BenQ W1070 : DLP Full HD, 3D Ready with lens-shift for 1000$ - Page 340 - AVS Forum | Home Theater Discussions And Reviews
 403Likes
post #10171 of 11995 Old 10-27-2014, 08:21 AM
sat-tv's Avatar
Quoted: 31 Post(s)
Question about the Height mount of the Benq w1070. Does it matter How high the projector is mounted.
At this spot I am looking at 125 screen mounting projector 20 inch from the ceiling.
http://www.projectorcentral.com/BenQ...ulator-pro.htm
sat-tv is offline
post #10172 of 11995 Old 10-27-2014, 08:29 AM
AV_Integrated's Avatar
Quoted: 1095 Post(s)
Liked: 794
The center of the lens MUST be 2" to 6" above the top of your screen. So, if the center of the lens is 20" from your ceiling, the top of the screen must be 22" to 26" from the top of the ceiling.
AV Integrated - Theater, whole house audio, and technology installation in the Washington DC metro area.
AV_Integrated is offline
post #10173 of 11995 Old 10-27-2014, 09:06 AM
sat-tv's Avatar
Quoted: 31 Post(s)
Thank you AV_integrated. This dam ceiling fan has thrown a twist on what I am trying to do..
dam fan
sat-tv is offline
post #10174 of 11995 Old 10-27-2014, 09:22 AM
dreamer's Avatar
Quoted: 990 Post(s)
Liked: 285
dam fan
It seems very strange that 75% of people asking about projector placement in the last month have a ceiling fan in the room to work around. Very odd.
Most homes only have one room with a ceiling fan that isn't a kitchen or bedroom, if they have any at all, so what are the chances that the same room people want to put a projector in happens to be the one with a fan ?
Kirk Ellis
BenQ W1070 VuTec 122" Screen
Harmon Kardon AVR 247 Parasound L&R Amp
Psycoustic Mark III L&R Towers, Boston Center
Energy Take 5 Surrounds, HSU Research Sub
dreamer is online now
post #10175 of 11995 Old 10-27-2014, 09:33 AM
fredxr2d2's Avatar
Quoted: 209 Post(s)
Liked: 118
Every single room (except bathrooms) in my house has a ceiling fan. Luckily the BenQ fit in front of it in the basement family room that I use as a "theater."
Tim S.
Former 35mm and Digital Projectionist @ Regal Cinemas
Currently watching on: BenQ W1070, 106" 0.8 Gain Screen, Darbee, PS4, w/ Marantz SR6011, NAD C370 (for Front L/R), Outlaw Model 5000, SVS PB-2000, SVS PC-2000, a Def Tech CS-8080HD, 2 SM65 for L/R, 2 SM55 for sides, 2 PM1000 for rears, and 4 AW5500 for Atmos.
fredxr2d2 is offline
post #10176 of 11995 Old 10-27-2014, 09:38 AM
Liked: 794
dam fan
Yes, ceiling fans are all evil and should be sot.
The Epson 3000 has more lens shift and can be placed below the top of your screen (anywhere between the top and bottom actually) and will do what you need. It doesn't look as good as the W1070, but is close in price and does what you need.
Or, take the fan down.
post #10177 of 11995 Old 10-27-2014, 10:04 AM
bluer101's Avatar
Quoted: 374 Post(s)
Liked: 293
I have fans in every room and outside pool patio, it's Florida.
Projector & Screen: Epson 5040ub Elite Screens 100" Electric Video: Oppo 103d Audio: Denon 4520ci Speakers: Infinity RS5 (LW L C R RW) Infinity RS1 (LH RH) Infinity Beta ES250 (SL SR) Subwoofers: 2 SI18d4 Martycubes with iNuke3000dsp and 2 Infinity BU120 Shakers: 4 ADX shakers with Dayton SA230 amp
My Builds--Media console build----Martycube build----ADX Bass Shaker Install
bluer101 is offline
post #10178 of 11995 Old 10-27-2014, 10:09 AM
voodoo2crue's Avatar
Yep, Gulf South=ceiling fans, I also have them in all rooms and outside.
voodoo2crue is offline
post #10179 of 11995 Old 10-27-2014, 10:30 AM
Crestwood1001's Avatar
Quoted: 60 Post(s)
Liked: 39
I have ceiling fans in almost all rooms, and the one in the theater happens to be centered and 8'6" back from the screen wall which is exactly where the projector needs to be.... damn fans
Crestwood1001 is offline
post #10180 of 11995 Old 10-27-2014, 10:34 AM
Solution. Goodbye ceiling fan, hello PJ!
AV_Integrated and gamermwm like this.
post #10181 of 11995 Old 10-27-2014, 11:25 AM
Liked: 794
Then get the 1080ST. It looks darn near identical. You really need to use a fixed frame screen with it, but it's a great solution when you need the projector a bit closer.
voodoo2crue likes this.
post #10182 of 11995 Old 10-27-2014, 12:39 PM
sat-tv's Avatar
Quoted: 31 Post(s)
Thanks again but that puts it at around under 6 feet.
Yeah I live in Florida and have a fan in almost everyroom 10 fans
sat-tv is offline
post #10183 of 11995 Old 10-27-2014, 12:54 PM
Bill97Z's Avatar
Quoted: 79 Post(s)
How close can the projector be mounted to the ceiling? My screen will be 6" from the ceiling so the center of lens must be 4" from ceiling? Can I mount it that high, it will be almost touching?
Bill97Z is offline
post #10184 of 11995 Old 10-27-2014, 01:30 PM
sat-tv's Avatar
Quoted: 31 Post(s)
18 inches
sat-tv is offline
post #10185 of 11995 Old 10-27-2014, 03:32 PM
wasure's Avatar
hey kreeturez
thanks a lot for the advice.
i opened it and lifted the plastic sheet and the clip seems to be in place correctly, though I haven't seen any photos of what it should look like. unfortunately i can't turn it on with the lid removed so i can't tell what exactly is vibrating.
it still makes the noise after re-sealing it all. but it does seem to be that pushing in the area that the plastic sheet covers quiets it, at least while my thumb presses rather hard on it. it could be the clip, the plastic, or just that the fan gets fixed by deforming the body...
wasure is offline
post #10186 of 11995 Old 10-27-2014, 04:18 PM
dolphinc's Avatar
Quoted: 92 Post(s)
Liked: 67
I also live in Florida and have fans in every room, outside and 2 in my SUV
I just removed it from the theater room, so much eaiser than trying to get around it.
dolphinc is offline
post #10187 of 11995 Old 10-27-2014, 05:37 PM
Bill97Z's Avatar
Quoted: 79 Post(s)
18 inches
Seriously? People have that much space on the top of their screen? They must have 10' ceilings.
Bill97Z is offline
post #10188 of 11995 Old 10-27-2014, 06:34 PM
robl45's Avatar
Quoted: 184 Post(s)
Quick question, if I ceiling mount this, can it shoot Strait with no offset? My mounting position needs it straight, I don't really have many inches to go down.
robl45 is offline
post #10189 of 11995 Old 10-27-2014, 08:49 PM
madcutter's Avatar
So my projector unexepectedly shut down tonight. No warning, the screen went black, the red lamp light went on. It was really hot in my apartment (had the gas fireplace on for too long previously) so I expected overheating. I waited an hour, then turned it back on with no problem! If it was an overheating issue, why didn't the temperature light turn on instead on the lamp light?
madcutter is offline
post #10190 of 11995 Old 10-27-2014, 11:13 PM
kreeturez's Avatar
Quoted: 494 Post(s)
Liked: 383
It doesn't, unfortunately: you'll need a few extra inches above the screen regardless of lens shift...
Because lamp life is what you'll shorten with frequent overheats?
If you check around these forums you'll see that this is the light that does tend to go on in a room that's too hot or when ventilation is very poor around the pj. No idea why. But provided you power on OK after cooling down, it's not actually the lamp.
In seriousness though, you'll want to avoid running any projector in a situation where you're "expecting overheating" since it will most certainly shorten both projector and lamp life: which would be a waste with a lamp rated for such long life.
BenQ HT2050 Projector; Kodi (on Ubuntu, OpenELEC & S802) via Sony STR-DH540 AVR with Boston Acoustics SoundWare XS SE 5.1 Audio + Jamo 210 Sub. Emby for Mobile Streaming.
Helpful post? Click the 'Like' button!
kreeturez is offline
post #10191 of 11995 Old 10-28-2014, 12:50 AM
Quoted: 60 Post(s)
Liked: 39
Benefit of having a father that is a relator is having access to a fantastic electrician that does work for me on the CHEAP, had it moved back a few feet and he placed an outlet right where I needed!
post #10192 of 11995 Old 10-28-2014, 12:52 AM
Quoted: 60 Post(s)
Liked: 39
Well its done, late last week I ordered an elite screens 100" fixed frame, had planned on waiting a few weeks to order the projector but I just bit the bullet and ordered the PJ, a peerless mount, associated redmere cables, a set of the Estar glasses and Avatar 3d, cant think of a better way to experience 3d in my home for the first time then 100" of Avatar! Everything will be here Wednesday cant wait!
post #10193 of 11995 Old 10-28-2014, 01:46 AM
dreamer's Avatar
Quoted: 990 Post(s)
Liked: 285
It can't shoot "straight" but you can cheat. All that really matters is that the angle between the screen and the projector light path be correct so you aren't forced to correct trapezoid keystoning.
If you can't place the white area of the screen at least 2.5 inches below the lens, you can angle the projector UP and tilt the screen OUT at the top edge to preserve the angles and prevent keystoning. Of course, this only works with fixed frame screens, not retractable. But with a fixed frame screen, the tilt shouldn't put the top edge of the screen more than 2" away from the wall. This has the benefit of tilting the screen down toward the viewers so they don't have to crane their necks. Especially useful for screens high on the wall like over fireplaces.
Kirk Ellis
post #10194 of 11995 Old 10-28-2014, 03:41 AM
robl45's Avatar
Quoted: 184 Post(s)
Okay, so two people have said this now, so even with the lens shift, there is still an offset? I looked up the manual and the picture shows it shooting straight. Would a very small amount of keystone really affect things too much?
What I have is a wall with two rectangle cutouts Top of the rectangle is 103 inchs. I am going to mount the projector to the top of one of those. Even with the lowest profile mount, I'm going to lose 3 inches or so and then another 3 inches with the offset. It is going to go on a fixed frame screen as wife has nixed the retractable one we already have but I doubt she will go for it tilting out on the wall.
robl45 is offline
post #10195 of 11995 Old 10-28-2014, 07:11 AM
niggenz's Avatar
Originally Posted by grubadub View Post
black levels/shadow details: this is one area where the Sharp is much better than the Benq. neither one has inky blacks but whereas the Sharp handles shadow detail very well the Benq simply crushes the blacks and anything close to it.
What's your verdict regarding the W1070's black levels/shadow details now that you have some hours on the bulb? Blacks and shadows still crushed? Just curious to hear from an experience FP owner of the W1070.
niggenz is offline
post #10196 of 11995 Old 10-28-2014, 07:27 AM
Liked: 794
You need to come up with a mount that works well which can be that tight to the ceiling. The reality is that there are no true 'flush' projector mounts on the market. They don't exist. So, any mount you get will push the projector several inches away from the ceiling.
But, Premier makes a mount (about $70) which may work well. Read the reviews here which speak specifically to the W1070:
http://www.amazon.com/Premier-Mounts...ustomerReviews
It indicates that the center of the lens can be under 4" from the ceiling, and they were able to use lens shift to keep the image within about an inch of the center of the lens, so the top of the image was less than 5" from the ceiling.
Sounds like an ideal solution for you.
Not sure why someone said 18" - that's not correct at all.
post #10197 of 11995 Old 10-28-2014, 07:32 AM
Liked: 794
Well, that's not correct. It doesn't lower the screen, it just presents the screen more squared to the viewers when seated. Not a bad thing or a good thing really, but if the screen is high in the room, then people are still looking up just as much as they ever were.
post #10198 of 11995 Old 10-28-2014, 07:58 AM
Bill97Z's Avatar
Quoted: 79 Post(s)
What cables are you running directly into the projector? Just an HDMI?
Bill97Z is offline
post #10199 of 11995 Old 10-28-2014, 08:21 AM
grubadub's Avatar
Quoted: 97 Post(s)
Liked: 100
well after finding out that the HDMI setting should be on "PC" instead of auto fixed that issue. i no longer get the crushing of blacks and whites. now i get decent shadow detail. the blacks aren't great and the contrast isn't great which causes the image to be a little flat. but it's sharp and bright with decent colors. one thing i've noticed compared to my previous projector is how source dependent this projector is. blu rays look great of course but watching tv (i have Dish network) is a crapshoot. last night's game on espn looked really good...better than any college game this past saturday. the Sharp i had before seemed to do a better job with inferior signals.
it's taking some getting used to. i don't know how many times i've thought about returning the Benq and getting the Sony hw40. but it's just not in the budget right now.
p.s. regarding the sharpness and noise reduction settings, i tried setting both of them to zero but it just looks to soft to me. for now i've settled on 10 for sharpness and 4 for noise reduction.
grubadub is offline
post #10200 of 11995 Old 10-28-2014, 08:36 AM
niggenz's Avatar
Cool. Thanks for the assessment. It gets worse once you start throwing rips downloaded from the Net in it. All that lossy compression really starts to show up at 1080p when you have such a big screen. I am almost forced to exclusively watch OTA HDTV or Blu-Ray content on my projector. I'll roll up the electric screen so I can watch anything else on the 55" LED.
niggenz is offline
Benq W1070 1080p 3d Projector
