BenQ W1070 : DLP Full HD, 3D Ready with lens-shift for 1000$ - Page 401 - AVS Forum | Home Theater Discussions And Reviews
 1417Likes
post #12001 of 12009 Old 08-07-2017, 07:53 AM
skoolpsyk's Avatar
Quoted: 88 Post(s)
Liked: 57
Originally Posted by dreamer View Post
Came across this video and thought I'd share.
https://www.youtube.com/watch?v=fPQd_Lz_78Q
I had thought about putting a Peltier cooler on the air intake, but not simply a monstrous heatsink on the lamp module.
thanks for sharing; unfortunately I have my short throw on a stand in front of me so it wouldn't work but it's an interesting idea!
skoolpsyk is offline
post #12002 of 12009 Old 08-15-2017, 05:22 AM
Liked: 6
FYI to anyone reading this thread, I was able to fix this by adjusting the brightness and contrast until I hit the right combination and the snow was 99% gone.
tomeklives is offline
post #12003 of 12009 Old 08-17-2017, 08:18 PM
wasntme's Avatar
I went to start my BenQ w1070 today and every time I turned it on, the power light would blink green twice and then orange once and not power on. I then unplugged the projector and waited a minute. When I plugged it back in the power light is solid red. The Projector won't turn on. I read that it's in "Download Mode" but I wasn't able to get DLP Composer to recognize it connected via USB.
Has anyone else seen this? Unplugging and plugging back in has not fixed it either, as it remains in the same state.
wasntme is offline
post #12004 of 12009 Old 08-17-2017, 08:50 PM
dreamer's Avatar
Quoted: 1047 Post(s)
Liked: 316
I have not seen that, but do you still have a previous lamp that worked but you replaced just due to hours or dimness ? I would try swapping lamps. If you don't have a spare, buy a cheap $40 lamp from Amazon just to see if that works and to have as a spare. If a different lamp behaves the same way, then it is likely the power supply board or lamp ballast board and those are both several hundred bucks to repair.
Kirk Ellis
BenQ W1070 VuTec 122" Screen
Harmon Kardon AVR 247 Parasound L&R Amp
Psycoustic Mark III L&R Towers, Boston Center
Energy Take 5 Surrounds, HSU Research Sub
dreamer is offline
post #12005 of 12009 Old 08-17-2017, 08:52 PM
wasntme's Avatar
Unfortunately I don't have an old lamp. My old one exploded. I think I am going to take it a apart and see if anything is loose. If it all checks out, I might end up having to buy a new one. I got this one over 4 years ago, so it got some good use. This sucks....
wasntme is offline
post #12006 of 12009 Old 08-17-2017, 09:18 PM
dreamer's Avatar
Liked: 316
Benq will charge you $65 to check it out. A $40 lamp to test with may be worth a shot. If you take it apart, what will you be looking for ?
Kirk Ellis
dreamer is offline
post #12007 of 12009 Old 08-17-2017, 09:39 PM
wasntme's Avatar
I looked for loose cables since I took it apart a couple weeks ago to clean it/replace the lamp housing (I saw nothing bad when I took it apart and had the same results when it all came back together). BenQ will charge $65 plus shipping, which kinda stinks. I couldn't expect more than that though. I think I might just bite the bullet on the HT2050.
wasntme is offline
post #12008 of 12009 Old 08-17-2017, 09:58 PM
dreamer's Avatar
Liked: 316
If you do replace it, let me know before you just trashcan the W1070. I have a dead power supply in my W1070 and would be willing to buy it for parts. Where are you located and about how many hours were on the lamp that is in it ? A low hours lamp would be worth something to me, even if I can't find the parts I need to make mine work.
Kirk Ellis
dreamer is offline
post #12009 of 12009 Old 08-17-2017, 10:12 PM
wasntme's Avatar
Sent you a PM.
wasntme is offline
Benq W1070 1080p 3d Projector
