BenQ W1070 : DLP Full HD, 3D Ready with lens-shift for 1000$ - Page 371 - AVS | Home Theater Discussions And Reviews
post #11101 of 11102 Old Yesterday, 03:19 PM
zapper's Avatar
Originally Posted by syvmn View Post
I thought I would post my 2.4:1 W1070 setup to this thread in the off chance someone might find it interesting.
I had the perfect spot in my basement of my new house for a 2.4:1 screen. Unfortunately the common "solution" was to get a CIH lens that would go over the front of the projector to stretch the image when I wanted 2.4:1 and then move out of the way when I wanted 16:9. Those lenses cost a LOT of money and were totally out of the question.
Unfortunately the W1070 does not have enough zoom to display both native 2.4:1 and 16:9 on the same screen when mounted in a fixed position. I decided to make things overly complicated and constructed a sliding projector mount that allows me to move the projector enough to view both on my screen for ~$0 cost.
I just finished everything up yesterday and have been really enjoying the outcome. Please ignore the "paint" job on the mount. I got a defective can of paint and will be refinishing it at a later time. Also ignore all of the cords everywhere. I set things up for a quick test run, not as a final solution.
Testing my frame.
Finished 2.4:1 screen.
2.4:1 Guardians of the Galaxy test. Note that there is a window letting light into the room just off to the right of the picture. This was taken about an hour ago (4PM).
Position of projector in 2.4:1 mode.
Elf in 16:9.
Projector in 16x9 mode.
Excellent set up...
Ralph
zapper is offline
post #11102 of 11102 Old Today, 03:35 AM
Liked: 0
Guys, i have noticed a weird issue with my benq w1070, not a problem at all, but i wonder if this is normal. I have my PJ ceiling mounted, with pj position ceiling in the menu, when i switch it to front in the settings(the image shifts upside down, as it is ceiling mounted), the projector runs quieter, is this normal? Any1 can test this? Just change projector position in the menu and let it run for two minutes, is it a bit louder in ceiling and quieter in front mode? Thank you!
Abadaman is online now
Benq W1070 1080p 3d Projector
Gear in this thread - W1070 by PriceGrabber.com
