BenQ W1070 : DLP Full HD, 3D Ready with lens-shift for 1000$ - Page 370 - AVS Forum | Home Theater Discussions And Reviews
 400Likes
post #11071 of 11989 Old 03-24-2015, 04:27 PM
Peterpack's Avatar
Quoted: 78 Post(s)
Liked: 34
Originally Posted by Ftoast View Post
If you're having trouble with rainbows, changing it to 50hz might solve the problem. If it already looks fine, there's little reason to change it.
Thank you Not having any problems with rainbows so far
Peterpack is offline
post #11072 of 11989 Old 03-24-2015, 07:54 PM
kyle85's Avatar
Quoted: 14 Post(s)
So I decided to temporarily mount the projector in my mostly finished basement and try to roughly setup the image size for a 120" screen using the built in test image. Once i got the height and width of the image dialed in to the correct size i noticed the bottom row of squares looked smaller. At first i thought the screen needed to be aimed down but that caused the screen to turn into a pyramid. After looked longer i noticed just the bottom row of squares were .5" smaller then the other rows from the top to the 2nd from the bottom row.
Is this normal on the test image for this bottom row to be smaller or is something else going on?
ID:	623393   Click image for larger version
ID:	623401   Click image for larger version
kyle85 is offline
post #11073 of 11989 Old 03-24-2015, 08:00 PM
StephenRC's Avatar
Quoted: 24 Post(s)
Normal, the bottom row is shorter.
StephenRC is offline
post #11074 of 11989 Old 03-24-2015, 08:11 PM
kyle85's Avatar
Quoted: 14 Post(s)
Well that's good news, was hoping nothing was wrong.
kyle85 is offline
post #11075 of 11989 Old 03-25-2015, 06:50 AM
Renron's Avatar
Quoted: 27 Post(s)
Liked: 30
SYVMN,
Great idea and solution for your given problem. Rather clever, out of the box thinking.
However, your choice in movies IS questionable / disturbing. (jk)
Nice job.
Ron
"New Member" since 2007....
Renron is offline
post #11076 of 11989 Old 03-25-2015, 02:10 PM
grubadub's Avatar
Quoted: 96 Post(s)
Liked: 100
how do you change it to 50 hz?
grubadub is offline
post #11077 of 11989 Old 03-25-2015, 03:41 PM
syvmn's Avatar
Quoted: 13 Post(s)
Originally Posted by Renron View Post
SYVMN,
Nice job.
Ron
Elf was the first 16:9 movie I came across while doing the testing. Also it's an american classic. I'm sure the library of congress will soon be archiving it for future generations to enjoy...
syvmn is offline
post #11078 of 11989 Old 03-26-2015, 04:35 AM
chmcke01's Avatar
Quoted: 31 Post(s)
Wife's favorite
Elf is one of my wife's favorite movies, definitely her favorite Christmas movie...trying to get her to watch National Lampoons Christmas Vacation (my go-to Christmas movie) is like pulling teeth!
chmcke01 is offline
post #11079 of 11989 Old 03-26-2015, 07:19 AM
Liked: 0
Hello everyone,
Quick question : is it confirmed that the w1070+ as higher input lag than the 1070 ?
Cause I had first settled on the 1070 due to it being a good compromise for a 60% gaming (fps, rpgs) 40% movies use.
But then i realized the wireless hdmi thing could be quite useful considering my room. I'm ok to pay the premium to get the w1070+ if it allows me not to have a cable running halfway across the room, but if it also increases input lag, not so much ...
StanRex is offline
post #11080 of 11989 Old 03-26-2015, 10:56 AM
Auric's Avatar
You can manually change it at the Source (if it's able to) there is no possibility to change it at the pj, the pj always sync with the source (if possible) and uses the highest color wheel speed that is possible with that frame rate.
I can't recommend anything else than using the original frame rate of the movie, everything else will cripple the picture quality because it will cause shutter etc..
so if you are an x-men and if you are massively disturbed by the rainbow effect (normal humans don't see it) go and buy a non-dlp pj.
greetings auric
Auric is offline
post #11081 of 11989 Old 03-26-2015, 11:02 AM
grubadub's Avatar
Quoted: 96 Post(s)
Liked: 100
greetings auric
thanks for the response. i'm not having a problem i was just curious. the only time i see rainbows are when the credits roll and i've seen them on the a few rare occasions with subtitles. i'm very happy and continually amazed that a projector at this price point can be so good.
fredxr2d2 likes this.
grubadub is offline
post #11082 of 11989 Old 03-26-2015, 11:23 AM
Liked: 0
Hi, i replaced my old lamp a few days ago. But when turn the projector on it works only a few minutes then shuts down and two LED indicators show up, a red that says Power and a green that says Temp. When i try to turn it on again a red LED that says "lamp" show up for about a minute, then the projector boots up as normal. And it works for 2-3 minutes again then shuts off once more.
Anyone know what might be wrong? Im sorry if i have a few gramatical or spelling errors, english is not my native language.
Klas Lindell is offline
post #11083 of 11989 Old 03-26-2015, 11:52 AM
kyle85's Avatar
Quoted: 14 Post(s)
This is from the manual
Looks liked the fans are not working correctly.
kyle85 is offline
post #11084 of 11989 Old 03-26-2015, 12:52 PM
Liked: 0
Guys any1 know what is the power consumption of W1070 on eco mode? Can't find it anywhere...perhaps soneone with the proper equipment could test? I am curious and i believe that many other people are also
Abadaman is offline
post #11085 of 11989 Old 03-26-2015, 05:20 PM
dragonbud0's Avatar
Quoted: 111 Post(s)
Liked: 51
It happened last week too, Just unplugged the power cord and restarted w/o any issues, so far.
dragonbud0 is offline
post #11086 of 11989 Old 03-27-2015, 01:39 AM
scoobdude's Avatar
Quoted: 59 Post(s)
Liked: 30
About 220 watts if I remember. You can find it in the service manualas well I think.
scoobdude is offline
post #11087 of 11989 Old 03-27-2015, 09:59 AM
Liked: 0
Just found something out today. I tried to turn the projector on without any HDMI cable on, and it can run without problems. As soon as i connect a video source (Hdmi for instance) it works for about 2 minutes and then shuts down again.. So something is really weird here.
post #11088 of 11989 Old 03-28-2015, 06:00 AM
Liked: 0
Thank you
Anyone else has observed that this projector runs a little bit louder while ceiling mounted with projector position: ceiling vs front in the menu?
Abadaman is offline
post #11089 of 11989 Old 03-28-2015, 05:42 PM
Peterpack's Avatar
Quoted: 78 Post(s)
Liked: 34
With the replacement lamps
Is this right
The only place you can a fully original replacement Lamp AND Housing is BenQ itself ?
Otherwise you can get 'original lamp inside' which is an original lamp inside a third party housing if that is correct ?
Are there original lamps with third party housings ok ?
seem to be around 25 percent cheaper
post #11090 of 11989 Old 03-28-2015, 11:03 PM
Peterpack's Avatar
Quoted: 78 Post(s)
Liked: 34
Originally Posted by kreeturez View Post
Quote:Originally Posted by EugF
In the interim, whenever we do serious cleaning of our room, I've 'fabricated' a dust cover by cutting a slit in top of the dust protector that the projector comes packaged in:
...since my last set of dust issues occurred on the day of a spring clean.
I did this as well ! i just added some masking tape to cover the holes at the front of the bag and also some tape at the end of my cut slit to stop it ripping any further
post #11091 of 11989 Old 03-29-2015, 07:50 AM
flint723's Avatar
Is this right
I got one of those original lamps in 3rd party housing on ebay. Not happy with it, one side of the screen was much brighter than the other. At the same time I had ordered an original bulb from china and when it arrived I installed it in my original housing, it was perfect.
I probably could have monkeyed with the ebay one and got the screen brightness even, but did not bother since the new bulb in the old housing was perfect. And much cheaper.
flint723 is offline
post #11092 of 11989 Old 03-29-2015, 04:56 PM
RLBURNSIDE's Avatar
Quoted: 1666 Post(s)
Liked: 1310
When my bulb exploded the glass inside the bulb assembly was chipped and the only way I could fix it was to replace the whole thing. So I just ordered a brand new one from amazon, replaced the chipped glass on mine, then returned it with the chipped piece. No way I was paying 250$ for a tiny bit of glass. My replacement bulb from china for 80 bucks has been perfect.
Has anyone who owns FireStorm XL 3D glasses had issues with the left / right polarity not being correct? I watched Sin City a Dame to Kill For recently and I had to switch back to my trusty Sainsonic 3d glasses because on those I could swap the left / right eye to make it look right. Apparently on the XLs you turn it off and on again and it should be reversed, but I just couldn't get it to look right no matter what.
Wondering if I could / should have just flipped the polarity in PowerDVD instead somehow. Any insights?
RLBURNSIDE is offline
post #11093 of 11989 Old 03-29-2015, 07:18 PM
Movie78's Avatar
Quoted: 820 Post(s)
Liked: 248
Is anyone experiencing blurriness on fast pace action movies with their projector?
OLD SETUP:http://www.avsforum.com/forum/15-gen...r-theater.html
NEW SETUP: http://forum.kodi.tv/showthread.php?...856#pid2506856
LG 75UH8500 3D DOLBY VISION HDR | SONY 43 ANDROID TV HDR
XBOX ONE S UHD BLU-RAY | PS4 PRO 4K HDR GAMING
MARANTZ SR7011 DTS X | ATMOS 5.1.4 | Auro-3D 9.1
Movie78 is offline
post #11094 of 11989 Old 03-30-2015, 07:44 AM
AV_Integrated's Avatar
Quoted: 1022 Post(s)
Liked: 740
Of course, motion is supposed to be blurry. It's always blurry, otherwise it looks like a poorly drawn cartoon.
Are you watching action movies from Blu-ray Disc, from cable TV, or from some other source like a digital download or Netflix stream?
If you are watching a download, you may want to see if you have the same issue when watching the same movie on a higher quality source like Blu-ray Disc.
The quality of Netflix is in the range of 1/10th of what Blu-ray Disc delivers, so you should expect an appreciable drop in quality.
AV Integrated - Theater, whole house audio, and technology installation in the Washington DC metro area.
AV_Integrated is offline
post #11095 of 11989 Old 03-30-2015, 10:41 AM
jch1's Avatar
Quoted: 35 Post(s)
I'm not sure if this has been answered previously, but I'm looking for a ceiling mount that allows for horizontally sliding the PJ. Does anybody know of one that would work?
jch1 is offline
post #11096 of 11989 Old 03-30-2015, 10:55 AM
scoobdude's Avatar
Quoted: 59 Post(s)
Liked: 30
I got the mono price one and it allows some adjustments. Not very precise when adjusting though.
post #11097 of 11989 Old 03-30-2015, 12:19 PM
Movie78's Avatar
Quoted: 820 Post(s)
Liked: 248
Are you saying it is normal to see blurriness,if you not using a good quality Bluray Player?
Movie78 is offline
post #11098 of 11989 Old 03-30-2015, 12:29 PM
Liked: 0
Hi guys,
At first, I would like to say hello as this is my first post here.
The point is that I am having some troubles with my BenQ w1070 since I updated it from 1.02 to 1.08. Since then the HDMI ports are not working fine at all:
- HDMI 2 does not work, directly. I have tried to connect the PC, PS4 or WD TV live with no results. It says no signal, and that is all.
- HDMI 1 works on his own way. Depending on what I connect there it works or not. For instance, with my laptop there is no problem but when connecting the PS4 or the WD TV live there is no way to make it work. It says "detecting input", "input detected", "detecting input", ... and enters in an endless loop
Is there any way to downgrade the firmware from 1.08 to 1.07? Or maybe, is it better to reinstall 1.08? Any suggestion?
I'm not sure if I have broken it or if there is any solution :S
Thanks in advance for your help.
PS: Just mention that with the previous firmware it was working fine and detected the PS4 with no problem.
PS2: I have read some people in this thread with similar problems (but with xbox instead of PS4) but I did not find any solution
dunadan84 is offline
post #11099 of 11989 Old 03-30-2015, 12:44 PM
Liked: 740
I'm saying that there are half a dozen different ways blurriness can be introduced into any image, projected or otherwise.
It could also be inherent in the material you are viewing. Wave your hand in front of your face - it's blurry. It's the way our eyes see things. If you track your hand back and forth, so your hand isn't blurry anymore, then the background is blurry.
Motion causes blurriness, and film captures that. Movies are shot at 1/24th of a second per frame typically. So, if you look at the original film, you would see blur.
If you use a good SLR camera, and set it to 1/24th of a second, you will capture a fair bit of blur.
If you increase the shutter speed, to (let's say) 1/1000th of a second, then the image would be crystal clear, but the motion would look painfully wrong. Like it was under a strobe light. This is what people call the soap opera effect that creative frame interpolation introduces to video.
But, that doesn't mean that everything should be blurry, and it depends on what you are looking at and what we are talking about.
The menus in the W1070 should be very sharp, from there, you want to feed it high quality content, not garbage, or even weak content. A 100" screen is going to work very hard to bring out every flaw in what you feed it, in much the same way a good sports car will reveal every flaw with the road you are driving on.
post #11100 of 11989 Old 03-30-2015, 02:32 PM
Liked: 0
Originally Posted by dunadan84 View Post
Hi guys,
Sorry for quoting myself but I could not find the edit button
I just wanted to say that I reinstalled 1.08 successfully but the problem is still there. So, I guess the only way I have to fix it is to downgrade the firmware but I am not sure if it is possible. Any of you guys have done it successfully?
Thanks in advance!
Benq W1070 1080p 3d Projector
