BenQ W1070 : DLP Full HD, 3D Ready with lens-shift for 1000$ - Page 400 - AVS Forum | Home Theater Discussions And Reviews
 396Likes
post #11971 of 11973 Old 03-16-2017, 04:54 AM
RLBURNSIDE's Avatar
Quoted: 1617 Post(s)
Liked: 1282
Originally Posted by qal1h View Post
My experience with the 1070 in a few lines:
Great projector, nice colours, bright and very good video quality, no tearing or other issues.
Few things to note, I do sometimes get the rainbow effect, only slightly noticeable, not a big issue at all.
The projector is a tad bright, i've not adjusted the settings at all but the original colour config is fine and I dont know where to start with adjusting it. We generally use it on a white wall, and the blacks aren't very deep at all.
However we got a 150" grey projector screen and the colours look brilliant, so much better than on a white wall, the blacks are now deep and overall picture quality is so much better.
Can you do me a favour? Try running the projector at 71.928 hz (using my settings above), from your PC, and tell me if that makes the rainbows disappear.
In theory, going from 60hz to 72hz could help reduce RBE since the colour wheel speed is synced to the refresh rate. And a 20% reduction is nothing to sneeze at. It's like going from a 5X to a 6X colour wheel speed. Actually, exactly like that, since the w1070 drops to 5X at 60hz so running it at 72hz likely brings it back up to the equivalent of 6X.
I've been meaning to try painting my wall gray, although reducing the brightness doesn't actually increase the contrast AFAIK, since you're cutting both white level and black level by the same amount, so the ratio between them stays the same no matter what.
RLBURNSIDE is online now
post #11972 of 11973 Old Today, 01:39 AM
andyxoxo's Avatar
Originally Posted by RLBURNSIDE View Post
The smart move here is to replace your bulb before that happens, to avoid collateral damage (which can affect other components including the colour wheel) and big messy glass cleanup after the fact.
Commercial cinemas have figured this out years ago. You do not want explosions. These bulbs are dirt cheap for the lifetime they offer. 80 bucks shipped from Amazon for 4000-5000 hours of usable lifespan is a bargain.
I would recommend to all w1070 users to replace their bulbs at no longer than 4500 hours. It will be quite dim by then anyway and time for a freshening up anyway.
Ya, that's very good advice and I am going to take it. I have one question though... I see that bulbs with housing are sold and then also just the bulbs itself are sold. Since it seems you have taken your W1070 apart (a few times ;-) have you seen heat damage or distortion on the housing that would require (or make sense for) an owner to replace the housing & bulb together? Or after prolonged usage can we just get away with replacing only the bulb at 4500 hours? Am curious to know your recommendation for someone like me who has never had to replace the bulb yet if we can just go for the bulb or also should change the housing as well for best optical performance. Cheers
andyxoxo is offline
post #11973 of 11973 Old Today, 12:30 PM
RLBURNSIDE's Avatar
Liked: 1282
Funny you should mention that, when my bulb exploded it cracked the glass in front in the housing and I couldn't order it separately, so I had no choice but to order a new housing. But the 80 dollar bulbs now on amazon often include the housing too, and it's convenient to have a spare. If you don't need it though, and nothing's broken, then definitely try to save 30 bucks and get just the bulb w/o the housing.
Benq W1070 1080p 3d Projector
