BenQ W1070 : DLP Full HD, 3D Ready with lens-shift for 1000$ - Page 308 - AVS Forum | Home Theater Discussions And Reviews
 374Likes
Old 06-13-2014, 09:17 AM
bighvy76's Avatar
Quoted: 22 Post(s)
Liked: 29
Originally Posted by ellisr63 View Post
They are about the size as a MAC Mini... My i3 NUCs are used as full fledged PCs and Media Servers for streaming 1080p movies. They only draw 25 watts max. We got them for 2 reasons: 1: small size, 2: energy efficiency.
So they have windows loaded on them and u can add a keyboard? I use my ps3 for everything now but would like to add a computer .
bighvy76 is offline
Old 06-13-2014, 09:22 AM
Adult Beverage's Avatar
Quoted: 38 Post(s)
Liked: 26
eric3316 and ellisr63 - Do either of you have any settings recommendations for new owners? I'm about to order the W1070 and was curious about what settings experienced owners are using.
Infamous last words: "Hold my beer. Watch this!"
Adult Beverage is offline
bori's Avatar
Quoted: 158 Post(s)
Liked: 123
All u guys using ps3 for 3d. What screen size are you using? I have an 100 inch screen would like to know if setting smaller screen will give 3d more pop.
bori is online now
Old 06-13-2014, 09:32 AM
ryudoadema's Avatar
I had mine set at 100" for a 100" screen. Pop seemed less than my standalone br player with both playing Pacific Rim, but it could have been my mind playing tricks. I recently set the ps3 to 50" but haven't tried it out yet. It may only affect games, I don't know. I've read that one topic on AVS where someone said setting it lower gave more effect, but not many responses.
Suffice to say I'd like to hear any thoughts/opinions on this as well...
ryudoadema is offline
Old 06-13-2014, 10:25 AM
eric3316's Avatar
Quoted: 778 Post(s)
Liked: 956
Here are two I know of.
http://www.soundandvision.com/conten...ector-settings
http://www.avforums.com/threads/benq...tings.1761516/
ellisr63 likes this.
eric3316 is offline
Old 06-13-2014, 10:30 AM
Medisinyl's Avatar
Quoted: 16 Post(s)
Originally Posted by d19racing View Post
Hey Guys,
I just bought the Sony BDP 5200 tonight and hooked it my my Receiver DNA1040 and Frame Packing Mode worked great.
Finally 3D Popped Out just like SBS Format.
So it wasn't the glasses after all. It was the PS3 ability to handle Frame Packing Format that has been issue all this time..... PS3 can't handle Frame Packing Mode.... Hence movie is FLAT....
Finally it works great as expected greats depth and great 3d Pop Out Effect...
Thank you Guys...........
Perhaps the PS3 just doesn't do 3D movies very well?
Medisinyl is offline
Old 06-13-2014, 10:46 AM
ellisr63's Avatar
Quoted: 873 Post(s)
Liked: 381
They come without any OS... I am running Windows 7 on on e and OpenElec/XBMC on the other 2. I use a wireless keyboard, and mouse for each one.
Yamaha CX-A5100, (3) JBL 2360As/EV DHA-1s, (3) 1/4 Pie bass bins, Xilica XP-4080 crossover, (2pr) JBL 8340As,  (2pr) JBL 8320s, PS3, XBox360, (2) Intel NUCs, Monoprice 12 gauge speaker wire, and XLR cables, Redmere HDMI cables, Monster HTPS7000, 2 DTS-10 subs, Panasonic AE8000, SeymourAV 195" diagonal scope screen, Panamorph UH-480, Darbee Darcet, Yamaha P7000s, (2) Crest Audio CM2208, (2) Parasound Zamps, (2) MiniDSP DDRC-88A.
The Ellis Family Go Big or go Home HT
ellisr63 is offline
Old 06-13-2014, 10:49 AM
ellisr63's Avatar
Quoted: 873 Post(s)
Liked: 381
Good point... I haven't tried any 3D movies with the PS3 so far, as I rip all my movies to mkv files and then watch them off of my NAS..
ellisr63 is offline
Old 06-13-2014, 11:31 PM
bori's Avatar
Quoted: 158 Post(s)
Liked: 123
Anyone know why benq keeps going back the standard setting? I set up user 1 hdmi1and 2 and 3d settings for just hdmi2. It seems to go back to standard then I have to go into settings and change it back.
bori is online now
Old 06-14-2014, 12:08 AM
Liked: 1
Hello from Germany!
I tried to update from 1.07 to 1.08.
Now the red LED is on all the time and the W1070 does not start anymore...
The update procedure seemed to be good, i did it with DLP composer light.
After the update it didn't want to restart, red LED still on.
Plug out few minutes and in again, still red LED :-(
Is there a solution, to awake the Benq again?
Mike.Dee is offline
Old 06-14-2014, 03:57 AM
eric3316's Avatar
Quoted: 778 Post(s)
Liked: 956
Strange, mine doesn't do that. It stays on whatever the last setting I used was for each input. Are you plugged directly into the projector?
eric3316 is offline
Old 06-14-2014, 04:26 AM
rwestley's Avatar
Quoted: 141 Post(s)
Liked: 95
[QUOTE=Mike.Dee;24957201]Hello from Germany!
Is there a solution, to awake the Benq again?[/QUOTE
Does not sound good. Did you set boot loader to 32KB. as per instructions?
7. Select Complete Image Download, and make sure to check “Skip Boot loader area (32KB)”
Did you wait until orange light came back on before unplugging the unit.
Doubt if this is possible but if you can try to upgrade again. If this does not work you will have to get Benq to fix it for you.
rwestley is offline
Old 06-14-2014, 05:27 AM
Liked: 1
@ rwestley
yo, did it as described at stevenbreuls.com
That is explaned very well...
When i was ready, unplugged the usb. Then tried to start by pressing Power, red LED was still on.
Waiting about 30 seconds, then unplugged power. May be to quick?!
Now, the DLP composer doesn`t find the USB Conection to the beamer.
Pressed Power and Auto again, put power in: no USB connection :-(
Mike.Dee is offline
Old 06-14-2014, 07:46 AM
Quoted: 38 Post(s)
Liked: 26
Does anyone know which firmware version new models are shipping with? Just ordered one and don't want to worry about updating it right away.
Old 06-14-2014, 08:44 AM
ellisr63's Avatar
Quoted: 873 Post(s)
Liked: 381
[quote=rwestley;24958593]
Originally Posted by Mike.Dee View Post
Hello from Germany!
@ rwestley
Was the LED orange before you unplugged it?
ellisr63 is offline
Old 06-14-2014, 09:45 AM
bori's Avatar
Quoted: 158 Post(s)
Liked: 123
Yes hdmi 1 is coming from receiver. Hdmi 2 is directly connected to ps3.
bori is online now
Old 06-14-2014, 10:14 AM
Liked: 1
Was the LED orange before you unplugged it?[/quote]
NO! The LED was still red!
I waited, untill the DLP composer was ready.
Then waited about one minute, nothing happened, unplugged the USB.
About one minute later, after trying the Power Button, unplugged the Power plug
Oh, oh....
Mike.Dee is offline
Old 06-14-2014, 10:19 AM
ellisr63's Avatar
Quoted: 873 Post(s)
Liked: 381
Oh, oh....[/QUOTE]
According to the instructions above it was supposed to be orange. I think you are going to have to send it to BenQ, and see if they can fix it.
ellisr63 is offline
Old 06-14-2014, 10:30 AM
Liked: 1
Yes, will send it to Benq...
There was no info of orange LED on that site, i took the update from.
Didn`t read here before...
I will try it again with a virgin Laptop, but don`t believe it will work, but try.
Thank you all for your help!!
Mike.Dee is offline
Old 06-14-2014, 11:13 AM
ellisr63's Avatar
Quoted: 873 Post(s)
Liked: 381
I have never done the upgrade... I was only going from this statement "Does not sound good. Did you set boot loader to 32KB. as per instructions?
Did you wait until orange light came back on before unplugging the unit." I hope BenQ can fix it for you... Is it still under warranty... If so I wouldn't tell them what you did as they say you have to return it to them for the upgrade.
ellisr63 is offline
Old 06-14-2014, 11:22 AM
Liked: 1
They optimized the repair support in germany sice 2013.
They pick it up and send it back, and do not ask very mouch...
I hope they are able and will just flash it.
If they have to charge, i will pay, for my own dullness, being to fast... not read enough... not waiting for orange...
I had the major problem of Color Branding. That was the reason of trying new firmware...
Mike.Dee is offline
Old 06-14-2014, 12:47 PM
rwestley's Avatar
Quoted: 141 Post(s)
Liked: 95
It should be 108.
rwestley is offline
Old 06-14-2014, 11:37 PM
draftd's Avatar
I have this projector. Used it only on ecomode and the bulb blew at 3200 hours. Shortly before it blew i did have inlaws in town who slept in the living room and kept it on for practically 3 days straight. Replacement bulb was $200 from projectorpeople. I used it a lot on a daily basis. We will see how this one goes but im going to have to say that 6000 hours is pushing it. All in all though i really like the projector i have pretty much every 3d movie available and enjoy them on it. Plus i got the chinese sainsonic glasses 2 for 50 six total and with all 6 running i never have them drop out or leave sync.
ryudoadema likes this.
draftd is offline
Old 06-15-2014, 04:47 AM
rwestley's Avatar
Quoted: 141 Post(s)
Liked: 95
Leaving the projector on for 3D straight was probably the cause of the bulb blowing. 3200 hours is not bad at all considering. I would suggest that your try glasses other than the Sainsonic.
Several other brands block the red flash much better and are not that expensive. The new 4th Generation HiShock being sold under various brands are great. They are very light.
rwestley is offline
Old 06-15-2014, 10:52 AM
Arcadia88's Avatar
Quoted: 51 Post(s)
Liked: 46
About to hit the buy button for the 1070 package. Is it possible to take down and repack a fixed frame screen once assembled? It's been 2 years since my old projector bulb gave up the ghost. I've been using a 46" lcd for so long that I've forgotten what a projector experience was. Will be nice to be able to move the chairs back to where they should be.
Arcadia88 is offline
Old 06-15-2014, 12:59 PM
robl45's Avatar
Quoted: 142 Post(s)
From reading the first 15 pages or so, it seems to say you can't get HSBS 3d without doing some resolution tricks, is this really the case?
robl45 is offline
Old 06-15-2014, 01:01 PM
kreeturez's Avatar
Quoted: 416 Post(s)
Liked: 333
Nope; straight 1080p@24hz is now sorted in the firmware bundled with all recent (and even not-so-recent) units; no tricks necessary anymore. Fortunately.
I'm not sure what BenQ were thinking with those original limitations - but they're all gone now.
BenQ W1070 Projector; Kodi (on Ubuntu, OpenELEC & S802) via Sony STR-DH540 AVR with Boston Acoustics SoundWare XS SE 5.1 Audio + Jamo 210 Sub. Emby for Mobile Streaming.
Helpful post? Click the 'Like' button!
kreeturez is offline
Old 06-15-2014, 06:58 PM
ryudoadema's Avatar
I agree with the glasses suggestion. I have three different types and each are liked by different visitors more, but these are my ratings on different criteria:
(1-5, 5 is best)
G15 on Ebay- Sync:5 Block Red:5 Weight:5 Comfort:3.5 Viewing/Lens Size:3.5 Price:5 Red/blue color change (when turning head):5
Estar ESG601- Sync:5 Block Red:5 Weight:4 Comfort:4.5 Viewing/Lens Size:4.5 Price:4 Red/blue color change (when turning head):4
3DTV Corp 4th-Sync:5 Block Red:5 Weight:4.5 Comfort:4.5 Viewing/Lens Size:4 Price:4 Red/blue color change (when turning head):4.5
gen (Hi-shock)
Any categories I forgot? Anyways my choice is the Estars and my girlfriend's is the 3Dtv Corps. None of them have much side view blocking, but the Estars have a little and to me is the most immersive (almost a toss-up with the 3Dtv Corp.). While the g15s are super light, the plastic slightly digs into the nose and is annoying. Though I can see slightly different tints when just putting them on and walking around, they all look great while viewing. I also never notice the color shift from red to blue (unless walking around with them), probably because you just don't turn your head that far away from the screen when watching.
Old 06-15-2014, 10:13 PM
Crestwood1001's Avatar
Quoted: 59 Post(s)
Liked: 39
Alright guys been heavily reading this thread and have some basic questions that are particular to my room that I would like to run by everyone here. As a note this is a dedicated "theater" or movie room. Right now I have a Samsung plasma (50") wall mounted, running a Yamaha rx-v373 on 5.1 audio with a good set of sony speakers, speaker wires, hdmi wires and everything else is run in the walls and terminated with wall plates. I have decided to step up to a W1070 as a budget friendly upgrade to the small 50" TV. This is by no means ment to be a pro level theater, just a great room to watch movies and play some PS4 in. Thank you in advance for the help!
Room dimensions:
Width - 11.45 Feet (137.5")
Length - 14.66 Feet (176")
Height - 8.25 Feet (99")
This a completely dark room, no windows, in a finished basement with a drop ceiling. The ceiling tiles are flat black and I am in the process of painting the rails flat black, the walls are currently the off white/tan color the builders painted it, but will be a flat dark mocha or similar color and the carpet will be ripped out and replaced with a dark color.
Now for the issues/questions I have for you guys, approximately 8.25' off the screen wall in the "center" of the ceiling is a fan, this will be removed as the lowest point of the fan (blades) is approximately a 1' drop off the ceiling so that will go to enable the hanging of the PJ. I will use the fans power source and put an outlet in there so no issue powering the PJ, as such it is very easy for me to run a longer HDMI cable up the wall into the drop ceiling cavity to feed the PJ, all of that is easy enough.
Now using BenQ's calculator for my desired 100" screen size I will have the PJ 8 Feet 4 Inches from the screen wall, perfect for the location the fan is being removed from where I will have power, my main question is about the distance the PJ will need to be mounted down from the ceiling, the entire screen wall is open for this purpose, the 3 front speakers are currently wall mounted but can be moved around on the wall as is necessary because I will be painting. I will be either buying a manual drop screen (no need for motorized as this is a dedicated room and the samy plasma will be relocated in the house), or doing a custom painted screen.
So I ask all of you, does that room size jive with a 100" screen? The viewing distance will be almost against the back wall, lets say 170" from the screen wall. Any tips for a first time PJ user???
Thank you guys, sorry for the long winded post!
Crestwood1001 is offline
Old 06-15-2014, 11:31 PM
ellisr63's Avatar
Quoted: 873 Post(s)
Liked: 381
I had almost 4000 hours on my bulb when I sent it in to BenQ for the fan problem... Bulb was fine still.
ellisr63 is offline
Benq W1070 1080p 3d Projector
taboola here
