BenQ W1070 : DLP Full HD, 3D Ready with lens-shift for 1000$ - Page 390 - AVS Forum | Home Theater Discussions And Reviews
 372Likes
post #11671 of 11812 Old 01-11-2016, 09:36 AM
scoobdude's Avatar
Quoted: 56 Post(s)
Liked: 29
120" might not work at 11 feet. I had mine 12 and zoomed ask the way it and would barely full it.
Also what I did was a ceiling mount, even went under the fan, with a monoprice mount and then ordered the HDMI cable and a power adaptor (normal 3 prong like for computers or most TVs). I did not have an outlet on the ceiling.
Then get the wire tracking for like 20 bucks at HD out lowesand make it look pretty... Or at least less conspicuous
If you upgrade the audio the trickiest part maybe where to put the receiver due to HDMI cable limitations. So think about that before you start on the audio stuff.
scoobdude is offline
post #11672 of 11812 Old 01-11-2016, 09:45 AM
Luis Gabriel Gerena's Avatar
Quoted: 80 Post(s)
Liked: 59
How do you guys deal with the ceiling mounts exactly?
I mean, I have mine on an unfinished basement on a tall rack standing on concrete (and a box on top of the rack to push it as close to the top as possible) and even them when the action gets big, my 3 subs will make the image shake. I used to have only one Sub before on my previous house with an unifished basement as well but that time it was ceiling mount and it will shake a lot...so I am just wondering how you guys avoid that.
Mario Lemieux is GOD!
Go Pens!!!
Aguante Boca!!!
If dolphins are so smart...why do they live in igloos?
Luis Gabriel Gerena is offline
post #11673 of 11812 Old 01-11-2016, 10:00 AM
scoobdude's Avatar
Quoted: 56 Post(s)
Liked: 29
Here is the mount I used. Planted in dry wall it only shook when my wife walked upstairs and even then not much. There were 6 holes, one on each corner and two in the middle. I only did the middle ones and then used cardboard to pressurize the outer holes or full in the space to keep it from wobbling.
ID:	1178402   Click image for larger version
ID:	1178410   Click image for larger version
post #11674 of 11812 Old 01-11-2016, 11:29 AM
StephenRC's Avatar
Quoted: 21 Post(s)
Monoprice's Redmere hdmi cables will solve that. I'm using a 25' Redmere from my receiver to the projector with no problems.
Rashman likes this.
StephenRC is offline
post #11675 of 11812 Old 01-11-2016, 12:29 PM
Quoted: 65 Post(s)
Liked: 8
I am using a 35' Redmere and it works great.
Rashman likes this.
BleedingBlue is offline
post #11676 of 11812 Old 01-11-2016, 01:19 PM
AV_Integrated's Avatar
Quoted: 854 Post(s)
Liked: 647
I am using a 75' standard 22 AWG cable and it works fine.
Redmere cables are nice, but there is rarely an issue with video up to 1080p using standard HDMI cables. Everyone is running to Redmere like the cables we have been using for the last ten years didn't work. They have been working fine.
There are also cables from companies like Blue Rigger which are fairly lightweight and have phenomenal reviews. As long as the cables are accessible, you should just roll with a cheaper cable or two. Keep in mind Redmere cables use active electronics which can fail after time, so if you run one HDMI cable behind drywall, or in a tough to replace location, you are asking for big trouble.
Behind drywall, always run 2 HDMI cables of decent quality and two cat-5e or cat-6 cables for future use if needed.
AV Integrated - Theater, whole house audio, and technology installation in the Washington DC metro area.
AV_Integrated is offline
post #11677 of 11812 Old 01-11-2016, 01:19 PM
Quoted: 854 Post(s)
Liked: 647
post #11678 of 11812 Old 01-16-2016, 06:00 PM
wasure's Avatar
hey guys,
just a quick "snowball chance in hell" question about mounts.
i went for a totally crappy mount as the purchase was easy: one-click order and i got everything to mount the 1070 and make the 27-inch drop from the ceiling i needed. i got a professional install, and all's good.
but it's really a pain when i have to make adjustments (buy a good mount!!), so i was wondering if this looks like something where i could use what the installer put into the studs in the ceiling and attach better mounting gear to it, either at the ceiling end or at the projector end.
thanks!
wasure is offline
post #11679 of 11812 Old 01-16-2016, 06:00 PM
wasure's Avatar
[deleted duplicate post]
wasure is offline
post #11680 of 11812 Old 01-18-2016, 11:57 AM
Quoted: 65 Post(s)
Liked: 8
Originally Posted by wasure View Post
hey guys,
thanks!
I am far from an expert as I just got in to this hobby a few months ago, but I think you need to scrap what you have and get a better mount. They are incredibly easy to install, if u have a drill and a stud finder you can do it.
post #11681 of 11812 Old 01-18-2016, 03:22 PM
jch1's Avatar
Quoted: 35 Post(s)
Any reliable places to purchase bulbs for this PJ in the US? I've read lots about fake products being sold, but I'd hate to purchase a full price OEM bulb.
jch1 is offline
post #11682 of 11812 Old 01-19-2016, 02:13 AM
kreeturez's Avatar
Quoted: 412 Post(s)
Liked: 323
There's a thread discussing bulbs for this projector that should help you, see here.
Rashman likes this.
BenQ W1070 Projector; Kodi (on Ubuntu, OpenELEC & S802) via Sony STR-DH540 AVR with Boston Acoustics SoundWare XS SE 5.1 Audio + Jamo 210 Sub. Emby for Mobile Streaming.
Helpful post? Click the 'Like' button!
kreeturez is offline
post #11683 of 11812 Old 01-19-2016, 11:54 AM
Iron Maiden's Avatar
Quoted: 453 Post(s)
Liked: 163
Does the 1075 use the same lamp?
Iron Maiden is offline
post #11684 of 11812 Old 01-24-2016, 07:59 AM
Quoted: 80 Post(s)
Liked: 59
Hello all!
I am using my W1070 with my HTPC (Nvidia GTX750 ti)
I noticed that when set to RGB and FULL in Control Panel, it will NOT pass the 4:4:4 Chroma test. If I set it to YCbCr 4:4:4 then it does and looks sharper of because of this.
Anyone else noticed this?
Go Pens!!!
Aguante Boca!!!
post #11685 of 11812 Old 01-24-2016, 11:35 AM
kreeturez's Avatar
Quoted: 412 Post(s)
Liked: 323
Originally Posted by Luis Gabriel Gerena View Post
Hello all!
4:4:4 Chroma Test (with RGB: Full Color Space) passes my side.
I'm running a GTX 970, though, so could it be your card (or driver?)
Quick photo (pardon the phone-camera quality):
It also passes at YCbCr444. As expected, it doesn't pass with YCbCr422 (and indeed, text looks nowhere near as sharp... so a must-have for PC use, I guess).
Here're my card settings:
ID:	1206050   Click image for larger version
post #11686 of 11812 Old 01-24-2016, 12:11 PM
RLBURNSIDE's Avatar
Quoted: 989 Post(s)
Liked: 740
As soon as UHD Bluray players and movies come out, owners of the w1070 might want to consider enabling 10-bit Deep Color. You can do that at 444 at 24/30hz I believe. (not at 60hz).
If anyone wants the best possible experience for UHD Bluray movies out of this projector, I recommend making a custom resolution of 1920x810, using 10-bit color through the VGA port, and increasing to 72hz at 1080p/RGB. I've managed 71hz at 1920x1080 at 10-bit so far, but I think it will require a slight vertical down-res to get that extra Hz in there (one wants a multiple of 24hz for movie watching, even when using interpolation like SVP because it will still look better due to no cadence mismatch).
RLBURNSIDE is offline
post #11687 of 11812 Old 01-27-2016, 11:50 PM
Quoted: 34 Post(s)
Liked: 3
Does anyone have any recommended settings for 3D viewing?
farr3ll is offline
post #11688 of 11812 Old 02-01-2016, 01:39 PM
Daniel Chaves's Avatar
Quoted: 307 Post(s)
Liked: 214
Im curious about this, would it be possible to do a write with images or even like a youtube video?
Projector: BenQ w1500 + ES Sable 135" Screen AVR: Onkyo TX-NR646 ATMOS DTS-X + Darbee
Speakers: Polk Audio TSX550t (FL/FR), CS2 Series II (C), Monitor40 Series II (RL/RR),
Onkyo THX Bookshelf Speakers (Ceiling L/R), (2) JL Audio 12" Subs + (2) Dayton Sub-1500 + (2) ButtKicker LFE
Arrangement: 5.1.2 Source Nexus Player, Roku 4, Panasonic Bluray Player
Daniel Chaves is offline
post #11689 of 11812 Old 02-01-2016, 01:55 PM
grubadub's Avatar
Quoted: 77 Post(s)
Liked: 91
here are 3d settings that i use that look pretty good = http://www.soundandvision.com/conten...4FSXSTStwwE.97
i think they are posted in a thread on this site somewhere.
grubadub is offline
post #11690 of 11812 Old 02-02-2016, 12:37 AM
Quoted: 34 Post(s)
Liked: 3
Thanks mate. Yeah I came across it then promptly lost it again. Much appreciated.
farr3ll is offline
post #11691 of 11812 Old 02-02-2016, 01:27 PM
dchabby's Avatar
Quoted: 74 Post(s)
Liked: 36
is there anything we can do regarding a loud fan ?
seems to be more noticeable lately or I just seem to be more sensitive to it as nobody else mentions anything
dchabby is offline
post #11692 of 11812 Old 02-02-2016, 03:12 PM
zapper's Avatar
Quoted: 48 Post(s)
You must be seating below the projector or really close by, we all thought the same thing as you at first but then we just cranked up the receiver volume and enjoyed the projector...
Ralph
zapper is offline
post #11693 of 11812 Old 02-03-2016, 06:52 AM
dchabby's Avatar
Quoted: 74 Post(s)
Liked: 36
Yes unfortunately we are right below the projector. And yes cranking the volume helps but in the quieter scenes it really stands out plus we don't listen at high volumes all the time.
So other than maybe moving the projector are there any other options ?
dchabby is offline
post #11694 of 11812 Old 02-03-2016, 07:08 AM
Rew452's Avatar
Quoted: 71 Post(s)
Liked: 43
As a long time owner, you learn to overlook it and enjoy the movie. I presume you are using the SmartEco setting for the lamp; this does quiet it down somewhat and improve lamp life.
dchabby likes this.
Rew
BenQ HT2050 |Lumagen RadianceXS-3D |Panasonic BDT460 | Samsung UBD-K8500
Denon AVR-x5200w | Nvidia Shield Android TV | C =Axiom VP150 |FL/FR =Axiom M60 |SL/SR =Axiom QS4 |TFL/TFR =Bose 161 | TRL/TRR =Bose 161 |Sub =Reaction Audio S-15 500W SEALED SUBWOOFER
Rew452 is online now
post #11695 of 11812 Old 02-03-2016, 10:06 AM
grubadub's Avatar
Quoted: 77 Post(s)
Liked: 91
Eco is the quietest setting. When I put mine on SmartEco, the fan gets louder.
dchabby likes this.
grubadub is offline
post #11696 of 11812 Old 02-03-2016, 10:18 AM
Rew452's Avatar
Quoted: 71 Post(s)
Liked: 43
I think you will find that noise will vary as the smart-eco setting changes lamp voltage based on the video being displayed. This setting not only improves the lamp life but also is hard to tell in brightness from the normal setting. I have also not seen much if any flickering which tends to occur with eco or normal setting. I think this is due to the changing lamp power.
Flickering is not just a BenQ issue but all pj's tend to have it some time during the life of the lamp.
dchabby likes this.
Rew
post #11697 of 11812 Old 02-03-2016, 12:55 PM
dchabby's Avatar
Quoted: 74 Post(s)
Liked: 36
^^ thanks - will try that setting and see if the noise improves
dchabby is offline
post #11698 of 11812 Old 02-03-2016, 01:02 PM
Rew452's Avatar
Quoted: 71 Post(s)
Liked: 43
One thing I forgot to say is the fans go full speed when first powered on; then slow down to temperature control. This was added in one of the firmware updates to verify the fans were operating right.
Rew
post #11699 of 11812 Old 02-07-2016, 06:33 AM
maddog42's Avatar
Hey All.
Why is this spot in my image?
Is that too much light from the benq w1070,or is it two close two the canvas?
Or?
maddog42 is offline
post #11700 of 11812 Old 02-07-2016, 06:34 AM
maddog42's Avatar
Hey All.
Or?
maddog42 is offline
Benq W1070 1080p 3d Projector
taboola here
