BenQ W1070 : DLP Full HD, 3D Ready with lens-shift for 1000$ - Page 311 - AVS Forum | Home Theater Discussions And Reviews
 1417Likes
post #9301 of 12009 Old 06-18-2014, 07:00 PM
long_pn's Avatar
Quoted: 21 Post(s)
Originally Posted by ellisr63 View Post
You don't want abrupt turning off of the projector as the bulb doesn't get cooled by the fan when it is off. I run a UPS on mine, and I know a lot of people do for that reason.
Ok, thanks, what type of UPS should I get ?
In specs, W1070 consumes 353w, so the UPS should be at least 600VA, or 500VA is fine ?
Does offline UPS ok for it? (projector not sensitive to switch-over and output wave form)
After you power-off the W1070, the cooling system still operates for how long (I haven't read the manual yet), meaning the UPS backup time should be long enough for that ?
long_pn is offline
post #9302 of 12009 Old 06-18-2014, 07:13 PM
bluer101's Avatar
Quoted: 375 Post(s)
Liked: 295
I have a Belkin Pureav AVR and battery backup since 2007. I'm on my 3 set if batteries but it works great. I have my 60 inch Sony, cable box, 100 inch motorized elite screen and the w1070 all hooked up to it. For me I ran a heavy duty extension cord from the Belkin up my front screen wall to a surface mounted wall outlet. This is where I connect my screen. From that outlet I have romex they the ceiling over to where my w1070 is mounted. There I have another outlet for the PJ.
bluer101 is offline
post #9303 of 12009 Old 06-18-2014, 07:38 PM
Crestwood1001's Avatar
Quoted: 60 Post(s)
Liked: 39
Hey guys just jumped on amazon to grab a total for the W1070 and associated items for my upcoming order and the price on the W1070 has dropped from $749 to $729!!!!!!!!
Crestwood1001 is offline
post #9304 of 12009 Old 06-18-2014, 08:10 PM
Arcadia88's Avatar
Quoted: 51 Post(s)
Liked: 47
Price drop? Now? Sigh
The pair of hi shock 4th gen glasses delivered and now I've played around with 3d.
These glasses block the red sync and watching cars 2 3d was effortless. No eye strain no crosstalk no loss of sync as long as your facing the screen.
Super stardust hd in 3d is a new way to play. Splosions coming at ya.
The biggest negative I can think of is all the light leakage through the vents.
Arcadia88 is offline
post #9305 of 12009 Old 06-18-2014, 09:11 PM
bori's Avatar
Quoted: 194 Post(s)
Liked: 126
Do u have a link for those glasses?
bori is offline
post #9306 of 12009 Old 06-18-2014, 09:38 PM
Arcadia88's Avatar
Quoted: 51 Post(s)
Liked: 47
http://www.amazon.com/gp/aw/d/B00E1S65EM/ref=redir_mdp_mobile?ref_=pe_385040_30332190_TE_dp _1
post #9307 of 12009 Old 06-18-2014, 09:42 PM
bori's Avatar
Quoted: 194 Post(s)
Liked: 126
bori is offline
post #9308 of 12009 Old 06-19-2014, 05:55 AM
dedi's Avatar
Was anyone able to successful "overclock" the input refresh rate? Like 1080p/120hz, 72hz or 720p/120hz?
The only thing I found was this topic: BenQ W1080ST 120Hz operation - with the last post beeing able to accept 120hz, but with some missing horizontal lines. Also he did no test if it's actually true 120hz, and did not tweak the settings (eg. with toastyX custom resolution tool) or with lower refresh rate.
dedi is offline
post #9309 of 12009 Old 06-19-2014, 06:42 AM
shiseido's Avatar
picture quality only, should an "old" optoma hd8200 be better than a w1070? or could a used 8200 be better deal than a new 1070?!?!
shiseido is offline
post #9310 of 12009 Old 06-19-2014, 09:01 AM
kreeturez's Avatar
Quoted: 495 Post(s)
Liked: 387
I was able to do 720p@120hz (in 2D mode) a while back. No tweaking of settings required and no under/over-scan; it was simply listed in Display Settings as a supported resolution/frame-rate combination. The projector reported the correct input refresh-rate and it looked otherwise perfect.
See from Page 56 onwards of the User Manual for all the supported refresh rate timings - it appears that 1280x800 @ 120hz is supported as well.
BenQ HT2050 Projector; Kodi (on Ubuntu, OpenELEC & S802) via Sony STR-DH540 AVR with Boston Acoustics SoundWare XS SE 5.1 Audio + Jamo 210 Sub. Emby for Mobile Streaming.
Helpful post? Click the 'Like' button!
kreeturez is offline
post #9311 of 12009 Old 06-19-2014, 12:47 PM
wraunch's Avatar
Quoted: 122 Post(s)
Liked: 39
what ceiling mount is everyone using for this?
wraunch is offline
post #9312 of 12009 Old 06-19-2014, 01:14 PM
Adult Beverage's Avatar
Quoted: 40 Post(s)
What do you need and how much do you want to spend? How much room do you have? I'm installing the Peerless PRG-UNV tonight because I found it in white and got a good deal on it. Chief makes some highly recommended models. I went with a quality universal figuring it will work for the next PJ as well.
I played with the shift on my new W1070 yesterday and found that I have up to 5 inches from the center of the lens to the edge of the screen to play with. Going to need them all to get it up high enough to be out of the way.
Think ya used enough dynamite there, Butch?
Adult Beverage is offline
post #9313 of 12009 Old 06-19-2014, 01:18 PM
wraunch's Avatar
Quoted: 122 Post(s)
Liked: 39
I have a 9' ceiling and will most likely need to drop the projector down around 12" to clear my soffit. How much can I shift the image down with the w1070 without having to keystone? I'd prefer to get a mount for as cheap as I can but still get a quality product. Doesn't need to be name brand as nobody cares about that.
wraunch is offline
post #9314 of 12009 Old 06-19-2014, 01:44 PM
filtor's Avatar
Liked: 36
I have a UPS on my projector but it shuts off anyway when the power even blips a bit. My TV, computer and AVR stay on but the projector shuts off. Can anyone with a UPS confirm that this projector stays on with a UPS without the UPS being a double-conversion type. Mine is an older APC with newer batteries (2nd set). This UPS used to keep my Optoma on to power down .. but three times now has not done so for my 1070.
I read where some types of power supplies are very sensitive to voltage fluctuations and wonder if the 1070 has one of those?
filtor is offline
post #9315 of 12009 Old 06-19-2014, 02:10 PM
AV_Integrated's Avatar
Quoted: 1148 Post(s)
Liked: 825
Almost all non-name brand mounts are cheap, non-adjustable, pieces of junk. Projectors drift, don't lock down properly, and are difficult to adjust. So a quality mount will make you happy over the long term compared to everything else. To this point, I've seen no 'cheap' mount that is worth using.
In order: Chief RPMAU, Peerless PRG-UNV, Chief RPAU, then a ton of junk.
Check eBay for options and pricing on used/open box/old stock. About $80 or so.
Lens shift: The W1070 can be about 5" above the top edge of a typical screen at the most. Double check before mounting your screen/projector.
ellisr63 and eric3316 like this.
AV Integrated - Theater, whole house audio, and technology installation in the Washington DC metro area.
AV_Integrated is offline
post #9316 of 12009 Old 06-19-2014, 02:49 PM
bori's Avatar
Quoted: 194 Post(s)
Liked: 126
That's what i use. Best investment. My job uses chief mounts for all there projectors too.
bori is offline
post #9317 of 12009 Old 06-19-2014, 03:36 PM
rekbones's Avatar
Quoted: 503 Post(s)
Liked: 256
The Optoma HD8200 is a much better projector than the 1070 for 2D, no 3D. Of course used is always a gamble, manufacturer refurbished should be fine. Better blacks as it has an iris,DC3 chip, large lens shift both horizontal and vertical, better optics, RGBRGB color wheel and FI. It did have some reliability issues when it first came out. Of course this is in a good room, if the room is less than ideal than the 1070 might work better for you
"Smart enough to know better, to old to care" ------ Dedicated Home Theater, Mitsubishi HC7900DW Projector, 110" 16:9 Jamestown screen with variable power masking for CIW 2.50:1 to 16:9, Marantz 7009 with 7.1.4 Atmos with Ohm mains,3 DIY Subs (2 15" (1 ported, 1 sealed and a 12" 4th order bandpass), 1 DIY butt kicker, Custom Built HTPC, 10TB DroboFS NAS
rekbones is offline
post #9318 of 12009 Old 06-19-2014, 06:07 PM
long_pn's Avatar
Quoted: 21 Post(s)
That is what I'm worry about when getting a new off-line UPS. You never know if the projector PS is sensitive to the UPS switch-over or not.
The best way is to ask the users here what type of UPS they have for the W1070
long_pn is offline
post #9319 of 12009 Old 06-19-2014, 06:48 PM
dolphinc's Avatar
Quoted: 97 Post(s)
Liked: 68
How old is the battery backup, typical battery life is around 18 months or so.
Also if you look at most battery backups there are 2 sides, one says "battery and surge" the other states "surge only", make sure you have it on the battery and surge side.
dolphinc is offline
post #9320 of 12009 Old 06-19-2014, 06:52 PM
filtor's Avatar
Liked: 36
It's connected to the correct side. Latest battery maybe a year old - still holds charge and runs HTPC, AVR and TV but 1070 shuts off even if the UPS chirps for a micro-second.
AGAIN - can anyone with a 1070 on a standard UPS confirm it staying on if power is interrupted?
filtor is offline
post #9321 of 12009 Old 06-19-2014, 08:58 PM
hotjt133's Avatar
Quoted: 21 Post(s)
Liked: 30
I think there is also a bug in the 1070's power management. It not only shut down due to a power cycle, it even shuts down when I plug in or out the 3.5mm audio cable! I'm been hit with this problem twice. Each time it just abruptly shuts down, fan shuts down as well. This must have eaten several hundreds of lamp hours.
hotjt133 is offline
post #9322 of 12009 Old 06-19-2014, 09:04 PM
mega129's Avatar
Hello
My new house (closing next month) has a media room with dimensions: 11' by 18' and 9' ceiling. The electrical outlet is placed on the ceiling at about 14' from the screen wall.
When I saw a great deal on the 1070 at the Benq outlet store last month, I just jumped on it. But now I'm not sure this will work based on the calculations from projector central.
I figure the largest screen my wall can handle is about 120" diagonal allowing for my tower speakers on either side. That translates to throw range between 10' and 13'. I assume throw range means I can ceiling mount the projector anywhere in this range from the wall to get the 120": diagonal picture?
So looks like it's about a foot short of where I need it. Unless of course I take into account the length of the power cord, etc, which may still not be enough, or would it?
Or should I just return it to Benq (still have until end of the month) and get the Optoma HD25 which has a longer throw distance and seems a better fit for my room conditions?
Would appreciate any advice, TIA
mega129 is offline
post #9323 of 12009 Old 06-19-2014, 09:35 PM
Quoted: 60 Post(s)
Liked: 39
Originally Posted by mega129 View Post
Hello
The benq should work just fine with your plan, it does not need to be placed directly next to or in front of the outlet, it has an average length power cord
post #9324 of 12009 Old 06-20-2014, 04:03 AM
shiseido's Avatar
Thanks rek, the major problem is that the hd82 is not refurbished but used and its realy a gamble (ive had 3 epson pjs!!), so ive opted for the benq.
my living room has light walls end roof but i can get all the lights off, but not ideal batcave....
shiseido is offline
post #9325 of 12009 Old 06-20-2014, 04:53 AM
rekbones's Avatar
Quoted: 503 Post(s)
Liked: 256
Good choice, especially in a light colored room.
rekbones is offline
post #9326 of 12009 Old 06-20-2014, 05:15 AM
bluer101's Avatar
Quoted: 375 Post(s)
Liked: 295
I agree with you. If it's only off by a foot or so that's not a big deal.
bluer101 is offline
post #9327 of 12009 Old 06-20-2014, 05:17 AM
bluer101's Avatar
Quoted: 375 Post(s)
Liked: 295
I have had an issue when I was trying the 3.5 trigger. It shut down and started to blink error. I had to unplug the PJ to reset it.
I can try my ups later to see what happens.
bluer101 is offline
post #9328 of 12009 Old 06-20-2014, 06:15 AM
Arcadia88's Avatar
Quoted: 51 Post(s)
Liked: 47
I've got a two year old 1500VA UPC from APC. It's connected to all my HT equipment including the new 1070. I yanked the power from the wall and the meter says I have about 20 min of backup power. This is with the 1070, sony dn1000 (soon to be a 1040) and one game machine, and my cable modem and router. I have not tried turning on all of my equipment at the same time as thats not usually how I run things.
Everything including the 1070 stayed powered up.
post #9329 of 12009 Old 06-20-2014, 06:46 AM
mega129's Avatar
Thumbs up
Hey there Crestwood1001, thank you so much for your prompt and helpful advice. I didn't really want to return it anyway so I'm happy to know that I can make it work.
mega129 is offline
post #9330 of 12009 Old 06-20-2014, 07:40 AM
Kilikkun's Avatar
Liked: 0
I'm looking to buy my first projector. I've seen the W1070 pop up a lot because of how good it is for it's price. A local best buy has an open box Sony HW30ES for about double what I'd be paying for a new W1070. The Sony is a little older than the BenQ but I was wondering if it would still be the superior projector? Any insight on comparisons between the two would be great. Thanks
Kilikkun is offline
Benq W1070 1080p 3d Projector
