BenQ W1070 : DLP Full HD, 3D Ready with lens-shift for 1000$ - Page 283 - AVS Forum | Home Theater Discussions And Reviews
 396Likes
post #8461 of 11973 Old 04-17-2014, 03:25 PM
Jimbo2012's Avatar
I was all set to buy one but I was told the distance to the screen being 192" from the lens is not going to work on my 130" diag screen wall.
Any opinions?
Or if you agree what other models might work with similar quality?
Jimbo2012 is offline
post #8462 of 11973 Old 04-17-2014, 05:01 PM
ellisr63's Avatar
Quoted: 991 Post(s)
Liked: 412
Originally Posted by AV_Integrated View Post
I hope the MOUNT isn't one of your passions, but many on these forums are certainly passionate about getting the best 'on-screen' image possible, and when you can't align your projector easily, and spend hours futzing with the mount... then getting frustrated... perhaps yelling. It's amazing how passions can grow. biggrin.gif
Anyone who has used a cheap mount, then switches to a Elite mount understand the difference and the 'why' of a good mount.
For what it's worth, if you are dissatisfied, keep an eye on eBay. I've seen the Elite mount go for under $50 several times.
Yup... I picked up mine for under $40.
Yamaha CX-A5100, (3) JBL 2360As/EV DHA-1s, (3) 1/4 Pie bass bins, 4 JBL 8340As, 4 JBL 8320s, PS3, XBoxOne, 2 Intel NUCs, Monoprice speaker wire, and XLR cables, Redmere HDMI cables, Monster HTPS7000, 2 Furman filters, 2 DTS-10 subs, Panasonic AE8000, SeymourAV 195" diagonal scope screen, Panamorph UH-480, Darbee Darcet, Yamaha P7000s, (2) Crest Audio CM2208s, Yamaha XM-4080, (2) MiniDSP DDRC-88.
The Ellis Family Go Big or go Home HT
ellisr63 is offline
post #8463 of 11973 Old 04-17-2014, 05:14 PM
schmidtwi's Avatar
Quoted: 191 Post(s)
Liked: 136
Any opinions?
http://www.projectorcentral.com/BenQ-W1070-projection-calculator-pro.htm
The Schmidt Haus Theater - WIP (or not) since 2010
schmidtwi is offline
post #8464 of 11973 Old 04-17-2014, 08:32 PM
Morkeleb's Avatar
Originally Posted by OZReddog View Post
Can the people who are having dust blob problems please advise if their projector was ceiling mounted up side down?
Thanks, just thinking outside the box here and exploring a theory.
Originally Posted by kreeturez View Post
Ceiling mounted upside down, here!
Ceiling mounted upside down here also and I hate to report my replacement unit now has two blobs. Third movie into using it. mad.gif
ellisr63 likes this.
Disclaimer:
The words above are based on loose facts mixed with my opinion, the latter of which is subject to change.
Gamertag Morkaleb
PSN Archathema
Morkeleb is offline
post #8465 of 11973 Old 04-17-2014, 09:02 PM
ellisr63's Avatar
Quoted: 991 Post(s)
Liked: 412
I have been ceiling mounted for almost a year now.... Only problem I have is it developed the fan rattle.
ellisr63 is offline
post #8466 of 11973 Old 04-17-2014, 09:13 PM
kreeturez's Avatar
Quoted: 477 Post(s)
Liked: 364
@Morkeleb: I can't believe it - that's a November-built model giving you hassles? Twice in a row! Does this mean the dust-sealing hasn't been improved between your March and November units, I wonder?
Was your November unit new or refurb?
@ellisr63: They're not obvious at first; and only affect users at specific zoom/focus combinations. They appear as white dust-shaped dots that go in and out of focus (becoming larger, less-bright circles) when viewed on an all-black screen. Depending on projector placement, they may be completely focused out, making them invisible.
To make sure you're definitely not affected, set your projector to Eco-Blank, and while it's blanked (in a dark room), experiment with changing both Zoom and Focus combinations across their respective ranges to make sure that none do appear.
You may be lucky; but OTOH maybe the degree of dust-sealing varies from unit to unit. My room is generally dust-free; except for a bit of dusty spring cleaning (which was when my issue first appeared). The rattling fan is pretty standard, though :-)
BenQ HT2050 Projector; Kodi (on Ubuntu, OpenELEC & S802) via Sony STR-DH540 AVR with Boston Acoustics SoundWare XS SE 5.1 Audio + Jamo 210 Sub. Emby for Mobile Streaming.
Helpful post? Click the 'Like' button!
kreeturez is offline
post #8467 of 11973 Old 04-17-2014, 09:25 PM
ellisr63's Avatar
Quoted: 991 Post(s)
Liked: 412
My first one was returned in the first 30 days for the fan rattle... The fan noise is only noticeable if i walk around the projector and then I can hear it at around the front right side. I had the dust blobs on my old Epson 1080p... I don't see them on mine period. Our room doesn't really have a dust problem but a dog hair problem. When we get the new HT built it should be dust and dog hair free as the dogs won't be in the room as much as they are now (HT is in the family room).
ellisr63 is offline
post #8468 of 11973 Old 04-17-2014, 09:53 PM
OZReddog's Avatar
Liked: 32
Thank you for the responses regarding the dust blobs and ceiling mounting, appreciated.
Is there anyone who has experienced dust blobs who has the projector mounted/positioned right side up? Thanks.
Morkeleb likes this.
OZReddog is offline
post #8469 of 11973 Old 04-17-2014, 10:25 PM
bori's Avatar
Quoted: 188 Post(s)
Liked: 125
Mine was manufactured in February 2014. Bought it refurbished.
bori is offline
post #8470 of 11973 Old 04-18-2014, 05:30 AM
CheYC's Avatar
Quoted: 35 Post(s)
Liked: 56
Same exact thing for me, only mine has been more like 9 months.
CheYC is offline
post #8471 of 11973 Old 04-18-2014, 05:39 AM
Rew452's Avatar
Quoted: 107 Post(s)
Liked: 64
If I remember right, BenQ has this noise to be caused by the Color Wheel vibrating .
Rew
Rew
Vizio P75-C1 | OPPO UDP-203 | Samsung UBD-K8500
Denon AVR-x5200w | Nvidia Shield Android TV | C =Axiom VP150 |FL/FR =Axiom M60 |SL/SR =Axiom QS4 |TFL/TFR =Bose 161 | TRL/TRR =Bose 161 |Sub =Reaction Audio S-15 500W SEALED SUBWOOFER
Rew452 is offline
post #8472 of 11973 Old 04-18-2014, 06:31 AM
bluer101's Avatar
Quoted: 353 Post(s)
Liked: 285
Mine is upside down. Build Jan 2014. My first PJ was sept 2013. It had the fan rattle after the first few movies and was more aggravated when on smart Eco. I run smart Eco only on 3d all other Eco only.
Projector & Screen: Epson 5040ub Elite Screens 100" Electric Video: Oppo 103d Audio: Denon 4520ci Speakers: Infinity RS5 (LW L C R RW) Infinity RS1 (LH RH) Infinity Beta ES250 (SL SR) Subwoofers: 2 SI18d4 Martycubes with iNuke3000dsp and 2 Infinity BU120 Shakers: 4 ADX shakers with Dayton SA230 amp
My Builds--Media console build----Martycube build----ADX Bass Shaker Install
bluer101 is offline
post #8473 of 11973 Old 04-18-2014, 07:39 AM
Morkeleb's Avatar
My replacement unit is an October 2013 build and it was refurbished. The dust blob on my original unit was towards the bottom and faint. On the replacement unit after I watched my third movie on it last night as the credits rolled there where two dust blobs. One of these is close to the middle of all places so needless to say I'm not happy but not going to do anything about it at this time. It won't really bother me until I start seeing it during a movie which will likely be the next horror movie I watch.
Disclaimer:
Gamertag Morkaleb
PSN Archathema
Morkeleb is offline
post #8474 of 11973 Old 04-18-2014, 02:48 PM
wootpiggy's Avatar
Originally Posted by Cerberus83 View Post
Thanks!! I will look into Lofree MT-200 (is it back-lit?).
I'm putting all of my media behind the wall in a closet and I just bought Harmony Ultimate as I am hoping to hide all the devices. But to your point, I would need the mouse and a keyboard (to search titles at least).
Sorry, I'm in Italy so I missed this. The Lofree isn't backlit which is what led me to purchase the logitech mini controller. I just have to test if it will work with the android stick. It should be in my mailbox when I get home.
wootpiggy is offline
post #8475 of 11973 Old 04-18-2014, 04:25 PM
preed88's Avatar
Proud new owner of a 1070 here.
Quick question: Ive noticed that when something bright comes on the screen, it seems that the projector increases its brightness and washes out all the blacks in the process. Is there a way to disable this? Or am I mistaken and thats just the white light bouncing off my walls...
preed88 is offline
post #8476 of 11973 Old 04-18-2014, 05:23 PM
bori's Avatar
Quoted: 188 Post(s)
Liked: 125
Thanks guys for the suggestions. Got my projector set up again. Here are some pics. nuhegu6a.jpg
Sent from the TermiNOTEr 2! ;-)
bori is offline
post #8477 of 11973 Old 04-18-2014, 05:47 PM
bori's Avatar
Quoted: 188 Post(s)
Liked: 125
I placed a piece of tape to cover the zoom adjustments. Is this OK? I did this so nobody changes my settings.
bori is offline
post #8478 of 11973 Old 04-18-2014, 07:29 PM
lsdec's Avatar
Quoted: 178 Post(s)
Liked: 116
I mounted mine today as well using the BenQ projector mount. All in all it was pretty easy. The horizontal shift is the one thing that would have made my job easier. Dumb mistake of centering on the middle of the projector vs the lens.
It has a release lever for the angles. It's a ball pivot where you can tilt it in any axis. The height adjustment flexibility was very nice and it's pretty stable.
The hdmi cable is just taped to the ceiling for now until I get some cable management. smile.gif.
Time for a movie now as my reward biggrin.gif.
lsdec is offline
post #8479 of 11973 Old 04-18-2014, 07:32 PM
Quoted: 99 Post(s)
Liked: 48
What cable management are you guy's using for your ceiling. Also I'm using a Pioneer blu ray player for 2D and PS3 for 3D what settings should I be using.
jsil is online now
post #8480 of 11973 Old 04-18-2014, 08:25 PM
butie120's Avatar
Quoted: 421 Post(s)
Liked: 83
I'm just using a single gang recessed plate. Plenty of cables can enter and exit. Kind of looks like a snout.
butie120 is offline
post #8481 of 11973 Old 04-19-2014, 07:54 AM
GLW65's Avatar
I just purchased a refurb from Benq. I have 30 days to try it before I can't send it back. Can some of you who have had the unit for some time tell me how you are doing on bulb hours. In smart eco this is supposed to give 6000 hours. Are any of you getting close to this? How much bulb dimming do you see? Is it noticable in the number of hours you have on the bulb. Thanks for the info.
GLW65 is offline
post #8482 of 11973 Old 04-19-2014, 10:40 AM
bori's Avatar
Quoted: 188 Post(s)
Liked: 125
I have a question. Just want to make sure. Does your 1070 always looks like its adjusting colors when it switches input? Is it the color wheel adjusting every single time?
bori is offline
post #8483 of 11973 Old 04-19-2014, 11:17 AM
bluer101's Avatar
Quoted: 353 Post(s)
Liked: 285
Yes, also when switching between some previews and menus. This is caused by 1080p 60 changing to 1080p 24 which is the movies native. I found you can go into your blu ray player and change the 24 output to off and then it will not do it but then it does not display the movie in the correct frame rate. Also all 3d blu rays I found out so far are 24.
Btw, you ceiling plate looks good. You just have to think a little out of the box.
bluer101 is offline
post #8484 of 11973 Old 04-19-2014, 11:21 AM
bori's Avatar
Quoted: 188 Post(s)
Liked: 125
thanks for ur help
bori is offline
post #8485 of 11973 Old 04-19-2014, 04:16 PM
JoeBoy73's Avatar
Quoted: 12 Post(s)
Liked: 26
Anyone replaced their bulb yet? I'm at 3600 hours since last Feb 2013...
JoeBoy73 is offline
post #8486 of 11973 Old 04-19-2014, 04:24 PM
ellisr63's Avatar
Quoted: 991 Post(s)
Liked: 412
I'm at 3300 hours since July 2014... I run in low power mode with our 134" Jamestown screen. I hope to make it till next year before I buy a new bulb.
ellisr63 is offline
post #8487 of 11973 Old 04-19-2014, 05:14 PM
JoeBoy73's Avatar
Quoted: 12 Post(s)
Liked: 26
Thanks ellisr63....it seems that I'm in good company then!
JoeBoy73 is offline
post #8488 of 11973 Old 04-19-2014, 08:18 PM
bori's Avatar
Quoted: 188 Post(s)
Liked: 125
How long does a bulb usually last?
bori is offline
post #8489 of 11973 Old 04-19-2014, 08:34 PM
ellisr63's Avatar
Quoted: 991 Post(s)
Liked: 412
I think it around 6000 hours on low per BenQ... I am assuming there will be a warning popup when it is getting close as there was on my Epson.
bori likes this.
ellisr63 is offline
post #8490 of 11973 Old 04-20-2014, 12:14 AM
Duckfan2012's Avatar
How does the w1070 perform in non-dedicated HT with moderate light, say sports viewing during the day?
Duckfan2012 is offline
Benq W1070 1080p 3d Projector
