BenQ W1070 : DLP Full HD, 3D Ready with lens-shift for 1000$ - Page 282 - AVS Forum | Home Theater Discussions And Reviews
 400Likes
Old 04-16-2014, 05:50 PM
OZReddog's Avatar
Liked: 32
Can the people who are having dust blob problems please advise if their projector was ceiling mounted up side down?
Thanks, just thinking outside the box here and exploring a theory.
kreeturez likes this.
OZReddog is offline
Old 04-16-2014, 05:54 PM
kreeturez's Avatar
Quoted: 477 Post(s)
Liked: 365
Ceiling mounted upside down, here!
BenQ HT2050 Projector; Kodi (on Ubuntu, OpenELEC & S802) via Sony STR-DH540 AVR with Boston Acoustics SoundWare XS SE 5.1 Audio + Jamo 210 Sub. Emby for Mobile Streaming.
Helpful post? Click the 'Like' button!
kreeturez is offline
Old 04-16-2014, 06:05 PM
bluer101's Avatar
Quoted: 353 Post(s)
Liked: 286
Originally Posted by AV_Integrated View Post
I just can't imagine hanging a $1,000+ projection setup from a piece of PVC. I know others do it, but considering the $10 price difference to use heavy gauge steel pipe... I don't get PVC.
PVC Pipe-Schedule 40 is very strong. The pressure ratings and durability far exceed a 5-6 lbs projector. Plus you can cut it easy and to any size you wish. Between pvc glue and 2 per drilled screws it's not going anywhere. If you think there might be an issue with any mount attach a safety cable.
Projector & Screen: Epson 5040ub Elite Screens 100" Electric Video: Oppo 103d Audio: Denon 4520ci Speakers: Infinity RS5 (LW L C R RW) Infinity RS1 (LH RH) Infinity Beta ES250 (SL SR) Subwoofers: 2 SI18d4 Martycubes with iNuke3000dsp and 2 Infinity BU120 Shakers: 4 ADX shakers with Dayton SA230 amp
My Builds--Media console build----Martycube build----ADX Bass Shaker Install
bluer101 is online now
Old 04-16-2014, 06:12 PM
ellisr63's Avatar
Quoted: 991 Post(s)
Liked: 413
I don't see any problem with using PVC for hanging this projector... Now back in the day of a CRT projector I would say no way! My old Epson 1080 was hung from a custom made piece I made out of 2 pieces of plexiglass, and 1/4" screws connecting them together, and it worked out fine.
Yamaha CX-A5100, (3) JBL 2360As/EV DHA-1s, (3) 1/4 Pie bass bins, 4 JBL 8340As, 4 JBL 8320s, PS3, XBoxOne, 2 Intel NUCs, Monoprice speaker wire, and XLR cables, Redmere HDMI cables, Monster HTPS7000, 2 Furman filters, 2 DTS-10 subs, Panasonic AE8000, SeymourAV 195" diagonal scope screen, Panamorph UH-480, Darbee Darcet, Yamaha P7000s, (2) Crest Audio CM2208s, Yamaha XM-4080, (2) MiniDSP DDRC-88.
The Ellis Family Go Big or go Home HT
ellisr63 is offline
Old 04-16-2014, 06:57 PM
Charlie97L's Avatar
I found the plates on the site thanks! pj arriving friday; probably can't play with it until Monday due to work. Le Sigh.
loving my completed home theater. :)
Charlie97L is offline
Old 04-16-2014, 08:07 PM
lsdec's Avatar
Quoted: 178 Post(s)
Liked: 116
Originally Posted by bluer101 View Post
This was the factory mount but has been discontinued.
http://www.newegg.com/Product/Product.aspx?Item=N82E16824997038
What about this one? I just bought it last week and should have it up in a couple of days.
http://www.bhphotovideo.com/bnh/controller/home?O=&sku=899557&gclid=CNzZwefE5r0CFQsSMwod4QMA9w&Q=&is=REG&A=details
lsdec is offline
Old 04-16-2014, 10:32 PM
bori's Avatar
Quoted: 193 Post(s)
Liked: 126
I think 3-5 inches to be safe.
So I could go as low as 12inches? That's if 7 inches is the perfect spot correct?
bori is offline
Old 04-17-2014, 06:34 AM
bluer101's Avatar
Quoted: 353 Post(s)
Liked: 286
If the calculator is telling you 7 inches then that is ceiling to center of lens. I was saying lens shift is 3-5 inches to be safe. You do not want to be lower than the 7 inches. You cannot lens shift up. When you mount the projector upside down and have not used the lens shift yet, the shift is all they way up already from factory. When you turn the screw, flat head, it will move the lens assembly down to bring the picture down. So I would be at 6-7 inches from ceiling. Then use the down shift to get it to you screen.
I have my pj as high as it can go with the lens shift maxed out. This way it gets my PJ the highest it can go out if the way. This also helps when getting up from me seating. Most people that are not real tall won't be in the projected image.
Just a word if caution to everyone. I had my PJ replaced by benq and they sent a new one. I had the original one all set up. I removed it with my peerless quick removable mount. So when I got the new projector I could just put it back into position and adjust the lens shift down and refocus. Wrong, it seems the new pj did not have enough down shift. So I had to extend my down pole by about an inch or so.
So I guess the lens shift is not set in stone from PJ to PJ. They can be off. But this can be my problem also as I'm using the shift to the max.
Old 04-17-2014, 06:57 AM
bori's Avatar
Quoted: 193 Post(s)
Liked: 126
Right now I have it set up around 7 inches. The thing is I used toggle bolts to hook up mount. Its not the ideal way to mount it cause it still moves alittle. I wanted to add a board and screw it to wood studs. Then use a pipe and floor flange to attach my mount. This would add about 3 inches. I wouldn't be able to tilt mount up?
bori is offline
Old 04-17-2014, 08:25 AM
bluer101's Avatar
Quoted: 353 Post(s)
Liked: 286
Take a few photos and post here. If it's that close there are other ways to mount the projector. Instead if the floor flange and pipe you can still use a board to the joists. Then use wood to bring the mount down and screw the mount to the wood. So everything will be attached to the wood then screw the whole thing to the joists. Slide your projector on the mount, all set.
Then get creative with small moulding and paint. It will blend in.
Old 04-17-2014, 08:44 AM
bori's Avatar
Quoted: 193 Post(s)
Liked: 126
So basically use the wood only. Attach mount to that.
bori is offline
Old 04-17-2014, 08:47 AM
bori's Avatar
Quoted: 193 Post(s)
Liked: 126
[IMG]
bori is offline
Old 04-17-2014, 08:58 AM
bluer101's Avatar
Quoted: 353 Post(s)
Liked: 286
Yes, if you are that close no need for pole and flange. As long as you have adjustment and get the picture right. Personally I want my PJ
As high as possible out of the way.
Old 04-17-2014, 09:28 AM
bori's Avatar
Quoted: 193 Post(s)
Liked: 126
Thanks for the advice going to do that. Just thought the first option will give more flexibility for adjusting mount. That's OK will use the wood only and make it look nice with some molding.
bori is offline
Old 04-17-2014, 10:23 AM
bluer101's Avatar
Quoted: 353 Post(s)
Liked: 286
As long as you are center on the screen all other adjustments can be made. If you want side to side you can do what I did. I routed slots to allow this adjustment. So the whole mount and board can be moved. But I really did not need it as my math and measuring was spot on.
Old 04-17-2014, 11:15 AM
AV_Integrated's Avatar
Quoted: 1022 Post(s)
Liked: 740
It's weird that they don't show mounts on the BenQ website, but that mount is generic cheap stuff. Looks good, but functionality-wise is going to have stability issues and alignment issues which will be difficult to deal with.
Where is the pan adjustment? Where is the tilt adjustment? Where is the yaw adjustment? These three things must be separate and must be able to be individually tightened.
Likewise, is the projector mount removable? Can you get it down to just a few inches? Less? What adjustments are there for that? What about quick release and the stability of that?
It's typical, not bad, but a long way from great, and very similar to many others out there from a long list of generic suppliers for less money.
AV Integrated - Theater, whole house audio, and technology installation in the Washington DC metro area.
AV_Integrated is offline
Old 04-17-2014, 11:17 AM
Liked: 740
Do you have the RPM mount or the RPA mount? The RPA mount I don't think allows for left/right rotation of the image. The RPM (Elite) mount does and is more supportive of being directly screwed into a ceiling joist.
Old 04-17-2014, 12:17 PM
lsdec's Avatar
Quoted: 178 Post(s)
Liked: 116
It's on the BenQ site too: http://www2.benq.us/product/projector/ceilingmount-cm00g2/
It has a tilt adjustment of +/- 25 degrees but no other adjustments. I have to be perfect when I mount it.
There is a a quick release and a bolt for keeping the quick release in check.
Yes, the extension pole is optional so you don't need to use it.
I'm not sure about all these other mounts but I figured getting one with the same brand couldn't hurt. As long as it holds my projector up in place and looks nice it's all good.
lsdec is offline
Old 04-17-2014, 12:21 PM
ellisr63's Avatar
Quoted: 991 Post(s)
Liked: 413
The problem is that your screen wall must be a perfect 90 degrees from your ceiling... Which in my case it was not. That is where the adjustment comes in.
ellisr63 is offline
Old 04-17-2014, 12:24 PM
Liked: 740
Yeah, there must have been some change. I searched their US and global site about a month ago, and that mount definitely wasn't there. It came up right away when I did a search this time.
You could save money and have the same results with a host of other mounts, or you could spend more and have a mount that actually allowed you to dial it in perfectly. Your money though.
Old 04-17-2014, 12:43 PM
Quoted: 108 Post(s)
Liked: 49
Anyone using this mount with there Benq W1070. Sanus - VisionMount Universal Projector Ceiling Mount.
jsil is offline
Old 04-17-2014, 12:58 PM
Liked: 740
The VMPR1?
http://www.sanus.com/en_US/products/mounts/vmpr1/
This is certainly a better built mount on par with the Chief RPA series of mounts. Nice adjustability, firmly built. Not as good as the Elite series Chief mounts. You should have no issue with it, but I wouldn't buy it over the Elite if you are buying anywhere near the typical $100+ online price. Buy the Elite instead.
Old 04-17-2014, 01:09 PM
bori's Avatar
Quoted: 193 Post(s)
Liked: 126
Its just say RPM as model# doesn't say elite.
bori is offline
Old 04-17-2014, 01:15 PM
bori's Avatar
Quoted: 193 Post(s)
Liked: 126
Here goes some pics of the rpm. Does it look like I can rotate if mounted directly to ceiling?
bori is offline
Old 04-17-2014, 01:45 PM
Liked: 740
That is a RPM mount and not a RPA mount. That's a GOOD thing! Yes, it can be rotated once affixed to the ceiling. Make sure when you affix it to the ceiling, you are in the center of the rotation area. Right now, if you look at the top of the mount, you will see there are grooves in the mount which allow for rotation of the projector right on the mount. They are currently turned all the way clockwise. If you mount it, as-is, the projector could spin counter-clockwise about 20 degrees or so. So, before putting up the mount, adjust it about 10 degrees counterclockwise, then you will be able to spin the projector about 10 degrees either direction with it firmly affixed to your ceiling.
Once again, this is why this mount is the best on the market.
ellisr63 likes this.
Old 04-17-2014, 01:47 PM
lsdec's Avatar
Quoted: 178 Post(s)
Liked: 116
I wasn't willing to spend anymore than this...I do hope I can dial it in perfectly otherwise I'll have to return it. We will see how it works out in the next couple of days.
I'm sure it'll be fine - it's just a projector mount. Certainly not one of my passions smile.gif.
lsdec is offline
Old 04-17-2014, 01:50 PM
bori's Avatar
Quoted: 193 Post(s)
Liked: 126
I just took off mount. It does rotate not a 360 rotation but gives u option to rotate around 20 degrees
bori is offline
Old 04-17-2014, 02:35 PM
ellisr63's Avatar
Quoted: 991 Post(s)
Liked: 413
I just took off mount. It does rotate not a 360 rotation but gives u option to rotate around 40 degrees
ellisr63 is offline
Old 04-17-2014, 02:42 PM
Liked: 740
I hope the MOUNT isn't one of your passions, but many on these forums are certainly passionate about getting the best 'on-screen' image possible, and when you can't align your projector easily, and spend hours futzing with the mount... then getting frustrated... perhaps yelling. It's amazing how passions can grow. biggrin.gif
Anyone who has used a cheap mount, then switches to a Elite mount understand the difference and the 'why' of a good mount.
For what it's worth, if you are dissatisfied, keep an eye on eBay. I've seen the Elite mount go for under $50 several times.
Old 04-17-2014, 02:47 PM
bori's Avatar
Quoted: 193 Post(s)
Liked: 126
yes this is an awesome mount. And I give u all the credit for the recommendation a couple of weeks ago.
bori is offline
Benq W1070 1080p 3d Projector
