BenQ W1070 : DLP Full HD, 3D Ready with lens-shift for 1000$ - Page 348 - AVS Forum
post #10411 of 10426 Old Yesterday, 10:14 AM
kreeturez's Avatar
Quoted: 153 Post(s)
Liked: 177
Originally Posted by Ftoast View Post
The w1070 also has a powered USB.
It doesn't... The USB service port is 'slave' (rather than host) and thus doesn't provide power.
That said, if you're already running power to the projector from an outlet, powering a device plugged into it shouldn't be much hassle.
Ftoast likes this.
BenQ W1070 Projector; Xtreamer Ultra 2 (running XBMC on OpenELEC) via Sony STR-DH540 AVR with Boston Acoustics SoundWare XS SE 5.1 Audio. MediaBrowser3 for Mobile Streaming.
Helpful post? Click the 'Like' button!
kreeturez is offline
post #10412 of 10426 Old Yesterday, 10:34 AM
robl45's Avatar
Quoted: 26 Post(s)
When you have to run it through walls, its more of a hassle. Honestly, for the 100 dollar difference between these things, its not worth it to me to have to have a separate power source wired.
robl45 is offline
post #10413 of 10426 Old Yesterday, 10:49 AM
kreeturez's Avatar
Quoted: 153 Post(s)
Liked: 177
If I were buying now, I might just get the 1075 as well. But if laying wiring, ideally you want a plug point near the projector for future-proofing. Alternatively it's easy to run a plug-point extension to the mount and power the projector off that using a short power cord (the projector power cable is the same thickness as a regular extension cable; so this is no less convenient to do).
This way you're covered no matter what needs to be powered there in future (not all Wireless-HDMI solutions can run off powered USB, for instance).
post #10414 of 10426 Old Yesterday, 10:51 AM
chmcke01's Avatar
My setup
Finally got my projector setup ceiling mounted and just projecting straight onto a light tan wall. Looks pretty good to me. This is taken a little from the side so that is why it looks skewed. I will post pics with the lights on later tonight if I remember.
Name:	2014-11-24 22.47.48.jpg
chmcke01 is offline
post #10415 of 10426 Old Yesterday, 11:34 AM
fredfish's Avatar
Originally Posted by chmcke01 View Post
I could be wrong, but I don't even believe my power cord was 6'...I think it was more like 5'...
Thanks. 5' would be way too short.
I didn't even think about the power chord until I saw it mentioned in another thread. I may be able to find something at work and if not, there is a local store that carries that sort of stuff cheap.
fredfish is offline
post #10416 of 10426 Old Yesterday, 01:07 PM
Liked: 0
Hi everyone!
I bought a w1070 about a week ago and it functioned just fine the first few days.
All of a sudden, since yesterday, the projector shuts off after 5 minutes. The power light is solid red and the temp light is solid green.
When I attempt to boot up the projector right away, the fans start blowing again and the lamp light starts flashing red for about 2 to 3 minutes, then the projector boots up again automatically.
When I just wait 10 minutes before booting it up again I don't get the red lamp flashing light, it just boots straight up, only to shut down again after 5 minutes.
I've looked at the fans and they seem to be spinning (I could only see 3 fans, im not sure how many there are). I also tried high altitude mode but that doesn't seem to work either. The projector is in a cool room with lots of space to breathe.
Anyone know what this could be? Any help would be greatly appreciated!
yekezei is offline
post #10417 of 10426 Old Yesterday, 01:37 PM
voodoo2crue's Avatar
Originally Posted by yekezei View Post
Hi everyone!
See the link page 52. Was it new? Do you have a warranty,I'd contact the seller and demand to repair or replace.
http://www.projectorcentral.com/pdf/...anual_7265.pdf
voodoo2crue is offline
post #10418 of 10426 Old Yesterday, 02:51 PM
kreeturez's Avatar
Quoted: 153 Post(s)
Liked: 177
Hi everyone!
That light combination definitely indicates a non-working fan. There're 4 fans in total (there's one internally that's not visible - so that one may not be functioning). Alternatively one of the others is spinning but not reaching full speed.
Swap it out - return to sender!
post #10419 of 10426 Old Yesterday, 03:33 PM
AV_Integrated's Avatar
Quoted: 322 Post(s)
Liked: 369
You can't run a power cord behind your walls. It's a fire hazard and not to electrical code. You can run power extensions using Romex which are to code, or have a proper outlet installed, or surface run power. But, if you are looking at running power behind walls, then do yourself a favor and run a HDMI cable (or two) as well as a couple of cat-5e/6 cables. At the end of the day, properly wiring your projector up makes a ton of sense to do right the first time.
Once you have a power outlet near your projector, you can power anything you want to.
AV Integrated - Theater, whole house audio, and technology installation in the Washington DC metro area.
AV_Integrated is offline
post #10420 of 10426 Old Yesterday, 07:32 PM
fredfish's Avatar
Originally Posted by AV_Integrated View Post
You can't run a power cord behind your walls...
I can't run anything behind my walls. It's an apartment
I'll need to run a surface raceway down to an existing outlet (about 7') to hide the cable as best as I can.
That leads me to another question. Can I run the power and HDMI cables next to each other for that run down the wall, or do I need some physical separation between the two to avoid signal interference?
fredfish is offline
post #10421 of 10426 Old Yesterday, 07:36 PM
tigerfan33's Avatar
Quoted: 46 Post(s)
Liked: 27
Just got this for the bedroom.
I have Sony hw50es for main projector using HP screen.
1070 is setup using 1.3 gain screen. Very bright OTB.
Using Cinema, warm, gamma 2.2.
I'm impressed thus far.
Slight brightness uniformity issue but that's due to my short throw. No biggie.
Can't compare (not suppose to) the Sony in blacks. Motion maybe a little better on Sony too.
I paid $515 for the 1070 used on Amazon. This will be used primarily for hdtv and Roku. Very pleasantly surprised how good the pic.
My firmware is 108. Is this current.
tigerfan33 is offline
post #10422 of 10426 Old Yesterday, 09:24 PM
macshome's Avatar
I got mine earlier this year and have been very happy with it.
1.08 is the current FW.
macshome is offline
post #10423 of 10426 Old Yesterday, 09:30 PM
macshome's Avatar
When I ran my power (code spec wire and installed an outlet) and lines (HDMI, Composite, Trigger) for my ceiling mount 1070 I also left a string in there that follows the run. That way if I ever need to pull something else I can just tie it to the string, pull the new run, and not need to mess about with my glow rod in a dark ceiling space.
macshome is offline
post #10424 of 10426 Old Yesterday, 09:53 PM
Quoted: 322 Post(s)
Liked: 369
HDMI, as a all digital signal, tends to not have any issues with electrical interference the way analog cabling used to. I would run hard power and HDMI side by side. Look into the Redmere slim cables to cover the distance and give you reliable thin cables to keep things tidy.
If surface running cabling, you can always just get an extension cord the right color, and perhaps a bit lower weight, for your application instead of looking for a long power cable.
post #10425 of 10426 Old Yesterday, 09:56 PM
Liked: 0
Has anyone seen a direct comparison with the W1080ST. I'm thinking that is what I'll get to allow for stand up (wii, Kinect) gaming in the room without always shadowing the screen.
Anthony Sparrow is online now
post #10426 of 10426 Old Yesterday, 11:58 PM
dreamer's Avatar
Quoted: 182 Post(s)
Liked: 51
W1070 cih 2.40:1
So ... tonight I dug out the wedge prisms I bought 7 years ago from a group in France that had a limited run made. I bought them, but then never did anything with them because I had no good way to do vertical scaling with my JVC RS1 projector.
Of course, the W1070 "Letterbox" mode of "Aspect" ratio control does the vertical stretch needed to use an anamorphic lens. I could have sworn someone said the short throw of the W1070 and its recessed lens would make use of an anamorphic lens unworkable. I am happy to report THIS IS NOT TRUE. It may not work with the "trophy" prisms because the size and shape of those is different, but these French prisms work fine with the W1070.
I simply placed the prisms at angles in front of the lens and it worked like a charm. It took me all of 2 minutes to find the correct angles. Of course, it all needs to be setup inside a black velvet lined box to contain the reflections, but that should be a piece of cake. And of course a sled to move it away when watching 16:9 content. But simpler than the moveable mount I was planning on needing to use the "zoom method" for constant image height on 2.40:1 screen.
I was concerned about the chromatic aberrations of a simple two prism A-lens, and they are pretty bad on the test pattern, but unobjectionable when watching a movie. There is about an inch of bow across the top (what would be the bottom when ceiling mounted), so I can see why people go for a curved screen to counter this.
Here is a shot of the prisms setup in front of the projector and some shots from X-Men Days of Future Past using the full 1080 pixel height of the W1070.
ID:	385857   Click image for larger version
ID:	385865   Click image for larger version
ID:	385873   Click image for larger version
ID:	385881   Click image for larger version
Kirk Ellis
JVC DLA-RS1 VuTec 122" Screen
Harmon Kardon AVR 247 Parasound L&R Amp
Psycoustic Mark III L&R Towers, Boston Center
Energy Take 5 Surrounds, HSU Research Sub
dreamer is online now
Benq W1070 1080p 3d Projector
