BenQ W1070 : DLP Full HD, 3D Ready with lens-shift for 1000$ - Page 305 - AVS Forum | Home Theater Discussions And Reviews
 390Likes
post #9121 of 11931 Old 06-08-2014, 09:32 AM
dolphinc's Avatar
Quoted: 86 Post(s)
Liked: 63
I just bought the w1070 a week ago and love it, I will be re-designing my theater room and have a question. My room is 18x 21 complete light controlled (no windows), ceiling will be flat black, 3 walls will be flat navy blue, i have dark grey carpet. Front seats will be about 12-13feet from screen, will this projector push to a 135" fixed screen? I have 106" now but i would like to go larger but without sacrificing to much image quality.
dolphinc is offline
post #9122 of 11931 Old 06-08-2014, 11:15 AM
AV_Integrated's Avatar
Quoted: 972 Post(s)
Liked: 718
Originally Posted by Movie78 View Post
Is it normal that vent is blowing  hot air?
This make my small home theater room very hot.
It's a very hot lamp inside, surrounded by electronics running full tilt.
Yes, it's supposed to be VERY hot air coming out of the projector if the fans are doing things properly.
AV Integrated - Theater, whole house audio, and technology installation in the Washington DC metro area.
AV_Integrated is offline
post #9123 of 11931 Old 06-08-2014, 11:19 AM
Quoted: 972 Post(s)
Liked: 718
Originally Posted by dolphinc View Post
...will this projector push to a 135" fixed screen? I have 106" now but i would like to go larger but without sacrificing to much image quality.
Image quality is all about resolution compared to seating distance and screen size. A 10' wide screen viewed from 15' away is the same as a 100' wide screen viewed from 150' away. As long as you maintain good brightness, color, and contrast with the size.
In the case of the W1070, 135" is easy.
I'm running my unit at 161" on a 1.3 gain screen. It looks great. Look at the photos just a few posts back with the outdoor screen... That's 228"! This projector really performs well.
post #9124 of 11931 Old 06-08-2014, 02:00 PM
bighvy76's Avatar
Quoted: 22 Post(s)
Liked: 29
my room gets hot too. It's a 11×14 with 1 a/c vent. It's fine in winter but I'm thinking of adding another vent
bighvy76 is offline
post #9125 of 11931 Old 06-08-2014, 02:50 PM
Movie78's Avatar
Quoted: 796 Post(s)
Liked: 242
I might have to buy a very quiet mini AC unit the for this room...
Movie78 is online now
post #9126 of 11931 Old 06-08-2014, 03:06 PM
dolphinc's Avatar
Quoted: 86 Post(s)
Liked: 63
Thats an awesome size screen. I will be ordering the 135" tonight. July 4th weekend will be the when I paint and change the room, I'll post pics as i go. Thanks AV for the info, by the way, you would love the room now, its bright yellow! smile.gif
dolphinc is offline
post #9127 of 11931 Old 06-08-2014, 03:53 PM
bori's Avatar
Quoted: 187 Post(s)
Liked: 125
Originally Posted by bori View Post
Is it possible to send the video signal directly to projector then send just optical to receiver in order to get 3d? Or is this player a better option? I don't want to upgrade receiver because it's been great to me.
Panasonic DMP-BDT310 Integrated-Wi-Fi 3D Blu-ray DVD Player (2011 Model) by Panasonic http://www.amazon.com/dp/B004LNOSQO/ref=cm_sw_r_udp_awd_gc9Itb1EXJBEF
Are there any newer Blu Ray players that are inexpensive with dual hdmi?
bori is offline
post #9128 of 11931 Old 06-08-2014, 05:15 PM
Boomassiv's Avatar
Quoted: 118 Post(s)
Liked: 50
Anyone using Yamaha rx-v773 with their 1070? What hdmi do you use and does it carry everything? I will probably have to span using a 50' cable.
Boomassiv is offline
post #9129 of 11931 Old 06-08-2014, 05:22 PM
bighvy76's Avatar
Quoted: 22 Post(s)
Liked: 29
I'm using the rx-v573 it carries everything and I'm not using anything special for hdmi one off amazon
bighvy76 is offline
post #9130 of 11931 Old 06-08-2014, 06:11 PM
Boomassiv's Avatar
Quoted: 118 Post(s)
Liked: 50
post #9131 of 11931 Old 06-08-2014, 06:54 PM
chmcke01's Avatar
Quoted: 31 Post(s)
Originally Posted by jkkwaz View Post
Hey guys, I got this projector and absolutely love it. Projecting onto a Seymour XD 120" diag screen and the picture quality is incredible. One question though, is anyone else having issues with the remote? I have to stand up and get the remote extremely close to the projector and have it facing at just the right angle to get it to work. I've tried multiple sets of brand new batteries to I don't think that is the issue. Are you guys able to get the remote working better than that? Is it responsive if you are just sitting in your MLP? I love the projector, but can't stand the remote!! Is it defective? Thanks!
Mine works great, I can just point it at my wall (my screen) and it works always. Probably a defective remote.
chmcke01 is offline
post #9132 of 11931 Old 06-09-2014, 11:59 AM
hawnr6's Avatar
Originally Posted by d19racing View Post
I actually did try to view 3d clips, movies from even you tube via my PS3 and it works great as in everything Pop Out in your face Youtube mvies/clips come in Side By Side Format.
Tried the my copy of the 3d (Blu Ray Frame Packing format) Tangled movie on my friends EPSON 3010E 3D Projector last night and lanterns scene actually Popped Out into the room, 3D Pop Out effect was amazing, Same scene has no pop outs on my projector w1070 when i play the same Blu Ray Movie.
Like I said before the SBS Format movies & clips from Comcast, or You tube work excellent and the 3D Pop Out is in your face.
However the any of my 3d Blu Ray Movies are detected and played by my PJ in 3D Frame Packing format however they are FLAT.
No Pop Out Effect.
Yes I did upgrade my firmware version to 1.8 . Guess this also didn't fix the issue for frame packing format.
Now I'm beginning to wonder if my PJ W1070 may have a defect for frame packing mode or may be my True Depth Firestorm XL Active Glasses don't support Frame Packing Mode @1080P/24 HZ,
However PJ & True Depth XL Firestorm glasses play the same movies and clips from comcast or youtube in Side By Side Format (@ 1080i/60HZ) and there is great 3D Pop Out Effect which is in your face.
I am thinking of ordering either Ben Q 3D Glasses from amazon or Saisonic 3d glasses and again test my blu ray frame packing format movies just make sure it may not be my 3D (True Depth firestorm xl) glass issue.... as in May Be True Depth Firestorm XL dont support 3D Frame Packing format or 3D Blu RayMovies with similar format. Since all Blu Ray 3D Movies come only in Frame Packing Format.......
Guys Any Advice would be greatly appreciated..... Thanks.
I have actually noticed the same thing - SBS seems to pop out a lot more compared to frame packing.. The 3d blue ray movies I have seem just to have depth into the screen, while the 3d movies on Netflix (especially the turtle cartoon movie) seem to really pop out.
hawnr6 is offline
post #9133 of 11931 Old 06-09-2014, 12:37 PM
eric3316's Avatar
Quoted: 839 Post(s)
Liked: 959
Just an FYI regarding this projector in the US. I emailed BenQ about registering my projector and they told me you are automatically registered with your purchase and just make sure to keep your receipt/proof of purchase for future warranty issues.
eric3316 is offline
post #9134 of 11931 Old 06-09-2014, 02:14 PM
Movie78's Avatar
Quoted: 796 Post(s)
Liked: 242
Are these Frame packing 3D original from the store or downloaded?
I have the Panasonic 3D demo and talking about pop out,there is too much pop out with this Demo.
post #9135 of 11931 Old 06-09-2014, 02:24 PM
d19racing's Avatar
Mine are Store bought 3d Blu Ray Discs in Frame Packing Format..
d19racing is offline
post #9136 of 11931 Old 06-09-2014, 02:30 PM
Movie78's Avatar
Quoted: 796 Post(s)
Liked: 242
Strange...
I had one that i made from the original copy to test it out and the 3D was bad on the copy version.
post #9137 of 11931 Old 06-09-2014, 08:12 PM
bori's Avatar
Quoted: 187 Post(s)
Liked: 125
I have a question regarding 3d. I have a Onkyo 805 receiver that I want to bypass for 3d only, but still want to be able to you it for 2d video through the receiver. Right now I have it connected through a hdmi switch. I want to use my ps3 for 3d. So I am going to send the optical out to the receiver and HDMI to projector. What do I need to achieve this? Would a hdmi splitter all I need?
bori is offline
post #9138 of 11931 Old 06-09-2014, 09:03 PM
d19racing's Avatar
Hey Guys,
I just bought the Sony BDP 5200 tonight and hooked it my my Receiver DNA1040 and Frame Packing Mode worked great.
Finally 3D Popped Out just like SBS Format.
So it wasn't the glasses after all. It was the PS3 ability to handle Frame Packing Format that has been issue all this time..... PS3 can't handle Frame Packing Mode.... Hence movie is FLAT....
Finally it works great as expected greats depth and great 3d Pop Out Effect...
Thank you Guys...........
post #9139 of 11931 Old 06-09-2014, 09:06 PM
bori's Avatar
Quoted: 187 Post(s)
Liked: 125
So you are saying the ps3 doesn't work well with this projector when it comes to 3d?
bori is offline
post #9140 of 11931 Old 06-10-2014, 12:45 AM
CARTmen's Avatar
Quoted: 84 Post(s)
Liked: 34
Sorry for the dumb question, but is Frame Packing best than SBS 3D? Why? And what about frame sequential?
CARTmen is offline
post #9141 of 11931 Old 06-10-2014, 04:33 AM
bori's Avatar
Quoted: 187 Post(s)
Liked: 125
What the default baud rate on the projector? I think I accidentally changed it.
bori is offline
post #9142 of 11931 Old 06-10-2014, 05:45 AM
kreeturez's Avatar
Quoted: 469 Post(s)
Liked: 354
He's referring to movie playback. (Not an issue that everyone's having). I've done a good deal of gaming on the PS3 via this projector and games played in 3D are incredible. MotorStorm Apocalypse is my showcase game in this case - it's mighty impressive. (Available for download on the PlayStation Store)
SBS tends to be half-resolution (H-SBS) since it's normally a 'regular' 1080p video with half the image split for the one eye; and half for the other. The result is loss of half of the original video's resolution; not ideal.
Frame Packing is preferable since it's generally full-resolution (1080p) per eye; thus no loss of resolution.
That said, not all devices support it - the PS3, for instance, Frame Packs at downscaled 720p for most 3D games. Most would argue that this still looks better than half-resolution 1080p SBS, but it's a debate (see here).
I vastly prefer the appearance from 3D Frame-Packed blurays to any 3D SBS rip. In the case of Netflix (which I don't use myself), the bitrate of the Netflix 3D SBS stream (and thus the level of image quality) is much, much lower than of a Frame-Packed bluray. Remember the effect of 3D is produced by simply sending one image to one eye; and another to the other - so the 3D format - i.e. SBS or Frame-Packed - other than affecting resolution, shouldn't change the degree of pop-out if the source is the same. I wonder if Netflix isn't doing something to the source content to increase perceived pop-out when they encode it...
Default value is 115200. But it doesn't matter since this value is only used when using the projector's Serial (RS-232) Port to connect to a PC; it's not used for anything else.
eric3316 and fredxr2d2 like this.
BenQ HT2050 Projector; Kodi (on Ubuntu, OpenELEC & S802) via Sony STR-DH540 AVR with Boston Acoustics SoundWare XS SE 5.1 Audio + Jamo 210 Sub. Emby for Mobile Streaming.
Helpful post? Click the 'Like' button!
kreeturez is offline
post #9143 of 11931 Old 06-10-2014, 07:16 AM
CARTmen's Avatar
Quoted: 84 Post(s)
Liked: 34
Thanks for the explanation kreeturez.
So this could make a big difference in the image resolution of the projector, especially in a 135' screen like I have, right?
Is there any options (software or hardware) to do an upscale of  HSBS 3d from netflix to Frame Packs 1080p?
CARTmen is offline
post #9144 of 11931 Old 06-10-2014, 07:20 AM
d19racing's Avatar
Nope what I meant is PS3 does play 3D Blu Ray Movies with Depth only in Frame Packing Format with No 3D Pop Out Effect (FLAT).
However it does have great Pop Out Effect when playing downloaded movies or YouTube clips in Side By Side format only..
However the Sony BDP 5200 3D Blu Ray Player plays the same 3d Blu Ray Movie in Frame Packing Format
With both 3D Depth and 3D Pop Out.
Yes in my scenario I could literally see the difference between the players just for Frame Packing Format Only and also only with reference with 3D Pop Out Effect Only the mentioned Format.
post #9145 of 11931 Old 06-10-2014, 07:23 AM
d19racing's Avatar
Even though the issue has been resolved.
Nevertheless I still prefer the Side By Side Format to watch 3D Movies as its just my personal preference, after watching Cable (Comcast) 3D movies in SBS mode. I personally feel they are just more objects flying out at your face in the SBS Mode.
Just my thought.....
post #9146 of 11931 Old 06-10-2014, 07:41 AM
bighvy76's Avatar
Quoted: 22 Post(s)
Liked: 29
Is it worth getting a good stand alone bluray player or is the ps3 good enough. I run everything thru the ps3 but wouldn't mind getting it to last longer by getting a nice 3d bluray player. What is the best one to look at. Or will nothing beat the ps3
bighvy76 is offline
post #9147 of 11931 Old 06-10-2014, 07:47 AM
Movie78's Avatar
Quoted: 796 Post(s)
Liked: 242
Are you able to get the PS3 to play SBS with This Projector?
If you do,what are your settings?
post #9148 of 11931 Old 06-10-2014, 08:38 AM
kreeturez's Avatar
Quoted: 469 Post(s)
Liked: 354
Games are frame-packed only.
Movies will play in SBS if the source video is already an SBS file.
Blurays only will play as frame-packed.
post #9149 of 11931 Old 06-10-2014, 08:39 AM
fredxr2d2's Avatar
Quoted: 169 Post(s)
Liked: 97
As far as I know, the PS3 will do everything you need it to do unless you want to go all the way up to an Oppo. In which case, you're looking at $500 for a standalone BD player. (That said, from all reports--on here and elsewhere--the Oppo blows the socks off of everything else.)
Tim S.
Former 35mm and Digital Projectionist @ Regal Cinemas
Currently watching on: BenQ W1070, 106" 0.8 Gain Screen, Darbee, PS4, w/ Yamaha Aventage RX-A1030, NAD C370 (for Front L/R), Outlaw Model 5000, SVS PB-2000, SVS PC-2000, a Def Tech CS-8080HD, 2 SM65 for L/R, 2 SM55 for sides, and 2 PM1000 for rears.
fredxr2d2 is offline
post #9150 of 11931 Old 06-10-2014, 08:44 AM
bighvy76's Avatar
Quoted: 22 Post(s)
Liked: 29
Samsung and Sony make decent 3d bluray players (100-200). Was just wondering if they are any better then ps3. I was told the ps3 has a fairly good bluray system.
bighvy76 is offline
Benq W1070 1080p 3d Projector
