BenQ W1070 : DLP Full HD, 3D Ready with lens-shift for 1000$ - Page 375 - AVS | Home Theater Discussions And Reviews
post #11221 of 11235 Unread 05-21-2015, 06:05 PM
atabea's Avatar
Quoted: 61 Post(s)
Liked: 81
Originally Posted by flint723 View Post
The ps3 is what makes the projector go into frame packing 3d mode (which is what blu-rays do). So I would start looking for a setting in the ps3. The w1070 detects this mode automatically even though there is no setting for it.
Thanks, Flint, I will play around with the PS3 settings next time I visit.
I will also take along my spare (Panasonic) 3D Blu ray player to test this theory.
regards,
atabea
atabea is offline
post #11222 of 11235 Unread 05-21-2015, 06:09 PM
Sonyad's Avatar
Quoted: 88 Post(s)
Liked: 61
Originally Posted by atabea View Post
.........Was visiting a friend who owns the W-1070 and noticed he is having a problem with Blu-ray 3D playback, via a PS3. He confirmed that he used to be able to watch 3D Blu-rays, but for some reason 3D is now turned off and cannot be reactivated in the 3D menu. The only access he has in the 3D menu is SBS and Over/Under (everything else is greyed out). There is no option to select "auto" so that it automatically detects 3D movies. Is there something he can do to rectify this oddity? I checked his firmware (1.04) but since he was previously able to watch 3D with that version, I can't see how that could be the problem.
atabea
Try resetting the PS3 per these instructions https://us.en.kb.sony.com/app/answer...ion-3-console.
Sonyad is offline
post #11223 of 11235 Unread 05-21-2015, 06:22 PM
atabea's Avatar
Quoted: 61 Post(s)
Liked: 81
Thanks, sonyad, will definitely give it a go.
Atabea
atabea is offline
post #11224 of 11235 Unread 05-22-2015, 01:14 PM
atabea's Avatar
Quoted: 61 Post(s)
Liked: 81
Just wanted to say "thanks" guys, resetting the PS3 worked!!!!!
regards,
atabea
atabea is offline
post #11225 of 11235 Unread 05-22-2015, 02:35 PM
Rashman's Avatar
Does anyone know if there's an index post for this thread anywhere? I'd like to find discussions or some widely-accepted picture adjustment settings. Before people snap at me:
1) I understand that I should probably read the entire thread, and I'll try to work my way through it, but there are currently 375 pages.
2) I know that viewing conditions affect projector settings a lot, and that in the long run I should do my best to calibrate for my particular conditions. I plan to do that (with Disney WOW or other), but I thought I'd see if there's a typical jumping-off point where I could improve things in the near-term before I get to calibrating on a more fine-grained level.
Rashman is online now
post #11226 of 11235 Unread 05-22-2015, 03:51 PM
jbn008's Avatar
Quoted: 39 Post(s)
Liked: 26
post calibration settings from avforums.com:
Preset: User 1
Brightness: 51
Contrast: 53
Colour: 50
Tint: 50
Sharpness: 8
Colour Temp: Normal
Lamp Power: Economic
Advanced
Clarity Level: 0
Gamma: 2.2
BrilliantColor: Off
Colour Temp Fine Tuning: Red Gain 96, Green Gain 88, Blue Gain 95, Red Offset 256, Green Offset 256, Blue Offset 256
Colour Management: Red - Hue 50/Gain 52/Saturation 49, Green - H 64/G 48/S 50, Blue - H 52/G 47/S 50, Cyan - H 50/G 47/S 50, Magenta - H 70/G 51/S 50, Yellow - H 64/G 50/S 47
Aspect Ratio: Real
https://www.avforums.com/threads/ben...tings.1761516/
Rashman likes this.
Headless Petie
jbn008 is offline
post #11227 of 11235 Unread 05-22-2015, 09:37 PM
RLBURNSIDE's Avatar
Quoted: 535 Post(s)
Liked: 390
Hey guys, I'm selling my Runco Whitney vertical compression anamorphic lens for $1000:
For Sale, Runco Whitney VC anamorphic lens
I find myself not using it much lately since I mostly do 16:9 gaming and watch more TV shows than movies like I used to.
RLBURNSIDE is online now
post #11228 of 11235 Unread 05-22-2015, 10:00 PM
DavidK442's Avatar
Quoted: 251 Post(s)
Liked: 155
Smile
At 11225 posts for an $800 projector, you are excused for not wanting to read everything...although the shear repetition and the vehement passion some express can be entertaining.
Rashman likes this.
DavidK442 is online now
post #11229 of 11235 Unread 05-22-2015, 10:33 PM
dreamer's Avatar
Quoted: 477 Post(s)
Liked: 134
These are my settings.
Apartment setup guidance
Rashman likes this.
Kirk Ellis
JVC DLA-RS1 VuTec 122" Screen
Harmon Kardon AVR 247 Parasound L&R Amp
Psycoustic Mark III L&R Towers, Boston Center
Energy Take 5 Surrounds, HSU Research Sub
dreamer is offline
post #11230 of 11235 Unread 05-22-2015, 11:15 PM
Liked: 0
What are some projector carrying cases worth buying? Any preferences?
Are these two cases good for traveling?
http://www.amazon.com/gp/product/B00...f_rd_i=desktop
pycologens4me is offline
post #11231 of 11235 Unread 05-23-2015, 07:05 AM
Rashman's Avatar
Thank you both!
post #11232 of 11235 Unread Yesterday, 02:59 PM
sojodave's Avatar
Liked: 45
I changed my bulb yesterday. I had 3700 hours in two years and I could have waited, but I wanted to do it before it popped. I bought it on Amazon for $65 and it came from China on the slow boat. It was authentic, followed the directions, and got it in with no problems. Picture is uniform and looks good. I reset the hours, reset the projector and re-input my settings. If you haven't done this yet...
* Remove the one screw from the side of the projector
* Remove the lid on top of the projector by prying up
* Remove the clear plastic plate over the bulb
* Remove the one screw closest to the lens
* Pull up using the wire handle
* Unscrew the small screws on the side of the lens that holds the silver plate
* Once plate is removed from bulb and housing, remove the four screws holding the bulb in
* Remove the electrical clips
* Remove old bulb
* Install new bulb and put in the four screws to hold the new bulb
* Put the screws back in on the side that holds the plate
* Connect the electrical connections by sliding wire clips over stems
* Slide bulb housing back into projector
* Put the clear plastic plate back on
* Snap on the lid back on
* Screw in the side screw
* Reset your settings
* Reset your bulb hours
sojodave is online now
post #11233 of 11235 Unread Yesterday, 04:10 PM
chmcke01's Avatar
Quoted: 23 Post(s)
Link
* Remove old bulb
Could you post or message me a link to where you found a bulb for that cheap?
chmcke01 is offline
post #11234 of 11235 Unread Today, 07:12 AM
sojodave's Avatar
Liked: 45
Benq W1070 1080p 3d Projector
Gear in this thread - W1070 by PriceGrabber.com
