BenQ W1070 : DLP Full HD, 3D Ready with lens-shift for 1000$ - Page 339 - AVS Forum
post #10141 of 10167 Old 10-21-2014, 12:19 PM
kreeturez's Avatar
Quoted: 133 Post(s)
Liked: 164
Originally Posted by gamermwm View Post
For those of you who use a PS4 with this projector I have a question: When you have the HDMI setting on Full RGB on the Playstation - what setting does it need to match that on the Benq? Would you have to set your Benq to "PC" on the HDMI level setting?
Does the "Auto" black level setting make the effective black level actually be set at "Low" or "Limited" therefore crushing blacks unless you put the PS4 on Limited RGB to match (instead of Full/Auto)?
Yup, you'd choose 'PC' to match the PS if you enable that setting on the PS.
Auto seems to default to limited.
Setting the HDMI Mode on the projector to 'PC' refers to full range (0-255).
Setting the HDMI Mode on the projector to 'Video' refers to limited-range (16-235). Usually this is the mode that Auto defaults to.
Getting it mismatched causes even the standard PS menu (at least on the PS3) to appear either washed out or too dim.
BenQ W1070 Projector; Xtreamer Ultra 2 (running XBMC on OpenELEC) via Sony STR-DH540 AVR with Boston Acoustics SoundWare XS SE 5.1 Audio. MediaBrowser3 for Mobile Streaming.
Helpful post? Click the 'Like' button!
kreeturez is offline
post #10142 of 10167 Old 10-21-2014, 12:22 PM
kreeturez's Avatar
Quoted: 133 Post(s)
Liked: 164
Originally Posted by RLBURNSIDE View Post
Smart Eco is worth it, both for black levels and for bulb life.
Replacement bulbs can be bought for 80 bucks online and I'm at 4000 hours so far after two years of using it as my primary display on my PC, and trust me Smart Eco is light years better than both Eco and Normal. It's a performance feature, since when the signal is dimmer it dims the brightness automatically to suit it.
Kinda like a dynamic iris without the audible noise
Agreed: as long as the occasional dimming is unnoticeable (or noticeable but not irritating), it's a good mode to be in: full brightness coupled with long lamp life. Win.
post #10143 of 10167 Old 10-21-2014, 05:19 PM
gamermwm's Avatar
Quoted: 22 Post(s)
Liked: 65
Thanks a bunch. I've got the Benq set to Auto (Low) now and the PS4 to Limited to match. I tried it the other way but didn't like having to turn the proj back from PC mode when I wanted to use another device such as the Wii U which only outputs at Limited.
I hear this setting does not affect bluray playback as it is not using RGB range
What is the meaning of life?
www.iamsecond.com/films
gamermwm is offline
post #10144 of 10167 Old 10-21-2014, 06:30 PM
chmcke01's Avatar
Quoted: 13 Post(s)
Link?
As to the other comment about Smart Eco not working, that person has a busted projector or something. It works, and it's one of the best features of this projector.
Don't use Eco, it sucks. Watch the heck out of the projector. Bulbs are cheap. Enjoy!
Care to post a link to the $80 replacement bulb?
chmcke01 is offline
post #10145 of 10167 Old 10-22-2014, 10:28 PM
rolling01's Avatar
http://www.aliexpress.com/item/Origi...l_target_url=y
Daniel Chaves likes this.
rolling01 is offline
post #10146 of 10167 Old 10-22-2014, 10:33 PM
rolling01's Avatar
Some bulb discussion here.
Bare Bulb replacemnet for Benq W1070
post #10147 of 10167 Old 10-23-2014, 09:25 AM
Crestwood1001's Avatar
Quoted: 26 Post(s)
Question for everyone, after doing all the math with my room and wall, I am going with a 100" inch screen (THX recommended size is 89" so it will be plenty large from my seating position at 11.5 feet back). Currently I have the screen masked out at 1 foot from the ceiling and it looks just about perfect, if not just a hair high. I am wondering what level the bottom of the screen should hold relative to the seating position? Right now the screen to floor is at 3'2" which when sitting back in the seating is almost level with your eyes if not a hair lower... should i drop the screen down a little bit more, say 6 inches so that it is 2'8" from the floor and a few inches lower then eye level from seating? Reason I hold off on doing this is my ceiling height is 8.25 feet and the projector, with the top of the screen 1 foot from the ceiling is showing at 9 inches off the ceiling via the benq calculator.
Name:	Projector measurments.png
Crestwood1001 is online now
post #10148 of 10167 Old 10-23-2014, 10:36 AM
Liked: 0
I have a problem with a square picture out my BenQ 1070w. The test pattern shows the grid sloping up at the bottom and top, I hope the picture does my question justice... I've changed every setting on the menu and projector body and the slant/slope hasn't gone away;is this a problem with the lens?
Thanks in advance
Jeff Scheider is offline
post #10149 of 10167 Old 10-23-2014, 11:15 AM
Quoted: 26 Post(s)
Looks like key-stoning? Do you have any keystone enabled in the menu?
imbloodyskint likes this.
post #10150 of 10167 Old 10-23-2014, 11:27 AM
voodoo2crue's Avatar
http://www.thx.com/consumer/home-ent...r/hdtv-set-up/
voodoo2crue is offline
post #10151 of 10167 Old 10-23-2014, 07:26 PM
niccolo's Avatar
Quoted: 122 Post(s)
Liked: 38
Eco sucks? My impression was many users in light controlled rooms were using Eco, precisely because this projector is a light cannon and no, brighter is not always better. Are you suggesting Smart Eco somehow has better black levels than Eco (how?) or just that you like the brightness in brighter scenes?
Benq W1070 projector w/ Chief RSM mount with custom interface bracket
119" Da-Lite Cinema Contour with High-Contrast (gray) Da-Mat screen
Denon X2000 receiver fed by Panasonic DMP-BDT210 Bluray player
Focal Chorus 700-series towers and center, JMLab Tantal 500-series bookshelf rears
Rythmik FV15HP sub
niccolo is offline
post #10152 of 10167 Old 10-23-2014, 09:48 PM
RLBURNSIDE's Avatar
Quoted: 90 Post(s)
Liked: 155
All I know is that Eco and Normal both lose out on the dynamic "iris"-like behavior that greatly increases the apparent contrast of the projector. In dark rooms you can always lower brightness or raise gamma, or install an ND2/4 filter for 5 dollars and get the best of both worlds, lower overall brightness as well as a greater luminance range that enhances (temporal) contrast.
RLBURNSIDE is offline
post #10153 of 10167 Old 10-23-2014, 09:51 PM
RLBURNSIDE's Avatar
Quoted: 90 Post(s)
Liked: 155
Thanks in advance
I used a laser pointer, a level, and my girlfriend's help to get my projector aligned properly. It's much easier to do it when one person moves the projector around and the other can stand really close to the grid to see if the lines are flat / vertical and at 90 degrees at the corners.
post #10154 of 10167 Old Yesterday, 06:57 AM
AV_Integrated's Avatar
Quoted: 245 Post(s)
Liked: 336
Thanks in advance
Your projector is not square to the wall.
It definitely needs to be pointed down some, and it looks like it needs to be spun a bit to the right.
You need to adjust how the projector is pointed at the wall until the left and right sides are the same length, and the top and bottom are the same length.
AV Integrated - Theater, whole house audio, and technology installation in the Washington DC metro area.
AV_Integrated is offline
post #10155 of 10167 Old Yesterday, 07:03 AM
grubadub's Avatar
yeah, you can do those things if smart eco is too bright. my problem with smart eco is the fan noise. eco looks pretty good so that's what i've been using.
question: what levels are you guys using for the noise reduction and sharpness settings? i've noticed (especially watching football) there's quite a bit of noise around fast moving objects.
grubadub is offline
post #10156 of 10167 Old Yesterday, 08:24 AM
fredxr2d2's Avatar
Quoted: 22 Post(s)
Liked: 29
Noise Reduction and Sharpness set to 0 actually produces the best picture, IMO. Before, with either setting at higher than 0, I saw artifacts in fast motion that I didn't see when reducing both settings.
Tim S.
Former 35mm and Digital Projectionist @ Regal Cinemas
Currently watching on: BenQ W1070, 82" 1.0 Gain Screen, PS3, with Yamaha RX-V473, SVS PB-1000, a Def Tech CS-8040HD, and 4 Def Tech ProMonitor 800s.
fredxr2d2 is online now
post #10157 of 10167 Old Yesterday, 09:15 AM
grubadub's Avatar
thanks for the reply. i will play around with it this weekend. plenty of games on to test it out
grubadub is offline
post #10158 of 10167 Old Yesterday, 09:50 AM
I use the settings linked here, looks great to me
https://www.avforums.com/threads/ben...tings.1761516/
post #10159 of 10167 Old Yesterday, 11:54 AM
imbloodyskint's Avatar
I have mine set low so as my eyes are 35% up from the bottom of the screen and find that much better.
Basically, if your screen was say, 6ft x 8ft, then your eye level when seated should be 2ft above the bottom of the screen/image, which equates to a 1/3rd up/into the screen/image.
imbloodyskint is online now
post #10160 of 10167 Old Yesterday, 12:21 PM
Quoted: 26 Post(s)
I'll have to mask that off and see how I like it, with my equipment setup I may not be able to go that low it'll be almost on the floor but can you post a pic? I'd love to see how you have it set up.
post #10161 of 10167 Old Yesterday, 12:31 PM
bluer101's Avatar
Quoted: 72 Post(s)
Liked: 80
The bottom of my screen is about 28-30 inches from the floor.
bluer101 is offline
post #10162 of 10167 Old Yesterday, 12:35 PM
mine is 29-1/2" off of the floor
post #10163 of 10167 Old Yesterday, 01:12 PM
cubs_2b23's Avatar
bluer101 and voodoo2crue, how big are your screens?
cubs_2b23 is online now
post #10164 of 10167 Old Yesterday, 01:18 PM
110" 16:9 format
post #10165 of 10167 Old Yesterday, 01:28 PM
grubadub's Avatar
practically, you want to mount your screen just high enough so that your feet don't interfere with the viewing area when your reclined. depends on your setup. sometimes things like speakers prevent you from mounting as low as you might want to. not really a big deal though.
grubadub is offline
post #10166 of 10167 Old Yesterday, 03:24 PM
Quoted: 26 Post(s)
Awesome thanks guys, im gonna take it down another 6" and call it done.
post #10167 of 10167 Old Yesterday, 08:56 PM
AllenA07's Avatar
Quoted: 61 Post(s)
Liked: 67
I've got mine on eco. I found smart eco to be too bright. Finally got everything dialed in tonight, I'm very impressed with this projector. Considering what it costs it really is a special deal.
AVR: Denon 2112
Speakers: EMP Tek e55ti, Center- EMP Tek e56ci, Side Surrounds- EMP Tek e55wi, Rear Surrounds- KLH 911b, Sub- SVS PC12 Plus
Display: BenQ w1070 on a 92in fixed screen
Blu-Ray Player:Samsung BD-EM59C;
Playstation 4, Apple TV, Harmony Remote
AllenA07 is online now
Benq W1070 1080p 3d Projector
Gear in this thread - W1070 by PriceGrabber.com
