less than 700$ best dlp projector for a +150 inches screen ? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 11-13-2012, 03:34 AM - Thread Starter
KimNeJoi's Avatar
Hi,
i am looking for a projector for less than 700$ , i'll be using the projector for a +150" screen .
i have searched for this options and i found a 2 choices
the 1st is Optoma gt750e
it comes with 3000 lumen and 3000:1 contrast ratio and with a 1280x800 resolution
2nd choice is from BenQ the W710st
comes with 2500 lumen and 10000:1 contrast ratio and with a 1280x800 resolution
( but i heard that this projector have a white dots problem )
what do you prefer from these choices ?
what is the 3rd choice that may considered with these ?
thanks
KimNeJoi is offline
post #2 of 5 Old 11-13-2012, 04:35 AM
Elix's Avatar
Quoted: 215 Post(s)
Liked: 100
720p on a 150" screen is going to look very soft.
Elix is offline
post #3 of 5 Old 11-13-2012, 05:42 AM - Thread Starter
KimNeJoi's Avatar
here is a test with gt750e on (190") screen
http://www.youtube.com/watch?v=glwzgA_QeQc
and i like the quality with this screen size
KimNeJoi is offline
post #4 of 5 Old 11-13-2012, 08:15 PM - Thread Starter
KimNeJoi's Avatar
up
KimNeJoi is offline
post #5 of 5 Old 11-19-2012, 06:30 AM
utee05's Avatar
Quoted: 36 Post(s)
Check out the egg. They have the viewsonic prohd8200 for under $700 with $50 gift card.
utee05 is offline
