:53 PM
filtor's Avatar
Liked: 36
Should work fine - I have a different/smaller/older model of ViewHD splitter and it passes 3D just fine - can even run TV while pj is on at same time. A powered splitter is the feature needed and that one has it.
bori likes this.
filtor is offline
post #8299 of 11954 Old 04-09-2014, 04:49 PM
wootpiggy's Avatar
I also bought the refurbished model for $677 but I thought I'd mention to keep an eye out on ebay as well. BenQ sells directly on there just like they do on their site and amazon. I personally bought mine from amazon but they stayed in stock on ebay for much longer.
I bought mine on 3/23 (Sunday) and it was delivered 3/28 (Friday). During the time between buying the projector, I went out and bought all the supplies and built a screen out of Do-Able board since it seemed the quickest and least expensive. I put together a post showing all of what I did.
http://www.avsforum.com/t/617173/the-official-untreated-do-able-only-thread/1100_100#post_24589203
wootpiggy is offline
post #8300 of 11954 Old 04-09-2014, 04:52 PM
bluer101's Avatar
Quoted: 347 Post(s)
Liked: 279
What you listed means that from lens to ceiling will be 7 inches. Then from ceiling to top of screen will be 9 inches. The bottom of the screen will be 33 inches off the ground. Then you have lens shift that can allow the screen to be further down from 9 inches.
I forgot which screen you have. Measure and see from actual viewing area to ceiling and actual viewing area to floor. Meaning the edge of the screen. Also how far away from the screen are you mounting?
bluer101 is offline
post #8301 of 11954 Old 04-09-2014, 05:28 PM
bori's Avatar
Quoted: 187 Post(s)
Liked: 125
When talking about the bottom. Is it including the black border?
bori is offline
post #8302 of 11954 Old 04-09-2014, 05:28 PM
bori's Avatar
Quoted: 187 Post(s)
Liked: 125
bori is offline
post #8303 of 11954 Old 04-09-2014, 05:47 PM
N2Sand's Avatar
No, bottom of the screen refers to the bottom of the viewable (white) area.
N2Sand is offline
post #8304 of 11954 Old 04-09-2014, 05:54 PM
bori's Avatar
Quoted: 187 Post(s)
Liked: 125
Those are the numbers I put in the picture.
bori is offline
post #8305 of 11954 Old 04-09-2014, 06:12 PM
bluer101's Avatar
Quoted: 347 Post(s)
Liked: 279
Yep!
bluer101 is offline
post #8306 of 11954 Old 04-09-2014, 06:13 PM
DekPM19's Avatar
Quoted: 115 Post(s)
Liked: 34
Somebody used the 1/3 reference does that mean when setting up your screen that if it is 60" high that you would want the 20" mark at eye level? I was trying to figure out how high off of the floor to hang a screen. I will ask again what is the best screen to use with this pj ?
Allen
DekPM19 is offline
post #8307 of 11954 Old 04-09-2014, 07:21 PM
bluer101's Avatar
Quoted: 347 Post(s)
Liked: 279
Allen
Yes, I did. You want your eyes around the bottom 1/3 if possible. But this is subject to what you like too. It is not one size fits all. Mine is 100 elite screens motorized. It has a viewable area of 87x49. With my setup my screen bottom is at about 28-29 inches from the ground. My eyes are around 39-40. So I'm just under 1/3. I had it higher first and did not like it at all.
bluer101 is offline
post #8308 of 11954 Old 04-09-2014, 07:34 PM
DekPM19's Avatar
Quoted: 115 Post(s)
Liked: 34
Thanks for the information
Allen
DekPM19 is offline
post #8309 of 11954 Old 04-09-2014, 07:50 PM
lsdec's Avatar
Quoted: 178 Post(s)
Liked: 116
Why didn't you just get an electric screen?
lsdec is offline
post #8310 of 11954 Old 04-09-2014, 08:11 PM
wootpiggy's Avatar
What electric screen could I have bought for ~$100 that has equivalent characteristics? I would say I did a fair amount of research before setting out on my project but by no means was it extensive.I also mostly just assumed that they would be out of my price range and stuck solely to the DIY section.
As a side note, unless the electric part refers to masking, it really serves me no purpose as that room is dedicated solely as a home theater and I would have no reason to raise or lower a screen.
Benq W1070 1080p 3d Projector
