BenQ W1070 : DLP Full HD, 3D Ready with lens-shift for 1000$ - Page 312 - AVS Forum | Home Theater Discussions And Reviews
 388Likes
post #9331 of 11919 Old 06-20-2014, 09:58 AM
Adult Beverage's Avatar
Quoted: 39 Post(s)
Liked: 27
What is your room setup? Screen size and type, room dimension, throw distance, light control (wall/ceiling color, window treatments), seating distance, etc. It doesn't make sense to spend a lot more on a projector if the room won't allow you to see the difference.
Think ya used enough dynamite there, Butch?
Adult Beverage is offline
post #9332 of 11919 Old 06-20-2014, 10:21 AM
nightnday's Avatar
Hey all I just wanted to give a update on my projector that I guess got dust inside the lens. BenQ really did well by me they sent me a March 2014 projector with the latest firmware update. I wish they did this the first time but it was still easy to deal with them just my personal experience so others may vary I hope the same.
So happy to be back in action guys =)
Much love to BenQ
nightnday is offline
post #9333 of 11919 Old 06-20-2014, 11:02 AM
Kilikkun's Avatar
Liked: 0
I currently don't have a screen either. Looking at 120". I can get a screen with whatever gain I'll need for optimal results. Max throw distance would be about 18 feet if I were to set it on a back shelf. I can set it up on a table about 13 feet back as well. Seating distance is 11 feet. This will be in my family room so there is some light. All 3 windows have wooden blinds and direct overhead lighting will be off for all viewing. Light in the adjacent kitchen may be on for regular TV and sports viewing. Walls are a light beige.
Kilikkun is offline
post #9334 of 11919 Old 06-20-2014, 11:17 AM
pdxrealtor's Avatar
Quoted: 141 Post(s)
Liked: 150
What have people discovered to be the best 3d glasses choice for this PJ? I know nothing about what to look for. Any suggestions?
___________________
RE: mounts -I'm using a monoprice mount with great success. Lock down the screws tight and the thing won't budge. I have four long throw 18" monster subs currently on 15kw of power and once I locked down the screws I haven't had to re-adjust the PJ.
They come in different lengths. I got the 8802 - http://www.monoprice.com/mobile/Prod...geGallery/8802
pdxrealtor is offline
post #9335 of 11919 Old 06-20-2014, 12:03 PM
AV_Integrated's Avatar
Quoted: 955 Post(s)
Liked: 709
Originally Posted by mega129 View Post
The electrical outlet is placed on the ceiling at about 14' from the screen wall.
...the largest screen my wall can handle is about 120"...
I'm just going to agree with others on this. The power connection is at the back of the projector, as is the HDMI connection. Since the 10' to 13' distance is based from lens to screen, and the projector is almost a foot deep. The outlet will be very close to where you need to plug it into.
Watch the lens offset though - the center of the lens must be about 2" to 5" above the top of the screen and dead center (left/right) of the screen.
You should be fine.
AV Integrated - Theater, whole house audio, and technology installation in the Washington DC metro area.
AV_Integrated is offline
post #9336 of 11919 Old 06-20-2014, 01:14 PM
Movie78's Avatar
Quoted: 783 Post(s)
Liked: 237
What are picture setting you guys are using?
I am playing all my Movie from XBMCUBUNTU and the picture looks dark....
Sometimes i can't determine the difference a man wearing black suit with a dark scene.
Movie78 is offline
post #9337 of 11919 Old 06-20-2014, 01:36 PM
Quoted: 39 Post(s)
Liked: 27
I haven't been able to find many, despite the popularity of this model. I think because it looks so good out of the box you don't have a lot of people tweaking. Above appear to be the choices but to tell the truth, beyond switching to Cinema mode, not sure I like the AVForum ones any better. I haven't tried the Sound And Vision ones yet. Bulb is also new so hard to hit a moving target right now. The actual viewing environment plays a part in the settings as well.
post #9338 of 11919 Old 06-20-2014, 01:52 PM
bori's Avatar
Quoted: 187 Post(s)
Liked: 125
I used the avs one for 2d and the S&V for 3d.
bori is offline
post #9339 of 11919 Old 06-20-2014, 01:57 PM
Quoted: 39 Post(s)
Liked: 27
I mounted and fine-tuned the W1070 last night. Temporarily. I am going to build a 110" screen to replace the 96" I currently have. When I do that i will be able to raise the W1070 about 6 inches, allowing me to get it up a comfortable distance. The ceiling is only 7'4" and it's hanging a little low right now. Pictures are of the W1070 with my old Optoma HD65 before taking the old one down. I'm using the Peerless PRG-UNV with a 4" extension and the Peerless ACC570 plate. When I raise the BenQ I will just eliminate the plate and extension. Second picture is my old PJ mount, a cheap satellite speaker mount. It was the perfect length and lasted 6 years.
ID:	128537   Click image for larger version
AV_Integrated likes this.
post #9340 of 11919 Old 06-20-2014, 02:43 PM
Movie78's Avatar
Quoted: 783 Post(s)
Liked: 237
I have try both settings,but still the same issue.
Movie78 is offline
post #9341 of 11919 Old 06-20-2014, 02:45 PM
fredxr2d2's Avatar
Quoted: 169 Post(s)
Liked: 96
It sounds like your gamma setting is too high. Try turning it down and see if that helps. Otherwise, I'd look into calibrating brightness/contrast with a disc like Disney's WOW or Spears and Munsil.
Tim S.
Former 35mm and Digital Projectionist @ Regal Cinemas
Currently watching on: BenQ W1070, 106" 0.8 Gain Screen, Darbee, PS4, w/ Yamaha Aventage RX-A1030, NAD C370 (for Front L/R), Outlaw Model 5000, SVS PB-2000, SVS PC-2000, a Def Tech CS-8040HD, 2 SM65 for L/R, 2 SM55 for sides, and 2 PM1000 for rears.
fredxr2d2 is online now
post #9342 of 11919 Old 06-20-2014, 03:01 PM
dolphinc's Avatar
Quoted: 86 Post(s)
Liked: 63
I setup this last week, I used the BenQ mount model number BenQ 5J.J4N10.001. I paid $55 for it on amazon, works fantastic, super easy to dismount if needed. Room is still a work in progress, i painted the ceiling and projector wall flat black and the other 3 walls flat dark blue. More work this weekend.
dolphinc is offline
post #9343 of 11919 Old 06-20-2014, 03:03 PM
dolphinc's Avatar
Quoted: 86 Post(s)
Liked: 63
Attachment 128593
Why are my photos uploading upside down?
dolphinc is offline
post #9344 of 11919 Old 06-20-2014, 03:05 PM
pdxrealtor's Avatar
Quoted: 141 Post(s)
Liked: 150
I used the settings from projector central and haven't looked back. Huge improvement. I also use mine in eco mode.
As mentioned above, the W1070 has extensive color controls and calibrates very well. Our settings for Cinema mode look like this:
Gain R3 G-3 B0 Offset R-7 G1 B9 Those adjustments give the W1070 a near-perfect 6500K grayscale across the board.
http://www.projectorcentral.com/benq...ge=Performance
post #9345 of 11919 Old 06-20-2014, 03:06 PM
pdxrealtor's Avatar
Quoted: 141 Post(s)
Liked: 150
Because this 'new' forum format, is actually very old technology. In other words - It sucks.
dolphinc likes this.
post #9346 of 11919 Old 06-20-2014, 03:09 PM
dolphinc's Avatar
Quoted: 86 Post(s)
Liked: 63
Well if everyone stands on their head then they can see my photo the right way.
pdxrealtor likes this.
dolphinc is offline
post #9347 of 11919 Old 06-20-2014, 03:16 PM
Movie78's Avatar
Quoted: 783 Post(s)
Liked: 237
Will try when i go home.
Movie78 is offline
post #9348 of 11919 Old 06-20-2014, 03:20 PM
Movie78's Avatar
Quoted: 783 Post(s)
Liked: 237
Is that their full complete settings?
Movie78 is offline
post #9349 of 11919 Old 06-20-2014, 03:29 PM
pdxrealtor's Avatar
Quoted: 141 Post(s)
Liked: 150
Yes. You can verify by clicking on the link I provided.
post #9350 of 11919 Old 06-20-2014, 08:24 PM
Quoted: 39 Post(s)
Liked: 27
I don't understand where to put these numbers in. All the RGB type numbers are in the 50 or 100 range as starting points in the menus. Are these numbers how much to bummp them up (+) or down (-)?
post #9351 of 11919 Old 06-20-2014, 08:26 PM
pdxrealtor's Avatar
Quoted: 141 Post(s)
Liked: 150
Oh man.... it's been a while since I've put them in, and not in front of my PJ. If you still don't have it figured out in a couple days (out of town till then) PM me as a reminder and I will help you out!
post #9352 of 11919 Old 06-20-2014, 09:58 PM
ellisr63's Avatar
Quoted: 989 Post(s)
Liked: 410
It must be as there are no negative numbers possible.
Yamaha CX-A5100, (3) JBL 2360As/EV DHA-1s, (3) 1/4 Pie bass bins, 4 JBL 8340As, 4 JBL 8320s, PS3, XBoxOne, 2 Intel NUCs, Monoprice speaker wire, and XLR cables, Redmere HDMI cables, Monster HTPS7000, 2 Furman filters, 2 DTS-10 subs, Panasonic AE8000, SeymourAV 195" diagonal scope screen, Panamorph UH-480, Darbee Darcet, Yamaha P7000s, (2) Crest Audio CM2208s, Yamaha XM-4080, (2) MiniDSP DDRC-88.
The Ellis Family Go Big or go Home HT
ellisr63 is offline
post #9353 of 11919 Old 06-21-2014, 05:21 AM
eric3316's Avatar
Quoted: 835 Post(s)
Liked: 959
I was just about to reply to your picture and ask why you mounted the projector on the floor. Good thing I read your next post. lol
eric3316 is offline
post #9354 of 11919 Old 06-21-2014, 08:01 AM
TinnEars's Avatar
Liked: 73
I've seen this happen on other forums and on eBay. If one uses the OS to rotate the thumbnail image then the image may not stay rotated when uploaded. The image must be opened in a program that allows "re-saving" the image after rotation. Something as simple as Windows Photo Viewer/Editor will work.
TinnEars is offline
post #9355 of 11919 Old 06-22-2014, 05:31 AM
JPHCCFC's Avatar
Quoted: 12 Post(s)
It looks like I will be purchasing a Benq w1070 have managed to find a good deal for a brand new one on craigslist. Is there any advice or tips on what to look for (e.g. state of packaging) to give me confidence it is brand new and not a refurb
JPHCCFC is online now
post #9356 of 11919 Old 06-23-2014, 06:47 PM
Liked: 0
Hello All,
I am trying to setup a home theater myself to save some cash . i have the speakers/sub/receiver setup. Got the benq w1070 projector as it's highly rated and a 135" screen. The room has no windows and a dark paint.
I am hoping someone can help me with the questions i have --
1) What do i mount first, projector or screen ? I am guessing it will be projector that needs to be mounted first.
2) I got the following mount from amazon - http://www.amazon.com/gp/product/B009CWJRWY
The power outlet is around 13' from the wall. What i wanted to know is whether there is an exact distance i need to attach the mount at ? Or i attach it near the outlet on a joist and then turn on the projector and mount the screen accordingly.
3) I think the top of the mount that attaches to the ceiling is a little to wide and i can not attach all 4 screws in the joist, do you guys think that 2 screws will hold the load ? Or i should attache the other two will dry wall anchors ?
4) Any other things that experts here think i should keep in mind before i start creating holes in the ceiling ??
Thanks a lot ..
JackD121 is offline
post #9357 of 11919 Old 06-23-2014, 08:24 PM
Quoted: 955 Post(s)
Liked: 709
You mount the screen first when possible at a height that you are comfortable with, then line the projector up to hit the screen properly.
Well, you got really lucky on this (I'm guessing) because the W1070 MUST have the lens between 11'4" and 14'9" from a 135" diagonal screen. So, you can mount it to any joist, with the lens on center to the screen, with the lens about 2"-4" above the top of the screen and you will be able to fill a 135" diagonal screen.
http://www.projectorcentral.com/BenQ...ulator-pro.htm
Two quality screws will hold several hundred pounds of weight. You are fine with two heavy duty screws. Not cheap drywall screws.
What wiring did you run to your projector? You have multiple HDMI cables at it? Cat-5e/6 cables? Is the screen a roll down/up screen or a fixed frame screen? Dark paint on the ceiling as well? Dark carpet? That all helps. With low ceilings, that mount may need to be very close to it for good results.
I can be really critical of all of this, but only to give you ideas and make suggestions, take it as you will.
post #9358 of 11919 Old 06-23-2014, 08:26 PM
Quoted: 955 Post(s)
Liked: 709
You ask why they are selling it. Bring a HDMI cable and a source with you to SEE it work. You should go to the person's home to buy it so you know where they live in case there is an issue. Warning signs are people that won't conduct business personally, in their home. If they won't, then you want to go to a place where you can test it, see it work, go through the menus, and hook up a HDMI source (camcorder, iPhone, etc.) to the projector directly and see it work properly on a wall. Buyer beware on this type of stuff. Since the projector is available for under $750 brand new online, buying it used is a gamble that's entirely up to you to take. I would never do it personally.
JPHCCFC likes this.
post #9359 of 11919 Old 06-23-2014, 08:47 PM
Liked: 0
Ok, good i checked here
I ordered the screen after checking the distance on benq and projector central. 135 is the size that was suggested to me there also. Only posting in this thread since this seems specific to the proj i bought.
I have a hdmi cable and cat5e cable running to the projector, next to the cables there is an empty pipe going from projector outlet to component closet, any clue what this is for ?
Ceiling has dark paint but carpet is not that dark (kina like khaki color). The screen is fixed frame.
On another note, the builder didn't even put rj45 connectors on the cat 5 cable .. more work for me
Thanks for all your help ..
JackD121 is offline
post #9360 of 11919 Old 06-23-2014, 08:49 PM
Quoted: 955 Post(s)
Liked: 709
Just used my BenQ for 3D for the first time this weekend. I was using a set of the Sainsonic 3D glasses.
Similar to these, but I can't find the exact model I got. They were a Christmas gift and I'm finally getting around to trying them for the first time...
http://www.sainsonic.com/3d-active-g...projector.html
I was very happy with the results. Easily as good, if not better than what I get at the movie theaters. This was something I wasn't sure about at all.
The DLP Link is a interesting technology. The screen turns completely red when using DLP Link which surprised me. The glasses did a good, but not perfect, job of blocking the red out. I wish that the red wasn't quite so intense in the image, but it is what it is I suppose, but BenQ could certainly benefit from making available an aftermarket RF system for their projectors (all of them).
Still, the 3D was good. I watched Prometheus. It did not have extraordinary pop-out, but it was decent. It was pretty much what I was expecting. I may go watch Avatar and see how that looks.
Plusses:
BenQ immediately recognized the 3D disc and started playback. I didn't touch the projector, BD player, or anything else. I just stuck the disc in and it started to work.
The glasses were easy to use. One touch turned them on and they synced right up.
The glasses 'power' button also reversed the sync. This wasn't necessary, but worked flawlessly. After they were on, one touch and they switched sync. One touch again and they switched back. Press and hold for a few seconds and they powered off. Worked perfectly!
The pop-off effect was decent. I'm not sure if the Panasonic allows me to adjust for screen size, but I will check in their setup/menu system to see if I need to adjust from my 64" screen to the 161" screen I was using.
Brightness was reasonable considering my screen size. It was a bit dark, but acceptable. I will know better after I see a few more movies.
Minuses: Probably my biggest issue was that the glasses allowed some red through from the DLP Link sync signal. From what I understand, this is a glasses issue, so I may pick up another couple of pairs from a different manufacturer and see how they perform.
Overall: I was excited by the entire process. It was great to see just how easily it worked and how good it looked. I have crosstalk issues every time I go to a movie theater, so IMO, this had less cross talk and provided as good, or better of an overall experience.
My player: Panasonic BD220.
HDMI: Monoprice HDBaseT - 50 feet to the receiver. Then 40' over HDMI to the projector.
Audio - Just using stereo audio at the moment for this as it was just a test.
Screen size: 161" screen - 1.3 gain
Used the BenQ default 3D settings. Adjusted brightness partway though, then adjusted back down as it raised the black levels to much.
I didn't check to see if the projector kicked up to high brightness mode or not, I may check that with my next viewing.
At some point I need to try 3D through my computer, but I have not done this yet to see how/if it works well.
Benq W1070 1080p 3d Projector
