Basement theatre, need wiring input - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 11-12-2012, 09:51 AM - Thread Starter
madspeed's Avatar
Im working in my theatre build and about ready to run some wires. Im running some conduit for the wiring, what type of connections do i need to run up to the projector? Dont have the projector yet.
madspeed is offline
post #2 of 7 Old 11-12-2012, 11:27 AM
boblinds's Avatar
Quoted: 12 Post(s)
Liked: 39
(My two cents...) I'd run two HDMI cables.
boblinds is offline
post #3 of 7 Old 11-13-2012, 03:54 AM - Thread Starter
madspeed's Avatar
any point in running components anymore?
madspeed is offline
post #4 of 7 Old 11-13-2012, 06:38 PM
rovingtravler's Avatar
You will need a power outlet and an HDMI. I would not run a second one, but make sure you leave enough room so you can feed, string a new cable through as the cables change... we all know they will!
David
"You buy a Ferrari when you want to be somebody. You buy a Lamborghini when you are somebody." - Frank Sinatra
rovingtravler is offline
post #5 of 7 Old 11-13-2012, 08:23 PM - Thread Starter
madspeed's Avatar
ill leave a string in just in case. Got power outlet within a few inches so should be good to go. Whats the point of running a second hdmi?
madspeed is offline
post #6 of 7 Old 11-13-2012, 10:13 PM
Project H's Avatar
besides power and hdmi to the receiver.. i dont think you need anything else unless you want to run the speaker wire too. your other components can connect to the receiver directly
Project H is offline
post #7 of 7 Old 11-14-2012, 02:00 AM
Skylinestar's Avatar
Quoted: 1175 Post(s)
Liked: 213
Run the speaker wire to the ceiling... getting ready for Dolby Atmos in the future. biggrin.gif
Skylinestar is offline
