BenQ W1070 : DLP Full HD, 3D Ready with lens-shift for 1000$ - Page 361 - AVS Forum | Home Theater Discussions And Reviews
 396Likes
post #10801 of 11976 Old 01-17-2015, 07:43 AM
bigcat's Avatar
Quoted: 94 Post(s)
Liked: 26
Still trying to square my projector using the test pattern. The top line length now matches the bottom line length and left and right match too, which is all great. However, the bottom left corner starts about an inch towards the right, so it's not aligned with the top left corner. I attached a pic of what I mean, exaggerating a bit just to illustrate what I am seeing.
BenQ W1070/Silver Ticket 120"/Denon X4200W/Infinity Primus | Vizio 80" 3D LED M801D-A3 w/ Denon X3200W/Infinity Primus | Sony Bravia XBR-60LX900 w/ Sony HTCT550W 3D Sound Bar | Sony SXRD KDS-R70XBR2 w/ Onkyo HT-S770 | Sony PS3 (Slim) | DIRECTV Genie HR44-500, C41s | Harmony 700
bigcat is offline
post #10802 of 11976 Old 01-17-2015, 08:10 AM
kreeturez's Avatar
Quoted: 477 Post(s)
Liked: 364
@sodvepas : That reminds me - you've probably already checked, but perhaps double-check that you're properly in focus on the projector (and that the projector is perfectly square to the screen) since CA can occur if you're out of focus in a portion of the image as well.
sodvepas likes this.
BenQ HT2050 Projector; Kodi (on Ubuntu, OpenELEC & S802) via Sony STR-DH540 AVR with Boston Acoustics SoundWare XS SE 5.1 Audio + Jamo 210 Sub. Emby for Mobile Streaming.
Helpful post? Click the 'Like' button!
kreeturez is offline
post #10803 of 11976 Old 01-17-2015, 09:53 AM
bluer101's Avatar
Quoted: 353 Post(s)
Liked: 285
It sounds like you need to yaw the pj to the right or in other terms tilt. It's not level so it's pitched. Try taking a photo for us.
bigcat likes this.
Projector & Screen: Epson 5040ub Elite Screens 100" Electric Video: Oppo 103d Audio: Denon 4520ci Speakers: Infinity RS5 (LW L C R RW) Infinity RS1 (LH RH) Infinity Beta ES250 (SL SR) Subwoofers: 2 SI18d4 Martycubes with iNuke3000dsp and 2 Infinity BU120 Shakers: 4 ADX shakers with Dayton SA230 amp
My Builds--Media console build----Martycube build----ADX Bass Shaker Install
bluer101 is offline
post #10804 of 11976 Old 01-17-2015, 02:57 PM
AaronPSU79's Avatar
Originally Posted by Greg121986 View Post
At 11 Feet throw distance, though, It seems the W1070 will output a huge screen, somewhere around 130". Can I use the zoom to bring this down to 106" or less? This is about the largest screen size I think I can fit between my speakers.
According to BenQ's projector calculator here: http://www.benq.com/microsite/projec...tiocalculator/ at an 11' throw distance your screen size can range from 101"-130" so you should be good at 106".
It's important to make sure your projector is centered horizontally to the screen since it does not have horizontal keystone adjustment. Other than that your setup looks good. I sit about 11' from my screen and I have it at about 120" which I think is great, but I wouldn't want to go any bigger.
Tommy Mang likes this.
AaronPSU79 is offline
post #10805 of 11976 Old 01-18-2015, 06:50 AM
bigcat's Avatar
Quoted: 94 Post(s)
Liked: 26
Thanks bluer101. I attached a photo. Hopefully, that helps. I will try your recommendation though.
bigcat is offline
post #10806 of 11976 Old 01-18-2015, 07:58 AM
bluer101's Avatar
Quoted: 353 Post(s)
Liked: 285
Yes, your pj needs to be tilted, rolled to the right. So the right side of the pj will come down and left side up, but that's over exagerated. Then you might have to lens shift the picture down with the screw or move the whole pj down to compensate.
What mount did you end up going with.
bigcat likes this.
bluer101 is offline
post #10807 of 11976 Old 01-18-2015, 09:48 AM
bigcat's Avatar
Quoted: 94 Post(s)
Liked: 26
Much better after some adjustments. See attached photo. I don't think it's perfect but I can probably live with it. You were right I had to use lens shift in addition to the tilt. I used this mount. Thanks a lot for the help.
bigcat is offline
post #10808 of 11976 Old 01-18-2015, 10:24 AM
bluer101's Avatar
Quoted: 353 Post(s)
Liked: 285
You over tilted just a hair too much but pretty close. Now you can make the picture just a little bigger with zoom ring and then focus. I have mine so the test pattern is just over the black screen boarder. It is very small this way it fills the screen all the way and very little picture spills into the black, like less than 1/8 of an inch.
That mount looks like a pain in the butt. That's why I was steering you to the peerless mount I have. Yes a few more dollars but the fine adjustment makes it very easy to line up. It has the spider gears and knobs. After I have mine set you just tighten a set screw if you want.
Here is a video.
bluer101 is offline
post #10809 of 11976 Old 01-18-2015, 12:03 PM
bigcat's Avatar
Quoted: 94 Post(s)
Liked: 26
Here is a video.
http://m.youtube.com/watch?v=eskAlVi3xGc
Thanks for the great feedback. Yeah that mount is a pain in the butt, too many moving parts and looks like it would move if you bump into it. Will see how it goes. Amazon didn't have the peerless extension when I ordered so I just got this one. Good point about the test pattern border I was actually going to ask if that could be over the black frame. I will try and make some further adjustments.
bigcat is offline
post #10810 of 11976 Old 01-18-2015, 01:41 PM
Movie78's Avatar
Quoted: 820 Post(s)
Liked: 248
What is the best 3D glasses out there?
Movie78 is offline
post #10811 of 11976 Old 01-19-2015, 01:16 AM
Liked: 1
Thank kreeturez!, yeah I need to double-check everything. Do you have any experience will BenQ change this to a refurbished model, because it would be a bummer since this is really new unit? (october 2014)
@xabih : How is your CA problem being handled?
sodvepas is offline
post #10812 of 11976 Old 01-19-2015, 03:04 AM
xabih's Avatar
I report my problem to Benq via website support, they sent me a courier and they carried the PJ somewhere to repair. I will report when it come back.
Mas vale duda que dogma.
xabih is offline
post #10813 of 11976 Old 01-19-2015, 06:52 AM
kyle85's Avatar
Quoted: 14 Post(s)
Does anyone have any suggestions for a low profile mount for the w1070. Ceilings in the basement are only 6'10" so i am trying to keep it as close to the top of the ceiling as possible.
kyle85 is offline
post #10814 of 11976 Old 01-19-2015, 08:07 AM
bigcat's Avatar
Quoted: 94 Post(s)
Liked: 26
These have been recommended here so I am thinking of getting them when I am ready for 3d
bigcat is offline
post #10815 of 11976 Old 01-19-2015, 08:08 AM
Smith1212's Avatar
Liked: 2
In germany it could be an Vogel EPC 6545:
http://www.vogels.com/epc-6545-proje...E#.VL0r5C61XK9
Smith1212 is offline
post #10816 of 11976 Old 01-19-2015, 08:12 AM
Smith1212's Avatar
Liked: 2
In german forum the G15 DLP Glasses are one of the recommendations like these:
http://www.ebay.de/itm/G15-DLP-Link-...item462f42bc54
post #10817 of 11976 Old 01-19-2015, 08:25 AM
Movie78's Avatar
Quoted: 820 Post(s)
Liked: 248
This is the one that i am actually using,i taught something else better than this one.
OLD SETUP:http://www.avsforum.com/forum/15-gen...r-theater.html
NEW SETUP: http://forum.kodi.tv/showthread.php?...856#pid2506856
LG 75UH8500 3D DOLBY VISION HDR | SONY 43 ANDROID TV HDR
XBOX ONE S UHD BLU-RAY | PS4 PRO 4K HDR GAMING
MARANTZ SR7011 DTS X | ATMOS 5.1.4 | Auro-3D 9.1
Movie78 is offline
post #10818 of 11976 Old 01-19-2015, 09:12 AM
Iron Maiden's Avatar
Quoted: 528 Post(s)
Liked: 202
I went with these and really like them. I only paid $150 though so the price went up a little.
Comes with a bunch of different nose pieces and charging cords. cleaning clothes. Have only tested 3 of the 4 so far but so far they have been great. I thought they were comfortable as did my two sons. (ages 13 and 16)
http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
60" Panasonic Plasma ~ BenQ HT1075 / 92" Screen~Onkyo TX-NR3008(Pre/Pro)
Earthquake Cinenova Grande Amplifier ~ Oppo BDP-103 ~ Xbox One & PS4
Musical Fidelity Tri-Vista Tube DAC ~ Monster Cable Signature Series HTPS7000
Energy Veritas V2.3i (mains)~Veritas V2.4i (Front Wides)~Veritas V2.2i (center)
Energy Veritas V2.1 & CAT Tiburons(Surr)~Subs: 2 FTW-21's~Fp10000q clone/2x4dsp
Iron Maiden is offline
post #10819 of 11976 Old 01-19-2015, 02:44 PM
Cataphract's Avatar
Hi guys,
what is the offset for this projector? I have a 106" fixed screen and 8 feet ceiling. Why does the Projection calculator not show it?
Is it because of the lens shift feature? I thought that was limited to a couple of inches of vertical adjustment and not that useful.
Just placed my order for same day delivery. Guys, please let me know if I need a mount extension, I cannot seem to figure out where the image will start. i.e. how many inches from the ceiling to the top of the screen, the top of my screen is about 15 inches from the ceiling. My mount would be 6 inches, plus add 3 inches to the center of the lens, plus 3 inches offset? This would put me at 12 inches, so would I need a 3 inch extension for the mount? Or will the lens shift take care of it?
I got sold on this PJ after reading all day today on the forum, was worried a bit about ambient light performance due to my light colored walls, and since I don't have a bat cave, but hopefully, this PJ has enough lumens to be able to watch during the day with blinds closed. You don't want to have all lights off when watching football for example. I am sure many people are doing just that, would like to hear more on that front.
Cataphract is offline
post #10820 of 11976 Old 01-20-2015, 09:52 AM
RLBURNSIDE's Avatar
Quoted: 1632 Post(s)
Liked: 1289
You need blackout shades, first off, not just "blinds" to watch a projector during the day.
Next, if you have lights on, it will degrade your contrast, so your best bet is to make the image small enough so that it's bright enough.
Of course, if you have an expensive screen with gain and ambient light absorption, you can get even better results with lights on, but those screens are quite expensive compared to simply turning the lights off.
A better solution is to buy a cheap TV for daytime movie and sports, and watch the projector at night.
RLBURNSIDE is online now
post #10821 of 11976 Old 01-20-2015, 09:52 AM
RLBURNSIDE's Avatar
Liked: 1289
post #10822 of 11976 Old 01-20-2015, 10:55 AM
Cataphract's Avatar
My question was more so about the projector and it's capacity in terms of producing lumens. This is not my first PJ, and I have had a dedicated HT room before, so am aware of the obvious.
The question is how much light does this PJ throw out, and can I watch football with some lights on/dimmed, does it have enough juice? The contrast would suffer, but that is to be expected. I am asking if the brightest mode it has available is good enough with some lights on.
PS: Have no idea why the fonts are so gigantic in the original post. Tried a few times to edit without much luck. Sorry about that folks.
post #10823 of 11976 Old 01-20-2015, 11:00 AM
Daniel Chaves's Avatar
Quoted: 400 Post(s)
Liked: 289
Well then it may be obvious for you that such a question has been asked several times in this thread and on the net so a simple google search would yield the obvious question you are seeking.
But if not, here is projector central review with tested lumens.
http://www.projectorcentral.com/benq...ge=Performance
and we watch football games all the time in a living room with multiple windows just with the blind set to close so still plenty of light in the room and the picture is still easy to see and not so washed out but football games tend to be already fairly bright to begin with.
Projector: BenQ w1500 + ES Sable 135" Screen AVR: Onkyo TX-NR646 ATMOS/DTSX + Darbee 5000
Speakers: Polk Audio TSX550t (FL/FR), CS2 Series II (C), Monitor40 Series II (RL/RR),
Onkyo THX Bookshelf Speakers (Ceiling L/R), (2) JL Audio 12" Subs + (2) Dayton 15" Subs + (2) ButtKicker LFE
Arrangement: 5.1.2 Source: HTPC, Roku 4, Nexus Player, Samsung UBD-K8500 4k Bluray Player
Daniel Chaves is offline
post #10824 of 11976 Old 01-20-2015, 01:06 PM
Cataphract's Avatar
Thanks! I have read the review, and it is just that. A review.
We come to the forum to hear firsthand from owners, who have similar equipment and use it for some of the same purposes as other would be buyers are thinking about. So why not find out about their experience? Which is the real value, and more so because it is factual to that same type of environment, just as you mentioned in the second half of your post. That was very helpful! That is exactly what I wanted to know.
Now if can someone can comment on the offset question, that would be great too! Is that not an issue anymore with the available lens shift?
post #10825 of 11976 Old 01-20-2015, 01:43 PM
bluer101's Avatar
Quoted: 353 Post(s)
Liked: 285
Here is Sunday afternoon with windows and drapes open. Also run my pj in Eco mode.
bluer101 is offline
post #10826 of 11976 Old 01-20-2015, 02:11 PM
kyle85's Avatar
Quoted: 14 Post(s)
Well my w1070 just came in the mail and I immediately hooked it up to my xbox and threw a white sheet over my wall(my basement entertainment room is not finished yet).
First impressions are amazing playing CoD or watching anything HDTV, thats with it on eco mode, one blind open and a lamp on. Not to mention behind the sheet are two candle holders and a giant clock. So the sheet is about as far from flat as you can get, yet it still looks great and even better with the lamp off and blind closed.
So here is a slight issue I am having, has anyone ran into their comcast/cable service flickering when running through the xbox one? When i have the cable box running to the xbox one then the xbox running to the projector just the HDTV signal will constantly flicker about every second. The menus or games all work fine, if i plug the cable box straight into the projector is also works fine.
kyle85 is offline
post #10827 of 11976 Old 01-20-2015, 02:57 PM
fallenturtle's Avatar
So recently got the BenQ and I want to hook my Wii up to it. I've decided I'd prefer to only have an HDMI and power cable going to the projector (using the HDMI switcher in my receiver) therefore I'm in the market for one of those wii to HDMI converters. I was curious if anyone has had any experience with them... in particular I think some simply convert the 480p signal to digital where as other models upscale it to 1080p so I'm debating if I would get a better picture letting the projector upscale vs the adapter.
fallenturtle is offline
post #10828 of 11976 Old 01-20-2015, 04:17 PM
Cataphract's Avatar
Looks Awesome! Thanks for clearing all doubts about this PJ's brightness and lumen capacity! Mine just arrived. Love the next day delivery from Amazon!!
Could you please chime in about my offset question? I have 15 inches from the ceiling where my screen begins. The ceiling is 8 ft, screen size 106". The projector will be about 6 inches from the ceiling with the Qualgear mount from Amazon.
Where would the image start? Do I need an extension for the mount for the 3-4 inches of adjustment issue? Need to see if this mount will work or if I need another one. Is it advisable to use the pitch function of the mount to cover up the 3-4 inch difference, or will that introduce distortion?
post #10829 of 11976 Old 01-20-2015, 04:22 PM
grubadub's Avatar
Quoted: 96 Post(s)
Liked: 98
I believe the center of the lens needs to be 2 to 6 inches above the top edge of the screen.
grubadub is offline
post #10830 of 11976 Old 01-20-2015, 04:42 PM
bluer101's Avatar
Quoted: 353 Post(s)
Liked: 285
I can measure mine when I get home. I have 8ft ceilings too. Mine screen is 100 though. Remember from center of lens not projector mount or body. I also use pretty much all the lens shift too to get the pj as high as I can.
bluer101 is offline
Benq W1070 1080p 3d Projector
