BenQ W1070 : DLP Full HD, 3D Ready with lens-shift for 1000$ - Page 338 - AVS Forum
post #10111 of 10136 Old 10-09-2014, 01:48 PM
Movie78's Avatar
Quoted: 29 Post(s)
Originally Posted by AV_Integrated View Post
No problem at all.
Unfortunately, no. In fact, the HDMI 1.4 specification doesn't allow for this, and HDMI 1.4 doesn't have the bandwidth to support 1080p/60hz frame packed 3D, or 1800p/120hz material.
Since movies are shot at 24hz, it works out just fine for movies, and IMO, looks better than what you typically see at a movie theater as long as you are using decent 3D DLP Link glasses.
What 3D DLP Link glasses are you using?
Movie78 is offline
post #10112 of 10136 Old 10-09-2014, 07:10 PM
AV_Integrated's Avatar
Quoted: 231 Post(s)
Liked: 328
I bought the Sainsonic ones first, and while they were very nice, I detected some red flash (DLP Link syncing mechanism) through the glasses.
I then read this thread:
Benq W1070 144Hz Compatible DLP-LINK 3D Glasses
Which has 900 replies specifically about glasses for the W1070, and I bought a pair of the EStar glasses.
http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
They were better. So, I bought another pair of them.
The thread I linked to details some cheaper glasses which work very well, but if I were buying for the family, I would try to get 4 sets of the EStar glasses.
These are the cheap ones which are reported to do a good job. I have not ordered any or tried them personally:
http://www.ebay.com/itm/G15-DLP-3D-A...item2c8ccaa5d4
AV Integrated - Theater, whole house audio, and technology installation in the Washington DC metro area.
AV_Integrated is offline
post #10113 of 10136 Old 10-09-2014, 09:07 PM
Tangled Cable's Avatar
Quoted: 70 Post(s)
Liked: 29
I just got some EStars. Along with the EStars I own two other brands that work fine, but the EStars are my new favorites. Very light, very clear picture. The lenses are pretty reflective so you might, say, see the lights from any equipment behind you mirrored in them, but I'm still very happy I bought them.
Tangled Cable is offline
post #10114 of 10136 Old 10-10-2014, 06:12 AM
cdudeman's Avatar
I have 3dtv corp 3d glasses that I bought from amazon and I don't have any issues.
cdudeman is offline
post #10115 of 10136 Old 10-10-2014, 07:26 AM
grubadub's Avatar
as a new owner of the W1070 i have a couple questions:
has anyone on here tried this projector with the Darbee?
is there any maintenance needed? do you occasionally vacuum the vents?
grubadub is offline
post #10116 of 10136 Old 10-10-2014, 10:45 AM
Liked: 0
Hey AVS! Is there any way to connect a Chromecast to the BenQ W1070 without having to plug it into a power outlet? Would it be able to work with the mini-b port? Thanks
mrtonytoca is offline
post #10117 of 10136 Old 10-10-2014, 10:49 AM
Liked: 0
You Tube - BenQ W1070 + Darbee
There is a guy who has a few videos of his Benq w1070 + Darbee
post #10118 of 10136 Old 10-10-2014, 11:47 AM
Quoted: 70 Post(s)
Liked: 29
I did. It seemed to enhance detail in some instances, but then looked artificial in others--made actors look like they were wearing pancake makeup, for instance. I returned mine. I posted a slightly more detailed review in the darbee thread if you want to look for it.
post #10119 of 10136 Old 10-10-2014, 12:27 PM
chmcke01's Avatar
Quoted: 12 Post(s)
Vacuuming?
I have read some people recommend vacuuming the vents (but NOT using canned air!). Anyway, would it be best to vacuum it when it is turned off or on...or does it even really matter?
chmcke01 is offline
post #10120 of 10136 Old 10-10-2014, 12:57 PM
Movie78's Avatar
Quoted: 29 Post(s)
Movie78 is offline
post #10121 of 10136 Old 10-10-2014, 02:18 PM
Argyle Shepard's Avatar
Quoted: 12 Post(s)
Hey guys. Been wanting to get back into front projection for years (my last PJ was a Sanyo Z3) and soon I'm going to be able to!! I really want to go with the 1070 as I've read so many great things for so long. We found a house and I went to do some measurements today. So I have 2 options, I can convert the den into my HT but it's going to require a bit of work and may not even be possible. The other option is a 3rd bedroom which is spacious enough but I would like to keep it a bedroom and will only convert it as a last resort. Here's my den dilemma. The attached picture is a profile view of what the room is like. The ceiling slopes down about 2 feet in the area where the couch would sit. The projector would be about 10' away for 120" image. What I'm trying to figure out is if the ceiling drop plus the ceiling mount would cause the image to be way too low to project at an even height. I know the image starts in the center of the lens and drops when the 1070 is upside down. What I don't know is if the vertical correction is limited enough that it wouldn't help me here. Any help is much appreciated. Oh, another option would be the short throw version if this projector, but I have a toddler and I'd like to keep cables off the ground. Thanks!
Argyle Shepard is offline
post #10122 of 10136 Old 10-10-2014, 03:15 PM
akm3's Avatar
Quoted: 73 Post(s)
My Oppo has Darbee built in.
I haven't done any maintenance yet, if I notice it is dusty I would probably vacuum it.
It's hard to love Martin Logans and 2.35:1 CIH at the same time...
akm3 is offline
post #10123 of 10136 Old 10-11-2014, 02:25 PM
ack_bk's Avatar
Quoted: 26 Post(s)
Liked: 105
I don't have a W1070, but I have used my Darbee with several other projectors (Acer, Optoma) and it works quite well. You want to calibrate your PJ with Darbee off first, then turn Darbee on and find the setting that works best for you. I have never been a fan of over sharpened images and traditional edge enhancement, but the Darbee, on more mild settings, really enhances the picture without causing the side effects.
ack_bk is offline
post #10124 of 10136 Old 10-13-2014, 01:50 PM
Quoted: 231 Post(s)
Liked: 328
The lens must be about 2" above the top of the screen. So, if (after mounted) the center of the lens is 6" from your ceiling, that puts it about 6'6" from your floor, which puts the top of your screen 6'4" from the floor. With a 120" diagonal screen (about 5' tall), the bottom edge of the projected image would be about 10" from the floor.
If that's to low, you could look at the Epson 3000 which has lens shift and could have the image a good deal higher and is adjustable with a lot more lens shift (full image could be above to below the lens or anywhere between) and should look reasonably good. Not W1070 good, but still should be quite respectably good.
Or, you could go with the W1080ST and move the projector into the other part of the room and drop it down on a pole, which may not be acceptable, but would work.
post #10125 of 10136 Old 10-13-2014, 02:57 PM
Quoted: 12 Post(s)
Integrated, I can't quote you from my phone but thank you. We decided to use a bedroom as the den space has so much going against it. The room isn't perfect but lacks about 3 obstacles that the den has.
post #10126 of 10136 Old 10-15-2014, 02:29 AM
felonyr301's Avatar
Hey guys have the w1080st and I am about to hit the 1 year mark and have been loving my projector for gaming and movie watching. I literally use it as a TV replacement and so I have reached 2200 hours in 1 year. Lots of times I use eco blank mode since i will be stepping out for a bit but dont want to turn it off completely since I heard it was bad for the projector.
I have just noticed the right side is slightly more darker than the left side and I am talking about while watching anything. I know about the uniformity when there is a white screen or web surfing and it never bother me it was not that bad.
The dimmer side can even be noticed when I put all black screen like the right side has slightly better black level sort of way. I can tune it out myself and nobody else notices when watching anything but I am wondering is this just an aging bulb?
If I replace the bulb will it be back to new or this is something wrong on projector. Would like to know this is my first projector and loving the performance.
Thanks in advance.
Xbox Live Gamertag: FELONY 301
PSN ID: FELONY--301
No problem adding people...
felonyr301 is online now
post #10127 of 10136 Old 10-15-2014, 08:30 AM
Liked: 0
Hey guys, really enjoying my w1070 so far (I've found AV_Integrated is a great source of info regarding projectors). I was wondering what the general consensus on lamp life is. I talked to a guy at BenQ and he was absolutely clueless. I've heard the average seems to be 3500 hours at full power, 6000 hours in smart eco mode (with variations in either direction of course, lamps being fickle like all electronics). Is that more or less what most people get out of it? Also, I'm confused about something.......I've been running the projector in eco mode thinking I'd save the most power and extend lamp life that way (I mostly use it for movies and PS4 games), but a look at the manual says that running the lamp in SmartEco mode consumes 70% less lamp power as opposed to 30% in eco. Should I be running my projector in SmartEco if I want to extend lamp life to it's maximum? I'd think full eco mode would extend lamp life the most......right? I'd like to get as much mileage outta the lamp as possible.
Oh, one last thing.......I've read a bit about the 'chirping' caused by SmartEco, and that the lamp life difference between eco and SmartEco isn't worth it. Accurate? Any advice is appreciated!
jmphipps0428 is offline
post #10128 of 10136 Old 10-15-2014, 10:24 PM
felonyr301's Avatar
Run it in economy mode smart eco just runs as bright as normal for me no matter what and uses eco mode fan speed and I believe that can cause issues from earlier users but I have not kept up if new update got rid of it.
PSN ID: FELONY--301
post #10129 of 10136 Old 10-16-2014, 04:33 AM
Liked: 0
Hello all,
This is my first post here. Two weeks ago I wasn't even considering a projection home theater. Saw one, caught the bug, found this forum, and you know how the rest of it goes - many hours spent reading threads, looking at specs, measuring the room....heck, I woke up at 3am the night before last and started thinking about it . Anyway, this site is a fantastic resource.
I do have a question, and despite some searching I haven't found an answer. I'm very interested in the W1070. I've been to the BenQ site and I've plugged measurements into their calculator. According to their calculator it looks like with an 8'6" throw I'll be able to get a 101" diagonal image, which seems perfect for the room. However, when I use the Projector Central calculator and I plug in the same measurements it tells me I can only get 90".
That's quite a difference. Obviously I'm a newbie at this so if I'm missing something obvious please forgive me....but why am I seeing such a big difference between these two calculators?
Thanks in advance for any comments, advice, or opinions - and thanks to the forum admins for allowing this site to exist. It's cool .
buzz fretwear is offline
post #10130 of 10136 Old 10-16-2014, 04:35 AM
chmcke01's Avatar
Quoted: 12 Post(s)
Like it
Well I only have about 1500 hours on my bulb but I tried out the different settings for the first week hundred hours or so but decided I liked SmartEco best and have stayed on that ever since. I do notice it get brighter for scenes that benefit from being brighter and darker for scenes that don't need the extra brightness. I have had zero problems so far and plan to keep it in SmartEco unless the bulb dies early. If the bulb dies before 4000 hours I will definitely switch to Eco, if it dies after 4000 hours but before 5000 hours it could go either way, but if it lasts 5000+ hours as rated then I will definitely stick with SmartEco.
I will make sure to post how it held up when the bulb does die.
chmcke01 is offline
post #10131 of 10136 Old 10-16-2014, 04:43 AM
chmcke01's Avatar
Quoted: 12 Post(s)
Zoom
Originally Posted by buzz fretwear View Post
Hello all,
The 90" is with the zoom in the middle and the 102" is with the maximum zoom. At 8'6" with no zoom would yield a 78" screen, zoomed all the way would yield a 102" screen (this zoom does not degrade quality, at least not to my eyes). So using zoom you can do anything in that range.
chmcke01 is offline
post #10132 of 10136 Old 10-18-2014, 02:20 PM
voodoo2crue's Avatar
Hello all,
Welcome to the obsession Buzz
What chmcke01 says is absolutely correct but for me having a little wiggle room is always good thing. If I was going for a 101 inch screen and you have room to install the PJ about a foot further back (around 9'-6") that would put you right in the middle of the range.
voodoo2crue is offline
post #10133 of 10136 Old 10-18-2014, 04:47 PM
rahulp001's Avatar
Quoted: 30 Post(s)
Hi guys,
trying to mount my w1070 and had a question.
I have a basement window close to the ceiling because of which I would end up having to project under the window.
the window is 20in high, however my mount gives me like 7inches fall.
I would have to tilt the projector downwards to move the image down and then probably adjust the keystone.
My question is, would that cause any difference in the quality of the image?
would appreciate any help.
rahulp001 is offline
post #10134 of 10136 Old 10-18-2014, 09:40 PM
chmcke01's Avatar
Quoted: 12 Post(s)
Yes
Originally Posted by rahulp001 View Post
Hi guys,
Yes, using the keystone will deteriorate image quality. How much depends on how far you tilt it and whether or not it is acceptable is up to you. However, in my opinion tilting downward enough to clear the last 13 inches of the window would cause the quality to drop more than I would be able to handle.
If I was in your place I would look into buying or making an extension pole to allow you to lower the projector further...if that isn't possible I would just buy a different mount.
chmcke01 is offline
post #10135 of 10136 Old Yesterday, 03:21 AM
rahulp001's Avatar
Quoted: 30 Post(s)
Thanks chmcke01 for the response.
The mount does come with the extension however, the extension brings the projector down quite a bit and it would come down to my head level if I stand.
I guess I can see if I can cut the extension pole enough to avoid tilting,..
post #10136 of 10136 Old Yesterday, 06:52 AM
dolphinc's Avatar
I used a peerless mount that has an adjustable extension every few inches. I used it with my setup so I could lower the screen down some while not having to use keystone. I have 8' ceilings and a 106" Da-Lite screen, projector is about 11' from the screen. Works out quite nice. I had adjusted it several times before I got it right. I stand 6'2 and its about 6 inches above my head so I'm not bumping into anything.
ID:	319482   Click image for larger version
ID:	319490   Click image for larger version
dolphinc is offline
Benq W1070 1080p 3d Projector
Gear in this thread - W1070 by PriceGrabber.com
