Optoma HD20 screen size and throw distance help - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 11-13-2012, 01:46 PM - Thread Starter
kevoin's Avatar
I am confused as to how big of a screen i should build and where i should mount my projector. My main issue is that i have a very low drop ceiling. (78") I bought a mount with an extension pole, so i plan to mount to the above floor board and run the pole through the drop ceiling having it as close to flush mount as possible. so for the specifics:
projector: Optoma HD20
projector mount: Peerless PRG-UNV-W Precision Gear Universal Projector Mount (+ 6-9" extension pole.)
room = 131" x 190" x 78" (the screen will be on the 131" wall.)
based on the calculator at http://www.eliteprojectorcalculator.com/ it gave me the largest possible screen size of 85"
I've never had a projector, so this is all pretty foreign to me. So let's say i want to go bigger, can i make a say 96" and fix the image with the keystone correction?
Also, what screen size would you recommend for a room that size.
If it matters, I needed an AT screen and bought moleskin silver and white. I plan to have the silver over the white because i favor more contrast over a brighter washed out look. The HD20 has 1700 Lumens, do you think the silver over the white is wise? The room is completely blacked out, but also has that low white drop ceiling.
I have all of my materials and enough to build a 110" screen, although i know that is way to big. I appreciate any advice you can give me. This is all a lot more complicated than i envisioned.
kevoin is offline
post #2 of 2 Old 11-13-2012, 02:36 PM
rekbones's Avatar
Quoted: 407 Post(s)
Liked: 196
By my calculations if the projector is flush with the ceiling you could get "110 screen with no keystone and the bottom would be about "15 from the floor. if thats to close you could move it up (tilt the projector up) and correct with keystone or tilt the screen down to correct the keystone.
"Smart enough to know better, to old to care" ------ Dedicated Home Theater, Mitsubishi HC7900DW Projector, 110" 16:9 Jamestown screen with variable power masking for CIW 2.50:1 to 16:9, Marantz 7009 with 7.1.4 Atmos with Ohm mains,3 DIY Subs (2 15" (1 ported, 1 sealed and a 12" 4th order bandpass), 1 DIY butt kicker, Custom Built HTPC, 10TB DroboFS NAS
rekbones is offline
